Question about DreamGear TYPE 6 2.4 GHz Wireless Controller for PS3
Maximo Wireless 2.4 GHz Controller wont work - DreamGear TYPE 6 2.4 GHz Wireless Controller for PS3
I bought a generic ps3 controller and im doing everything to connect it to my ps3 but it wont work....
In order to Sync a PS3 controller to the system you must plug the controller in using the charging cable, it will then register then controller and it will work.
I hope this helped!
May 16, 2011 | Sony Generic 2.4 GHz Wireless Controller...
I bought my ps3 320 from hsn it came with an additional wireless controller not a sony controller it has a usb flash wireless to plug into a usb port how can i you it on my win vista home p laptop as a...
You can find Windows drivers for your PS3 controller HERE. Read and follow the instructions available. These drivers even support wireless bluetooth connectivity which you can setup if your laptop has bluetooth. The developer of the driver includes a full tutorial on installing and configuring the PS3 controller.
Follow THIS link for installation instructions.
Follow THIS link for configuration instructions.
Jan 26, 2011 | Sony Generic 2.4 GHz Wireless Controller...
Nerf ps2 controller
no may ne u need config it manually
Jun 25, 2010 | Pelican PL-2050 XBOX EDGE 2.4 GHZ WIRELESS...
I have a old xbox system and my wireless controllers by pelican brand pl-2050 one will not link up to the xbox what to do!!
Check to verify that your batteries are installed correctly.
- Check to verify that the power is on. Check to verify that the signal LED is blinking
If this does not solve the problem, do the following:
1. Make sure your Xbox is turned off.
2. Remove the battery lid and place 2 AA batteries into the Blade 2.4 Street Wireless Controller. Make sure the batteries are inserted as shown in the battery compartment.
3. Insert the receiver into your Xbox controller slot of your choice and power up the controller FIRST, then your Xbox.
4. Press the Connect button on the receiver once. Your signal LED light will begin to flash slowly.
5. Press the Back button on your controller. This will program the receiver to connect to the controller each time it is uses.
6. Turn on your Xbox and insert a game.
Aug 06, 2009 | Pelican PL-2050 XBOX EDGE 2.4 GHZ WIRELESS...
Wireless controller wont WORK!!!
mad catz controllers have to be the crappiest controllers ever they are toruble its probably broken.
Jun 16, 2009 | Nintendo GameCube Console
It wont connect to da f**king playstation its rekin my head
make sure the ps3 and controller r on the same setting i had the same prob with my game cube control i may be wrong because i dont have a ps3
Jun 06, 2009 | DreamGear TYPE 6 2.4 GHz Wireless...
Just recieved a type 6 dreamgear wireless controller,doesn't work
1. Ask gifter/seller if it ever worked. If not, return it. What connect do you hit?
Apr 07, 2009 | DreamGear TYPE 6 2.4 GHz Wireless...
Remote contoller mode light flashing controller not working?
Hold down the connect button on the receiver and the mode button on the controller at the same time for approximately 10 seconds. This is a 2.4 GHz wireless transmitter and receiver (connection is somewhat like your WIFI router and laptop computer) and they need to reconnect sometimes.
Dec 31, 2008 | Logitech Cordless Action Controller for...
Controllers
make sure the channel is the same on the wireless controller and receiver. wireless phones can also be at the same ghz and cause a problem
Aug 04, 2008 | Nintendo GameCube Console
DreamGear TYPE 6 2.4 GHz Wireless Controller  for PS3 Logo
35 people viewed this question
Top DreamGear Video Game Consoles & Games Experts
James Wishart
Are you a DreamGear Video Game Console and Game Expert? Answer questions, earn points and help others
