Question about Cell Phones
Setup and use of Model CHT913. I bought two of those wireless speakers and now I assume that I need to purchase a transmitter for the wireless speakers.
Do I need special hardware or software to run the speakers wireless?
  • 279 Answers
SOURCE: Acoustic Research Model AW871 wireless sterio speakers
Your connection between the AR transmitter and the ONKYO receiver sounds solid. I'd guess it's the wireless speakers that are the wrong point, or at least that's what I'd look at first. Doing a bit of research, I noticed a couple minor points. First, these seem prone to RF interference from other RF devices. Have to tried switching channels on them? Second, someone reported theirs would not work properly unless the speakers were turned on just before the transmitter, and turned off shortly after the transmitter. Apparently you have to hold the button on the front in for 5 seconds to turn the speakers on or off. I know that's rather basic, but it's been a few days and no one else has responded, so I figured we should start somewhere.
Posted on Aug 31, 2007
SOURCE: Wireless speakers AW872 transmitter won't power on anymore
Idhager,
I have the same set of speaker and had a similar problem. what I did was disconnent and reconnect the transceiver (sort of a reboot) and then powered everthing back up and that solved my problem.
Hope this helps
Posted on Dec 23, 2008
  • 133 Answers
SOURCE: panasonic BT100 & sh-fx67 kit surround sound not working
make sure you have speakers A and B on, sometimes that is the problem
Posted on Jan 11, 2009
  • 10 Answers
SOURCE: Connecting rear Wireless Speakers on Panasonic Home Theatre Kit
Hi
Just push and hold the fast forward button on your receiver and push the button number 3 on your remote simultanously
your unit cames in pairing mode a P appear in the display
after, goes to your wireless receiver and push the reset button on the back
normally after that the unit must connect with your receiver
Posted on Jan 19, 2009
SOURCE: USB Wireless transmitter
the wireless transmitter use the same frequency as your wireless network and there should b a conflict. there is a way to change the frequency on the usb transmitter. once you do that, you should be ok.
Posted on Apr 26, 2009
I have the philips mcm530 micro system and want to tune in a wireless speaker to the system so I can take the speaker outside. Is that possible?
The philips only receives bt audio it doesn't transmit them. You need a wireless system that includes a receiver and transmitter. The transmitter needs to be able to be connected to the speaker outputs of your philips system. Since I don't know what country you live in it is difficult to recommend anything as what is available in one area may not be available in another
Sep 01, 2016 | Philips Audio Players & Recorders
Scpt950k wireless speakers don't work
there may be some loose connections or connections may get lost inside the speakers or it may blown due to high voltage so check that
Jun 30, 2008 | Panasonic Home Theater System System
Aug 27, 2007 | Audio Players & Recorders
Just purchased SBHS100AE-K rear speakers to connect to my SC-BT100. I want to connect them wired rather than purchase the wireless transmitter, but I can't figure out how to connect the wired rear speakers...
This unit is not as flexible as traditional receivers are as far as speakers are concerned. Speakers are labeled and *must* be connected to the correct speaker terminals.
Upon reading the manual - it is quite apparent that the only provisions for rear surround speaker connections is <i>only</i> via the optional wireless transmitter / receiver hardware. The optional digital transmitter is connected via a proprietary plug on the rear of the SC-BT100. The optional receiver amplifies the received signal and passes it to the connected surround speakers. I would bet that there are no provisions for amplifying a surround L and R speaker channel inside the SC-BT100, and that it only provides a low level (like a "tape out") or un-amplified signal to the transmitter plug. Even if you were to manage to get the surround speaker connections made up there - you would not be able to hear anything from them - as there is no amplifier. The amplifier is contained in the wireless receiver, and is largely why it requires a connection to house current.
Unfortunately, I doubt you'll find a way to listen the surround channel audio from the SC-BT100 without the optional transmitter / receiver and the integrated amplifier.
You can review the manual like I did here:
http://service.us.panasonic.com/OPERMANPDF/SCBT100.PDF
I hope this answered your question.
Jun 11, 2010 | Panasonic SC-BT100 Theater System
Transmitter on wireless speakers will not hold a signal
if most repair shops cannot fix it, and it has been discontinued, then it would probably be a good idea to buy another set of wireless speakers. you might wanna try looking at reviews for different ones on the internet. CNET, youtube, and other places are good places to look for some
Feb 21, 2010 | Electronics - Others
Element Electronics Wireless speakers (model#EWOS1) do not work.
I have the same exact problem!!! HELP!!! If you found out how to fix this, please please please let me know!!
divawoman1@yahoo.com
Feb 23, 2009 | Electronics - Others
Idhager,
Hope this helps
Dec 23, 2008 | Acoustic Research 900MHz Wireless Stereo...
Cylinder Like Sharper Image Indoor/Outdoor Wireless Speakers
ask google or you tube or go to car toys they can help. good luck
May 18, 2017 | Sharper Image SR277 Speaker
Bought a Shift wireless indoor/outdoor speaker from Office Depot & enclosed AC adaptor Model RGD48120120 plug is too big to fit in the plug hold on the speaker unit
if it packaged with the speaker, then its office depots fault. i would replace it with another before the warrenty is out of date.
Oct 24, 2008 | Audio Players & Recorders
WHO HAS THE ANSWER THE MANUFACTURE DOESN'T
I see this one on their site, and it has a 7V DC input.
Is that what you're looking for?
Hope that fixed ya...
Geno
Mar 26, 2008 | Audio Players & Recorders
Cell Phones Logo
21 people viewed this question
Top Cell Phones Experts
William Alequin
Are you a Cell Phone Expert? Answer questions, earn points and help others
