Question about Water Heaters
Can I rotate the water heater 90 degrees and install or will it not operate in my rv?
  • 3 Answers
As long as cold water is routed to cold inlet and hot is the outlet, and have access to gas valve then yes
Posted on Feb 25, 2014
5 Suggested Answers
  • 659 Answers
SOURCE: Hot Water Heater in 1991 Pace Arrow RV is not working
If you look on the outside of the RV, you will find the vent for the water heater behind and access door. There usually is a drain plug and valve located as well. Generally they will be tucked away under the kitchen sink area with internal access as well. You will need to find where the valve that shuts the water off to the unit is and turn it on. Most times the water heater is either electric or propane. But sometimes they are only propane. Once your find the access door, you will know where the water heater is. You can also contact Fleetwood who makes the Pace Arrow to see if they have any information on your unit. Usually your unit info or trim number will be located on a little plaque right by the entrance to the RV. You will need this when you contact them. Hope this helps.
Posted on Mar 31, 2009
motor1258
  • 6674 Answers
SOURCE: I have a atwood GEH-9EXT six gal. dual
Thing to remember is the cold line at bottom fitting is your feed line in to the tank, then heated water comes out the top line and fitting. Basically what you need to remember is that you want any valve wide open at lower fitting (cold) and also at any top fitting or shut off ,so hot can come out as required. Any taps in between those 2 lines need to be in off position. There are a few different ways to install the by-pass, so I can't tell which one you have without a picture or description of where they are, and style of valves, such as simple shut offs, or directional valves etc. If you can include a picture, great but a detailed description may do it.
Posted on Feb 25, 2011
  • 5245 Answers
SOURCE: Newly installed Hott Rod in 6 gal RV water heater only heats to lukewarm. Has been on for 12 hours. Outside temperature is 60 degrees
Hott rod is 120Volt AC.
Check voltage supply for undervoltage, or reversed polarity, or tripped breaker.
Check that electric thermostat is set to 120 degrees.
Rotate thermostat temperature adjustment back and forth and see if you can hear water heater working.
Thermostats can be bad, or stick.
Check the ECO red reset button is not tripped out.
If tank was not full of water before power was applied, the element will instantly burn out.
Use continuity tester across bare element screws to see if element is good. Or use multimeter and test across bare element screws shows 29 ohm for 6 gallon, 18 ohms for 10 gallon.
More resources at Hott Rod, for troubleshoot and contact.
http://www.hottrod.net/hott_rod_troubleshooting.asp
Posted on Nov 01, 2012
  • 5245 Answers
SOURCE: Have 75 gallon gas water heater. Can I run 90 PVC off top power vent without vertical PVC first? Have Richmond unit.
1) I believe you can immediately elbow the PVC pipe.
There is a limit for how many elbows can be used between blower and termination, and limit is determined by diameter of PVC pipe.
2) Copy following link for venting resources and typical Rheem and Richmond power vent manuals, and diameter-elbow pdf from Bradford White.
http://waterheatertimer.org/How-to-troubleshoot-gas-water-heater.html#venting
3) Richmond is Rheem. Product manual will show specifications for venting.
Product warranty is voided if installation does not follow specifications shown in manual.
Posted on Feb 20, 2013
Where is the hot-water output shut-off valve on a Bradford-White Hydro-Jet 80 ga. water heater ...and which way do you turn it?
Typically water heaters do not have a shut off valve for the out put water line, only on the cold water line above the water heater and they have a boiler drain to drain the tank. The input shut off valve can be of two types. The usual hose bib style like you would have on the outside of your home for your garden hose (remember lefty loosie, righty tighty) or you could have a gate valve of which if the handle is inline with the pipe the valve is open. You will either have to push it up or down depending on how it was installed, 90 degrees to shut it off.
I hope this is of some help.
Nov 04, 2016 | Water Water Heaters
Where is the bypass on the water heater on a 2000 Georgie Boy Pursuit RV?
Bypass kits don't usually come installed from the manufacturer. If your heater has one, it will be located on the water inlet and outlet. You can get bypass kits from RV parts stores.
Mar 19, 2015 | Water Water Heaters
My water is too hot eemax sp 90
Water heaters have thermostats so that you cand adjust the temperature of the water. Temperatures above 120 degrees can pose a scald hazard.
Jul 15, 2014 | Water Heaters
Feb 20, 2013 | Rheem Richmond 75 Gal Natural Gas 6 Year...
Oct 31, 2012 | Camco Hott Rod RV/Camper 6 Gallon Water...
Excess Hit Water Bill from Solar/electric Hot Water System
10-30-12
Cost calculations for recirculation system vary widely.
These systems cost more, and they cause higher operation cost of water heater.
1) When pump is OFF, then hot water is no longer leaving the tank.
Most recirculation systems have choice of timer for setting specific times of operation, or thermostatic operation that activates pump when sensor detects temperature less than 90 degrees
BUT...
2) Condition of plumbing is suspect here because you are not receiving fully 90 degree hot water from the recirculation system.?.
Bad single-handle faucet cartridge, or bad recirculation check valve, are causes of crossover. Clean recirculation check valve with white vinegar. Replace worn faucet cartridge.
Test for crossover.
http://waterheatertimer.org/Crossover.html
3) There are other suspects, such as water leak.
Drips, broken pipe, bad TP valve.
Turn off all taps and put ear against pipe to listen for running water.
http://waterheatertimer.org/How-to-troubleshoot-electric-problems-with-water-heater.html#listen
4) High costs: Lifting single-handle faucet in middle will immediately cause cold water to enter tank. Even if no hot arrives at tap, because the cartridge is drawing both hot and cold in equal amounts when handle is lifted in middle.
Today it is more efficient to install dual-handle faucets so tank is not receiving constant dose of cold water when single-handle faucet is not used correctly or tediously.
http://waterheatertimer.org/9-ways-to-save-with-water-heater.html
Oct 29, 2012 | Water Heaters
What does DSI mean when referring to RV water heaters?
D.S.I. = Direct Spark Ignition. You would have a 12 volt switch inside RV, that when turned to ON, will ignite water heater automatically, provided ignition module and rest of components are there, or come with new water heater. Otherwise you would have to go outside with a lighter/matches or whatever and manually start the water heater.
Oct 22, 2010 | RTO Atwood DSI-RV Water Heater-6 Gallon
Does the atwood electronic Rv water heater have a temperature setting? Brad
NO. ITS FACTORY PRESET. YOU CAN INSTALL ANOTHER HOTTER T-STAT OR BUY A KIT THAT YOU CAN INSTALL TO ADJUST THE TEMP.
Oct 18, 2009 | RTO Atwood DSI-RV Water Heater-6 Gallon
Water Heaters Logo
18 people viewed this question
Top Water Heaters Experts
Donni Steen
Gil Shultz
Are you a Water Heater Expert? Answer questions, earn points and help others
