Question about Galaxy Radios DX55HP 10 Meter Radio
How big of a fuse should my dx 55 hp have - Galaxy Radios DX55HP 10 Meter Radio
  • 1,162 Answers
If your rig runs the rated wattage of 12 watts PEP on ssb then a 4 amp fuse is plenty. If you run 4 watts 2 amps. They sell the fuses in Radio Shack 5 for $2.
Posted on Mar 26, 2014
My galaxy dx 55 hp is getting hot at right rear on am modulation causing modulation distortion
take it to a tech , if you have to ask then you are not able to work on it . It is definatly an internal problem.
Dec 01, 2012 | Ranger Radio Communications
What is 55-200mm?
That's the focal range of a zoom lens. Unlike a single focal-length lens (or a "prime" lens) a zoom lens lets you adjust the focal range. "55-200mm" specifies the lens's focal range from 55mm at the low end to 200mm at the long end.
You can read a general description of zoom lenses at
http://en.wikipedia.org/wiki/Zoom_lens
Nikon current has two different 55-200mm lenses:
http://www.nikonusa.com/Nikon-Products/Product/Camera-Lenses/
2156/AF-S-DX-Zoom-NIKKOR-55-200mm-f%252F4-5.6G-ED.html
and
If you're asking about the L110, it has a permanently-affixed lens and will not use either of the above lenses.
Aug 11, 2011 | Nikon Coolpix L110 Digital Camera
I have a broken 18-55 mm lens . The plastic bayonet type rim that connects to the camera base has snapped off, can it be fixed easily without sending back to Nikon.
You'll need at least a small screwdriver and a soldering iron. If you feel up to it, you can order the part and do it yourself.
The part depends on which variant of the 18-5mm lens you have.
18-55 3.5-5.6 G ED DX
http://uscamera.com/1c999-357.htm
AF- S 18-55 3.5-5.6 G II ED DX:
http://uscamera.com/1c999-488.htm
Apr 25, 2011 | Nikon D60 Digital Camera
My Nikon 18-55 mm lens turns easy when zooming in, but is stiff when zooming out. There is no roughness in the movement that would suggest dirt.
hi there,
the zoom-rubber might have been loosen, so it moved too easy while you use it
you can fix it by contacting nikon representative technical support
thanks
Dec 12, 2010 | Nikon D60 + AF-S DX VR NIKKOR 18-55 mm...
On a new Nikon 18-55mm AF-S DX Zoom - Nikkor f/3.5-5.6 lens and a Nikon 55-200 mm AF-S DX Zoom f/4.56 lens is VR also included and standard?
Nikon currently lists two 18-55 AF-S DX and two 55-200 AF-S DX lenses. One in each pair has vibration reduction, the other does not. The ones with VR in the name have it, otherwise it doesn't.
VR isn't exactly an option. If it wasn't built into the lens initially, you can't add it later. A lens either has it or it doesn't, though if a lens has VR it can be switched off.
Aug 30, 2010 | Nikon Cameras
Nikon 55-200 is locked on 55 and won't extend to zoom. Worked the last time I used it, and was on the camera when it stopped.Nikon 55-200 is locked on 55 and won't extend to zoom. Worked the last time I...
Assuming that you've already tried a good firm hand on the zoom ring then all you can realistically try is to give the lens a few good firm slaps onto a desk to try and free up whatever has gone wrong. Brute force usually sorts them out, but it is "kill or cure". This lens lacks a macro mode, so this is not the usual simple case of adjusting a lens control and then slapping your forehead with embarrassment...
The lens is otherwise uneconomic to repair as it's one of the cheaply built kit lenses and so you can easily obtain another for less than the cost of repairs.
Jan 26, 2010 | Nikon Zoom-Nikkor 55-200mm f/4-5.6G ED...
Nikon lens 55-200 nikon dx vr
So does mine, that is the VR releasing, it is normal.
Jun 24, 2009 | Nikon Zoom-Nikkor 55-200mm f/4-5.6G IF-ED...
My Nikon D300 doesn't recognize the 55-200 AF-S DX as a cpu lens.
you call the computer expert to your home and then tell him this thing. he will give you the full idea about it. from my side it is the camera body.
May 23, 2008 | Nikon Nikkor 55-200mm f/4.5-5.6 G AF-S...
Galaxy Radios DX55HP 10 Meter Radio Logo
71 people viewed this question
Top Galaxy Radios Radio Communications Experts
Steve
Steve
Are you a Galaxy Radios Radio Communication Expert? Answer questions, earn points and help others
