Question about Kodak EasyShare DX7630 Digital Camera
Firmware upgrade kodak easyshare dx7630 - Kodak EasyShare DX7630 Digital Camera
jackboy
  • 2985 Answers
SOURCE: Kodak EasyShare DX7630 Camera
Check the ASA setting - read up the manual
Posted on Jul 19, 2008
tjjfitz
  • 8 Answers
SOURCE: Camera battery clip
Well, I got the latch and spring back into my DX7630, and so far (half an hour after) so good.
To do this, I had a replacement latch from U.S. Camera ($10 total, latch plus shipping and handling) and the original spring on hand. I took all of the eight screws holding the camera body together. I also pulled off the "rubber" hand grip on the front of the camera. I'm not sure if that was necessary or not, but in doing it I broke off one of the "claws" that secure the grip.
Then I turned the camera so the battery door was on top, opened the door, and gently pried the camera body halves apart. I used "square" wooden toothpicks to hold the body apart so I could get at the latch area. (The battery was not in the camera during all this work.)
There are two small slots in the camera body where the latch is held and pivots. The latch pivots can be slipped into those slots if the toothpicks have the body wedged open widely enough.
The hard part of the assembly is getting that latch spring properly mounted. The spring fits over the rod of the latch. The spring wire has two ends: one is shorter. The shorter-end goes behind the latch on the memory card side. The longer-end makes the job difficult. It must be held so that the spring is under tension while the battery side latch pivot is slipped into its slot, then the memory card side latch pivot is slipped into its slot. The longer spring-end presses against the camera body.
The latch and spring only flew away into the darkness of this room once during the effort, and that happened because I tested the latch a few times before closing the camera body. The body halves should be closed before doing any latch testing.
I put all the screws back into the camera snapped the rubber hand grip back in, put in a battery and a memory card, and at this writing, all seems to be working as designed. Hooray!
Posted on Oct 21, 2008
  • 44 Answers
SOURCE: dx7630 kodak easyshare
the 5-way switch breaks it's solder connections on several Kodak models. if you have a soldering iron with a fine tip and are comfortable working on small soldering joints it is possible to repair the joystick (there are 10 solder connections on a 1/4 inch square switch, 3 on two sides and 2 on the other two sides)
Posted on Nov 16, 2008
  • 126 Answers
SOURCE: Kodak Easyshare DX7630 screen is black and won't take anymore pic
your image sensor is bad it will have to be replaced by a camera technician .
Posted on Jun 03, 2009
reitann
  • 214 Answers
SOURCE: Kodak cd40 has wrong firmware. How can I fix this?
Try patching the firmware of your camera , get the update at www.kodak.com/go/downloads
Posted on Dec 23, 2009
How do I upload pictures from my Easyshare dx7630 to my Macbook Pro iphoto 09
Upgrade your Mac Os to Mac OS X 10.6.2,then it gives you a good result
Sep 09, 2010 | Kodak EasyShare DX7630 Digital Camera
I have an EasyShare DX7630 that will not accept my reader cards. It keeps saying they need formatting and then will not format. Any ideas?
Have you used the cards in this camera before?
So me cameras cannot handle bigger cards unless there was a firmware upgrade.
If the cards worked before, try to format the cards in the computer and then in the camera.
MAKE SURE to format the cards in the camera before taking any photos.
Jul 18, 2009 | Kodak EasyShare DX6490 Digital Camera
Grey cradle that surrounds the joystick is jammed?
Have you found a solution to this? My camera has the same problem.
Jun 09, 2009 | Kodak EasyShare DX7630 Digital Camera
Jun 03, 2009 | Kodak EasyShare DX7630 Digital Camera
Kodak dx7630
turn the lens slightly towards the way it is supposed to retract.
Sep 25, 2008 | Kodak EasyShare DX7630 Digital Camera
Jul 18, 2008 | Kodak EasyShare DX7630 Digital Camera
Kodak dx7630
Check your manual - if it says nothing in the manual then assume no. Kodak may help id you ask.
Aug 05, 2007 | Kodak EasyShare DX7630 Digital Camera
Kodak easyshare DX7630
X Ray machine would not harm the device. What Hi temp means I do not know- discuss it with the Kodak Support site.
Jun 21, 2007 | Kodak EasyShare DX7630 Digital Camera
Kodak EasyShare DX7630 Digital Camera Logo
Top Kodak Cameras Experts
Tony
Are you a Kodak Camera Expert? Answer questions, earn points and help others
