Question about Sony Cybershot DSCW370 Digital Camera
Dscw370 battery clip is broken
The plastic clip that holds the battery in place is broken
How is the actuator rod connected?
usually has a plastic/nylon swing clip that goes over the rod and clips into place holding the end of the actuator rod into the lock, these are easily broken, get new ones from your local dealer if broken/missing
May 03, 2014 | 2003 Pontiac Sunfire
Looking for a replacement for the folding mechanism of a p&t vibe 1
Hi
I was wondering what side clip you are missing???
It has been ages since you have posted, not sure if still searching???
Nov 30, 2012 | Regal Lager Phil & Teds Vibe Jogger
Replace fuel filter
For safety, remove relay # 8 in the fuse box, and disconnect battery. Take the little plastic cap off the pressure relief valve at the filter. Push the pin up to relief the pressure. Use a pair of pliers to remove the clips at both hoses, some gas will come ou,t, taking note which hose goes to which fitting, because the filter is directional. Remove the plastic strap holding the filter and remove. Chances are the plastic strap might be broken, if not, you're lucky. If so, use a zip tie to hold in place.
Jan 02, 2011 | 2003 Chevrolet TrailBlazer
How do you change a gas filter on a 2004 Trail Blazer
Dec 24, 2010 | 2004 Chevrolet TrailBlazer
The orange plastic clip that holds in the battery broke.
use some tape, or put a piece of something on top of the battery, when you close the battery door and latch it, it should hold the battery in place. That orange clip just holds the battery low enough that it comes in contact with the terminals at the bottom of the compartment.
Hope this helps
Jer
Jan 16, 2010 | Pentax Optio T20 Digital Camera
The space bar has come off how do i fix it
Often with keyboard keys, they have several clips that hold the keyin place. Try gently prying the key off again, and see if there is any placewhere the plastic might have broken, or if there were other clips thatweren't quite in place. If the key is broken, though, you can either deal with it as it is, orprobably order a new key.
Jan 07, 2010 | Sony VAIO PCG-K23 Notebook
Someone tried to open rear driver side-door while it was being unlocked and now it will not open
You will need to remove door panel, to see if the plastic clip(s) holding metal level are (is) broken and not in place. You will need to visit pick a part to purchase the entire piece.... make sure all plastic clips are in place, and in good condition.
Aug 03, 2009 | 1996 Isuzu Rodeo
Nikon Cool Pix 7900 Battery door won't stay closes
There are plastic clips on the battery door and body of the camera that lock the door in place. If they are broken of the battery door the door can be changed. If the clips on the body are broken the camera as a rule is history. Replacing a camera body is not a feasible repair.
Jul 02, 2009 | Cameras
Need to replace a headlight assembly for a 2006 Subaru Outback.
No, you just remove the radiator grill and the side marker light and the headlight housing bolts and it comes out. Not a real hard job and is Real straight forward. Good luck and have a good day.
Mar 27, 2009 | 2006 Subaru Outback
Sandisk clip
Call Sandisk at 1-866-726-3475, or get a broken player off of eBay for low cost and just swap out clips. Now, there is a plastic piece that holds the clip into place - that plastic piece didn't break off, did it? If so, you must replace the entire player.
Jun 07, 2008 | SanDisk Sansa Clip MP3 Player
Sony Cybershot DSCW370 Digital Camera Logo
11 people viewed this question
Top Sony Cameras Experts
james laughton
james laughton
JonSnell Electronic
JonSnell Electronic
Are you a Sony Camera Expert? Answer questions, earn points and help others
