Question about Asko 24 in. D3450 Dishwasher
Asko #D3120/DW20.1 how do you get to the heating element
Need to know how to gain access to the heater element(sealed unit). Checked the element by the wires on the board plug (unplugged) and it came up w/11.5 ohms. Supposed to be 30 ohms
  • 140 Answers
SOURCE: new install; where to hook up old wiring/plug to ASKO
There should be an installers/repair guide folded up behind the front panel. Check for that as it will show a wireing diagram. I won't be able to get any info until Jan 2. Let me know what you find.
Posted on Jan 01, 2009
SOURCE: asko d3120 flashing coffee cup
I had to slide the dishwasher forward (undercounter installation)and tip it forward as far as possible. Water leaks onto floor, but then the internal controller seems to reset and the ASKO now works normally again. What kind of idiot would design a control module that does not incorporate a power-off interlock? FAIL FAIL FAIL - Bad, ASKO, Bad. Go to your room.
Posted on Feb 13, 2009
  • 3247 Answers
SOURCE: Our 4 year old Asko D3121 dishwasher has stopped
I would check the voltages around the heater before replacing it. Sometimes the thermal overload relay opens out and shuts off the power. Could be a more simpler to replace than the whole heater.
Posted on Jun 29, 2010
Testimonial: "excellent!...thank you !"
jyackle5
  • 8197 Answers
SOURCE: replaceing heating element in Asko D1996
Disconnect the power source to your dishwasher before you conduct this or any other test. Either unplug the unit from the wall outlet, remove the appropriate fuse from the fuse box, or flip the appropriate breaker in the circuit breaker panel. Locate your dishwasher's heating element. Open the dishwasher door and look into the tub. It is the thin, circular tube at the base of your dishwasher. It may or may not be covered. If it is covered, remove the lower dishrack, and then remove the cover.
Your heating element is going to have two metal terminals. One at each end. Each terminal reaches downwards, into the base of the dishwasher. Mentally mark the area where each terminal enters the base of the tub.
Now you need to gain access to the heating element's wiring. You can do this by first removing the lower kickplate panel of the dishwasher. There will be at least two screws (but maybe four) holding the kickplate panel in place. They are located either on the top or the bottom of the panel. If the screws are located on the top, you may need to open the dishwasher door in order to gain access to them. Close the door to remove the panel, though.
Now look into the lower access area that you have just uncovered. Pinpoint the area where the heating element terminals extend through the base of the dishwasher. They will each have a wire connected to it. Label each of the wires so that you will be able to properly reconnect them later. Now you can pull the wires off the terminals.
Each wire is connected to a terminal using a slip-on connector. Grasp the connector and pull on it firmly.
DO NOT pull on the wire itself. Pull only from the connector. You may decide you need to use a pair of needle nosed pliers to help you.
Both terminals are secured in place with a lock nut. You can use a crescent wrench or a pair of pliers to losen, and then remove each lock nut. Reach into the dishwasher and lift the element out. Discard it. Situate your new heating element in place of the old one. Slip the terminals through the holes in the base of the dishwasher. Replace each of the lock nuts. Use a crescent wrench or a pair of pliers to tighten them in place. Now reattach each of the wires - remember, you labeled them earlier so you'd know which one leads to which terminal. Put the lower kickplate panel back in place. If you removed a heating element cover, replace it now. Replace the lower dishrack, and close the dishwasher door. Restore power to your dishwasher.
Posted on Jan 22, 2011
mastermaid
  • 502 Answers
SOURCE: were do i get the service manuals with the F codes
Find the manual here for download.
Posted on Mar 02, 2011
We just replaced the heat element still no heat any ideas
Contact asko... did you check the power going to the heating element. Or the control panel. If the unit doesn't know to work it won't I would check everything form the heating unit back
Sep 03, 2014 | Asko TL751 Electric Dryer
The water will not heat up. I found the heating element in the back of the tub, removed it and applied power to it and it heated up. What is the next thing that needs to be checked
I had same problem,checked heater element was good (27 ohms).I then removed
top cover and inspected connections all look good. then I lifted control circuit board and found soldered connection for heater relay was melted.I need a new control board.
Jun 03, 2011 | Asko W6221 Front Load Washer
Dryer working fine, but no heat, clothes not drying
not knowing what kind of dryer hard to help you out.. if it is a standard dryer most of time back panel can be removed and access gained to heater and thermostat ... you want to gain access to the heater area and unplug unit ... taking a multi meter check the heater by removing 2 power wires and checking contuinity to heater... should read through heater and if your meter has a tone on the ohms reading should beep at you.. check the limit/thermost the same way by removing wires to it and testing.. prior to doing all this make sure the vent pipe is clear all the way through and that you actually have correct voltage to unit.. even though unit comes on it will run off 120 volts ,but the heating element requires 220-245 volts to operate... test power at the back of dryer and make sure across the power cord you actually have full power...good luck to you
Jan 27, 2011 | Dryers
My ASKO D3100 dishwasher has no hot water
Well the heating element in the dishwasher might be faulty or not working properly. To check the heating element - Locate your dishwasher's heating element. Open the dishwasher door and look into the tub. It is the thin, circular tube at the base of your dishwasher. It may or may not be covered. If it is covered, remove the lower dishrack, and then remove the cover.
DO NOT pull on the wire itself. Pull only from the connector. You may decide you need to use a pair of needle nosed pliers to help you. you need a multimeter to check the heating element....... post comments for more help or information......
Good Luck!!
Mar 27, 2010 | Asko D1776 Built-in Dishwasher
I have a asko d3120 and it's only draining water and will not start or stop draining :( what can i do?
check the float switch under the pan .. you could have water in the pan or float stuck in the up postion...
Hope it helps if NOT let me know more about your problem... and I will help
Jun 08, 2009 | Asko 24 in. D3120 Dishwasher
DEF appears on freezer door and freezes up.
deF error means that you need to defrost the unit. Leave the unit unplugged overnight and defrost completely.
Dec 06, 2008 | GE Profile 26.6 cu. ft. Side-by-Side...
Asko d3120 flashing coffee cup
Nov 18, 2008 | Asko 24 in. D3120 Dishwasher
Asko dishwasher d3120
Hi this is known as an L1 fault (Not heating) you need to check the element,thermistor,wash motor,wiring or the pcb.Failing this you need to ring asko
Mar 02, 2008 | Asko D1776 Stainless Steel Built-in...
Dishwasher fault
I got this with another dishwasher. On that one it meant the water wasn't feeding into it (tap switched off, kink in inlet tube, etc.)
Feb 16, 2007 | Asko 24 in. D3120 Dishwasher
Asko 24 in. D3450 Dishwasher Logo
64 people viewed this question
Top Asko Dishwashers Experts
Owen Barnes
John Tripp
John Tripp
Are you an Asko Dishwasher Expert? Answer questions, earn points and help others
