Question about Dryers
Dryer timer runs but the dryer wont start - Dryers
  • 108 Answers
Hi sarah take top off press start button and give drum a push clockwise if it goes then its the motor capacitor it will only go untill it stops to go outherway if goes change cap
Posted on Feb 14, 2014
  • 1122 Answers
SOURCE: power button wont start dryer
check the door switch,also you can remove the back panel and check the little white main fuse on the blower box-mike
Posted on Mar 21, 2009
jumptrout51
  • 3361 Answers
SOURCE: Maytag dryer timer keeps running
Your dryers timer contacts have fused to gether.
The only repair is to replace the timer.
Posted on Mar 25, 2009
localwonder
  • 6784 Answers
SOURCE: dryer wont start. starter switch is new and timer will run when the door is closed
HI. if the timer is running, and the wiring harness is in good condition, this will confirm motor failure. I would advise to test the operational value of the door switch as well but if the door switch is working, this will only lead to motor failure.
Posted on May 22, 2009
  • 2333 Answers
SOURCE: Dryer wont run, lights work, timer clicks
what is the model number?there are a couple of things you can check with the little info you sent,check the door switch,push the paddle in and out ,if it doesn't click it's bad,check to see if the belt broke,on some dryers there is a switch down near the pulley,if the belt brakes the dryer won't run,one more thing if your dryer hasn't had a clean out in a long time or if your clothes have been taking a long time to dry check the thermal fuse located on top of the blower wheel housing,if the lint filter is on top the fuse is in the back,take off the vent line,remove the back panel and check the fuse located to the right and down near the bottom of the duct that the lint filter slides into,if the filter is inside then the fuse is in the front the fuse is on top and to the right of the blower wheel housing,also you should clean out the duct that the filter slides into,blow out the vent line,check outside and make sure the flapper is not blocked with anything and vac out the inside of the dryer where the motor is,you need to do this once a year anyway,if you still need help send the model number and let me know what you find,unplug the dryer to clean it and when working on it and remove one of the wires when using your meter
Posted on Mar 17, 2010
Jahn27
  • 1554 Answers
SOURCE: I have a Kenmore gas dryer model 97591220. wont
Disconnect power to the dryer and remove the screws attaching the console rear panel to the console and pull the panel off.
Inspect the wires connected to the timer and ensure a snug fit connection. Clean the connectors and terminals then reseat it several times to ward off dirt within the connectors.
Reconnect power to the dryer and start it; replace the timer (part number 3398195 ) if the dryer still won't stay running. Unplug the dryer and pull the timer knob off the console. Remove the screws securing the timer to the bracket and remove it. Secure the new timer in place then disconnect the wires from the old timer one at a time and connect it to the corresponding terminal on the new timer.
Push the timer back into position on the console and secure the console rear panel in place.
Posted on Apr 14, 2010
Apr 14, 2010 | Dryers
Dryer wont start. starter switch is new and timer will run when the door is closed
May 22, 2009 | Kenmore 73952 Gas Dryer
Wont start after running all night without shutting off
Bad timer, When the machine just runs and runs and runs, or runs for a very short time and shows that it ran the whole cycle but the clothes are still wet then the timer has gone bad and needs to be replaced. IF you go to repairclinic.com. You can order the timer from there or your local appliance repair company. They are around 40 dollars and you can replace the part fairly easy
May 20, 2009 | Dryers
My whirlpool dryer wont start.
check the door switch and also the push to start button. Timers will advance even if the unit is not on
Mar 30, 2009 | Dryers
Mar 25, 2009 | Dryers
Dryer wont run
defectvie timer,,,onthejob
Dec 07, 2008 | Whirlpool LER7646E Dryer
Eastate gas dryer 4-5 years old.
if burner does not reignite and glow bar is lighting up suspect the black coils on valve bad
Oct 24, 2008 | Estate TGDS740JQ Gas Dryer
Dryer wont run
I imagine this has got an electronic timer ? If so then it's probably the timer board that's faulty.
Sep 15, 2007 | Roper REX4634KQ Electric Dryer
Dryer won't stop running
the dryer wont stop running only when open door will it start a fire?
Sep 14, 2007 | Kenmore 62802 Electric Dryer
Dryers Logo
37 people viewed this question
Top Dryers Experts
