Question about GAMEVIL Zenonia
Quick Bar Troubles
I was playing Zenonia 5 and suddenly all of my quick slots were gone, a bit of time passed and they returned. Now they went away again and I don't know what to do. I tried putting things in the quick slot but the game thinks that there is something in the quick slot already. It tried switching out the things in the quick slot and restarting the game but it didn't work. The next thing I thought of would be to reinstall the game but I also do not want to lose all of my progress. Any suggestions?
Angle grinder eats carbon brushes
Yes, the rock dust is what's destroying your brushes and armatures. It gets sucked into the rear vent slots and gets to those parts and eats them away quickly. I don't know of any vacuum systems make by Makita but there are some companies that make them for their systems. Blastrac is one that comes to mind but they can be real expensive systems. I don't know of any grinders with sealed brush/armature systems, they have too much heat to disipate. To make your Makita grinders last longer make sure you are cutting with the side of the blade that directs the dust away from the case and try to have a strong airflow blowing the dust away from the grinder to minimize the dust taken in at the back of the grinder.
Jul 15, 2010 | Makita 9005B 5" Electric Angle Grinder
Program Play of Title 32 Prohibited
NO. it will most likely be either a limitation of the player or a faulty/incompatible disc.
A very quick test is to play the disc in another slot and see if the problem moves with the Disc.
Mar 17, 2010 | Televison & Video
Hp Pavilion dv2601tx Quick play not working
uninstall with revo uninstaller and install 3.2 back
Oct 25, 2009 | HP Pavilion dv9000z Notebook
Hp laptop, dv6000 series..volume button gone pink!
Usually when the volume button is pink(orangey) it means that the volume has been muted. Make sure both on the quick play bar right of the power button and in the task bar, that the volume has not been set to mute. Also check the audio drivers and make sure the drivers haven't been corrupt and reinstall or re-download new updated drivers in needed.
Aug 27, 2009 | HP Pavilion dv6000z Notebook
Wii Remote Turning Funtion Doesn't Work on Mario Kart
Your wii sensor bar probably went out, replace it. They sell wireless ones at wal-mart for $20. If you want to make absolute sure that the bar is broken, take a video camera and take a quick video of the wii bar while it's connected and the wii is on. If you see four little blue lights on each side then you're wii bar is ok, if any are gone it should be replaced. The fact that all the buttons are still working means that your wii is still communicating with remote using bluetooth, but since it's not sensing any motion, it probably means that the problem is sensor bar related.
Aug 25, 2009 | Nintendo Wii Console
My oil is burning will i pass inspection in pa
On the 2.0 l engines, oil burning is common, and quick easy solution I've found is to run "5 minute oil flush" available at any parts store. follow the directions and 8-10 times the carbon between the piston rings and sludge that build up in the valvetrain (a common problem for all OHC Dodge engines) goes away. be sure to use a high quality filter and a high mileage formula 10w30 motor oil like Valvoline or Pennzoil.
Jul 09, 2009 | 1995 Dodge Neon
Mail QuickView not working
go to keyword
type in : Tool bar settings.
on the right you will see: Tool bar Quick view.
check box that says display Quick view when signed on.
save that setting.
this worked for me.
Mar 22, 2009 | Computers & Internet
Can't get access to all songs of the game
faljose,
You could get all the songs by just just playing the career unlocking them one by one or you could go to the Main menu and choose 'Options' then choose 'cheats' then choose 'Enter cheat' then with the guitar press the colored buttons in this order :
blue, blue, red, green, green, blue, blue, yellow.
when done a message will appear telling you that you unlocked up all songs in Quick Play. Now that you did so you'll have noticed the 'same as before' emtpy slots for cheats. You actually have to scroll down the list of the emtpy cheats until you find 'Unlock all Quick Play Song' and if will say "Off" under it, simply select that to be 'On' and just head back to the main menu and go play Quick Play with every single song in the game. Now you can Rock.
randy320sgi
Jan 12, 2009 | Buck Guitar Hero World Tour for for Xbox...
Very Loud Noise When I am playing Back my Video
could be feed back make sure microphone is as far away from speakers as possible
Jul 17, 2008 | Logitech Webcam
Video Game Consoles & Games Logo
23 people viewed this question
Top GAMEVIL Video Game Consoles & Games Experts
James Wishart
Are you a GAMEVIL Video Game Console and Game Expert? Answer questions, earn points and help others
