Question about DeLonghi Perfecta ESAM5500 Fully Automatic Bean to Cup Coffee Maker
Diffuserclogged diffuser clogged
Is the rainbow rainmate like a essential oil diffuser?
If the instructions don't say so, I would not do it. Oils can clog air purifiers that are designed for such pruposes.
Jan 17, 2015 | Rainbow Air Purifiers
Low pressure
Low pressure indicates a problem on the input side of the pump. Possibilities include: broken or clogged impeller, broken diffuser, clogged pipes or valve on pump input side. If pump is full of water, most likely impeller is problem.
May 12, 2011 | Sta Rite 1 HP Sta-Rite Pump: 1.5" in/out,...
Top half of fridge not cooling
You could have a frosted up air diffuser between the freezer and the refrigerator section that is causing your cooling problem. If this air passage is clogged, it can prevent the refrigerator from cooling properly.
Jan 26, 2011 | Refrigerators
Bag was changed, but vaccum cleaner will not reset itself
You could have a clogged hose, afterfilter, or worn/broken control valve assembly.
1. To check the filter, press the tab located at the bottom of the tool holder/air diffuser. See photo below. Lift air diffuser. There may or not be a filter here. If there is, remove it, then check machine operation.
2. Disconnect hose form canister. Turn on machine. Place hand over intake. If the machine turns off during this process, the control valve assembly is broken or worn out. Replacement needs to be done at an authorized Aerus franchise service center.
3. To check the hose, disconnect both ends. Drop a marble or similar size item in one end and allow to roll out the other. If it doesn't, the hose is clogged. This will cause the machine to shut off as well.
Sep 11, 2010 | Electrolux Epic 6500 Vacuum
How to replace light globe in Chateau Grange rangehood
I have a 600mm Chateau range hood with the same problem. To access the globe chamber, you need to first remove the plastic diffuser from the underside of the rangehood. Located at one end of the diffuser will be a small slot approx 10 mm long. Insert a small flat blade screwdriver into this slot and carefully depress the plastic tongue of the diffuser by gently pushing the head of the screwdriver away from the diffuser. As the tongue disengages from the frame you should be able to grasp the edge of the diffuser and pull it away from the frame. Once the diffuser has been removed from the frame, you will be able to change the globe.
To reinstall the diffuser, insert the plain end of the diffuser into the frame of the the rangehood (above the globe) and gently push the clip end back to its flush position.
Nov 17, 2009 | Kitchen Ranges
My Livia 90 dosn't build pressure
Clean out the shower screen and the diffuser under the grouphead, turn the head on without the screen and diffuser, if water flows strongly then the problem was in the diffuser and screen, if you have no flow, then the line to the haed is clogged.
Jun 18, 2009 | Pasquini Livia 90 Espresso Machine
Doe's not defrost into lower drain pan.
Your drain line is clogged, just clean it out and you should be fine
Jun 26, 2017 | Kenmore Refrigerators
Whirlpool side by side refrigerator not cooling
it might have a defrost problem check timer heaters and defrost limiter if it has a build up of ice in the freezer on back panel if not try turning the control for the food caompartment to let more cold into the food compartment
Aug 29, 2007 | Refrigerators
DeLonghi Perfecta ESAM5500 Fully Automatic Bean to Cup Coffee Maker Logo
Top DeLonghi Coffee Makers & Espresso Machines Experts
Henry  Thomas
Henry Thomas
Shehu Pro
Shehu Pro
Are you a DeLonghi Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
