Question about Panasonic Ladies Wet/Dry Epilator in Pink
Panasonic epilator Not charging
Suggest me the best epilators that one can buy?
Although, there are a variety of options of epilator that are available. But for providing you with the top options of epilator. Here are some of the options that you can look for -'
1. The Braun Silk-Epil 7 7681.
2. Panasonic ES-ED90.
You must look for this options when you are planning to purchase a new epilator. Also, you can have a look at the reviews before purchasing it from Best Epilator.
May 03, 2017 | The Health & Beauty
Braun Troubleshooting
The rechargeable battery inside unit has reached the end of its usefulness and needs to be replaced.
Nov 23, 2013 | Braun SE 7181 WD Silk Epil 7 Epilator...
How to clean a remington EP6010 epilator?
AFTER EACH USE
CLEANING THE EPILATION HEAD Ensure the epilator is turned off and disconnected from the mains. Press the head release button/s and open the head assembly. (Diagram G) Turn the head assembly upside down. Using your thumbs, push the small sides together and push the epilation head upwards. This releases the curved epilation head. Brush the accumulated hair from the tweezers by turning the barrel manually. NOTE: The body of the epilator is not washable. Do not submerge in water.
TO REMOVE RESIDUE To remove residue from the stainless steel tweezers, dampen a swab with alcohol. Gently run the swab over the tweezers until the residue has been removed.
Online Manual: http://uk.remington-europe.com/pdf/ep6010_user_manual.pdf
Feb 28, 2011 | Remington Health & Beauty
Hi! I have the Panasonic ES2045 Epilator but I lost the charger. Where can I buy it? It says to use adaptor RE7-37 only. Thanks!
I just checked eBay and there are about 40 of them, varies on costs, but there were some that also had free shipping, go for it!! Take care.... Guy
Sep 10, 2010 | Panasonic ES2045 Epilator
Satinelle HP6409 Epilator: I have epilator philips satinelle ice with europia...
The epilator is universal voltage so the power lead should not matter. You could get an adaptor to convert from Europe to US and that would do fine.
Otherwise, try http://www.support.philips.com/support/service/onlineStore.jsp?userCountry=us&userLanguage=en
May 16, 2010 | Philips Satinelle HP6409 Epilator
Shaver wet/dry ES2045 - need a manual
I have a manual. You have to make sure it is in the charge position when it charges. Mine is totally charged, but only the epilator hehad works, the shave head does not. I think there is a problem with it.
Feb 16, 2009 | Panasonic ES2045 Epilator
Panasonic Ladies Wet/Dry Epilator in Pink Logo
13 people viewed this question
Top Panasonic Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Panasonic Audio Player and Recorder Expert? Answer questions, earn points and help others
