Question about Singer Sewing Machines
Singer vertical shaft
How to replace the top bevel gear. Vertical shaft is not dropping after gear is loosened.
SOURCE: Replacing broken gears on Singer Touch & Sew Model 648
Remove the plastic faceplate from the front of the machine. There is a Singer logo button that you will have to pop out to release it, and then the lever nobs to get around to get it off. You can then access the allen screw on the top gear.
Remove all the set screws on both the top and bottom gears on the vertical shaft. Put them in a safe place.
The vertical shaft sits directly below the horizontal shaft, but there is some space between them and wiggle room to do the following. If the shaft does not slip down easily, use a small diameter rod or screwdriver to gently tap the vertical shaft downward until the top gear slips off the end. Remove the gear.
Posted on Dec 17, 2011
kent581
  • 87 Answers
SOURCE: Singer zig-zag 437
loosen the screw on the larger of the two feed gears (not bevel gears). Retigten so that the feed teeth start to rise right when the needle starts to rise and fall right when the needle starts to go into the fabric. Make the setting the same. i.e. when the feed teeth start to rise, how high is the needle (2mm, 3mm, etc.)? set the feed timing so the teeth rise and fall with the needle at the same height going in and coming out, this assures that the fabric only feeds when the needle is out of the fabric.
kent
Posted on Mar 18, 2009
  • 980 Answers
SOURCE: I need to replace a vertical top shaft gear on a
Email me and I will type up full instructions including timing drivewithken@blueyonder.co.uk remind me of your model. Ken
Posted on Jan 09, 2010
SOURCE: need to replace the top vertical gear on singer 636
it would be better to take the machine to a sewing machine shop & let
them repair it, they have the tool needed for the job
Posted on May 01, 2012
SOURCE: Where can I find a vertical shaft gear? My bobbin
try this link for parts
http://www.sewingpartsonline.com/singer-457-stylist-sewing-machine-parts.aspx
Posted on Dec 14, 2012
How do I change the top gear on a singer fashion mate 368? I can't figure out how to get to the top vertical shaft gear to take it off.
These are repairs best left to a professional. Parts are not available to you unless you buy them used online, then its not the right part... Let a trained professional make these repairs and adjustments. Self repairs can result in more damage.
Cheers,
Embroidery Services
San Diego, CA
Sep 10, 2017 | Singer Sewing Machines
How to replace top vertical gear on a Singer 413?
Owner's Manual available on eBay, but you may be better with a Service Manual.
This show an Internet search for 413 diagrams:
Google
Mar 29, 2015 | Singer 4166 Sewing Machine
Singer sewing machine repair manual
Depending on model my first guess would be the gear from upper main shaft (horizontal) or the gear from Vertical shaft is broken
May 11, 2014 | Singer Sewing Machines
How to replace vertical gear on Touch and Sew 648
Singer upper vertical gears are mated to their main shaft gears at factory.
Jan 14, 2014 | Sewing Machines
Need to replace the top vertical gear on singer 636
Apr 30, 2012 | Singer Sewing Machines
Singer zig-zag 437
kent
Mar 18, 2009 | Singer 5050 Mechanical Sewing Machine
Mar 09, 2009 | Singer Sewing Machines
I have an old Singer 478 and I can't get the needle to grab the bobber thread. Is there a special trick for this one?
When you turn the handwheel, does the hook move? If not the top gear on the vertical shaft is stripped and needs to be replaced.
Jan 31, 2009 | Singer Drop-In Bobbin 758B-28BH Mechanical...
Sewing Machines Logo
Top Singer Sewing Machines Experts
Tally Girl
Tally Girl
mystery_soul
Are you a Singer Sewing Machine Expert? Answer questions, earn points and help others
