Question about Samsung WF419AA Front Load Washer / Dryer
Nf error it stops and nf error what does nf stand for
Nf code and donnot continue to next cycle
Samsung Washer Error Code NF (Fixed ...
www.appliancerepairlesson.com/.../samsung-washer-error-code-nf-fixed/
Jan 11, 2014 - What does the error code NF mean on a Samsung washer? ... You can set the washer to any cycle and test each solenoid for proper voltage. ... Next would be to check the screens on the back where the water hoses connect. ..... Hi, you don'thave any power to the water valve wires when it should be filling?
Dec 15, 2015 | Frigidaire Affinity ATF7000E Front Load...
What does error NF mean in front loading machine?
NF stands for No Flow. Check to see that your valves are open and that water is getting to your washer. If you have water to the washer, you my have a problem with the selenoid valves that control the water flow.
Oct 04, 2014 | Samsung WF328AA Front Load Washer
The NF light comes on
The nF error code stands for "No Fill."
If you have just installed your washer and it will not fill, or the display shows nF, check the following:
  • Make sure the door to the unit is tightly closed.
  • Make sure that both the hot and cold water lines are connected (cold to the cold and hot to the hot)
    • Note: If you do not have a hot water source, you can hook up the cold water source to the cold input on the back of the washer and another cold water source to the hot input on the back of the washer (but NEVER a hot water source to the cold water input on the back of the washer).
Oct 14, 2012 | Samsung WF337AA Front Load Washer
What the heck does nd stand for? Why does it sometimes say nf? Model MAH5500BWW
Hello & Welcome to FixYa
ND error in your Maytag Front Load washer indicates no drain issue. To start with check the drain hose for any clogs and try cleaning it, then check restriction in drain pump assembly or loose wire at the pump.
NF error in your Maytag is displayed due to no fill condition, when the washer tries to fill but is unable to, nf is displayed. Please check the water inlet valve for any clogs and obstructions, you can also clean the inlet to solve the issue. Please get back to me if you have any other questions.
Kevin
May 12, 2011 | Maytag Neptune MAH5500B Front Load Washer
I have an error code that says nf
NF error in your washer is displayed due to no fill condition, when the washer tries to fill but is unable to nf is displayed. Please check the water inlet valve for any clogs and obstructions, you can also clean the inlet to solve the issue. Please get back to me if you have any other questions.
Kevin
Mar 06, 2011 | Samsung WF337AA Front Load Washer
The code nf keeps coming up what does that stand for
NF(No Fill) code indicates that the washer is not getting enough water supply. Check if wwater supply is turned On and water is coming through the pipe. Then the fill valave can be clogged. t can become clogged with sediment over time
Stop the water supply and then remove the hose and then check for any clogs and if they are fine then in your case most probably your fill valve must have gone bad for this problem.Replacing it must solve the issue.
Jan 14, 2011 | Samsung WF337AA Front Load Washer
Nf error code
The NF error codes stands for no fill. This is usually caused by hard water deposits in the fill valve screen. Youl will need to disconnect the water lines to the back of the washer and clean then out thoroughly. This should solve you problem, please rate my response if it helps you:)
Dec 02, 2010 | Kenmore Elite 45986 Front Load Washer
My washer always stops and says NF which im assuming stands for not finsished why is it doing that
NF error for the FAV6800AW machine an many others = a no water fill error. The Control Board has not sensed from the pressure switch the correct water fill level after X amount of time.
Do you hear water flowing into the washer for the Cold or Hot water fill cycle? If not you could have clogged water inlet valve screens. I would shut off the Hot/Cold water supplies to the machine and pull the supply hoses off the back of the machine and inspect the water supply inlet screens. They look like this;
You could have a failed water valve solenoid. Do you hear the water valve solenoids go clunk at the start of the water fill cycle?
I assume your machine is a FAV6800AW or FAV9800AW here are some links for reference if you want to troubleshoot the issue; The Service Manual for reference. Sears Parts Direct for reference.
Post back if you have questions
Oct 14, 2009 | Maytag Neptune FAV6800AW Top Load Washer
Maytag neptune TL
The machine needs to cut you a break;
“”i have a maytag neptune TL and there are several things wrong with it...1. I can't wash small loads it will stop at the spin cycle and flash dc””
This issue is a clutch issue see this post to DIY the repair.
“”it will wash fine on regular loads until it comes to spin cycle again and it will stop and flash nf””
This one is a little confusing the “nf” error is a No water fill error code. Check these two post for support regarding water inlet restriction or valve not opening properly.
nf post nf post 2
“”my fabric softener dispenser will not let the softener out neither will the bleach dispenser””
See this fabric softer post for support. The fabric softener dispenser may be clogged or the water dispenser valves feeding both dispensers may not be operating properly. The Service Manual on page 16 “Board Output Test” will give you support to turn on the Fabric Softener Valve and Bleach valve. See if you hear the valves operate in Service Mode”
My method may seem a little confusion for viewing water flow to the dispensers. This issue could be associated to the nf error you are receiving, restricted water flow (inlet screen clog) or cold water valve not working properly.
Post back for any questions or possible support I can offer. I’m an owner like you not a repair person but I’m very comfortable working on this machine. Rich
Jun 17, 2009 | Maytag Neptune FAV6800AW Top Load Washer
Samsung WF419AA Front Load Washer / Dryer Logo
19 people viewed this question
Top Samsung Washing Machines Experts
Jaime Hernandez
shaun taylor
Are you a Samsung Washing Machine Expert? Answer questions, earn points and help others
