Question about Price Pfister Plumbing
Cloudy water in bathroom faucet
Model 42 YP Series. This is a new faucet. I have 3 of these and all of them have same problem. Other faucets in house have no such issue. Water is cloudy because of air bubbles and clears out in 30 seconds or so, I would appreciate your help in fixing this issue.
    New Friend:
  • 169 Answers
Usually, there is a filter-like mesh at the mouth of the faucet for producing the air bubbles. You may try to turn the mouth part using a suitable plier to see if it can be taken out and you may do something about the mesh.
Posted on Feb 14, 2014
  • 203 Answers
SOURCE: Two handled faucet not working
could be 1 or 2 things either an air lock or a valve is blocked
Posted on Nov 22, 2008
  • 39 Answers
SOURCE: Rusty water comes out of cold water faucet
Rust is usually a sign of galvanized pipe mixed with copper pipe incorrectly.Could be the pipe nipple used for the tub spout connection to the valve.You could change it to a brass nipple might be the problem
Posted on Jun 24, 2010
  • 1082 Answers
SOURCE: after installing a grohe faucet
It air bubbles in the water giving the appearance of cloudy.
It would seem that the aerator in the new faucet is particularly efficient.
If you take a glass of "cloudy" water and let it stand for a few mins, you should find it clears up nicely as the air slowly bleeds out through the top.
Posted on Dec 12, 2010
packrat1948
  • 528 Answers
SOURCE: We have a new Price
If you have full pressure on the cold water side and low pressure on the hot side then you well need to remove and clean or replace the cartridge for the hot side. If you have low water pressure on both sides try removing the aerator and cleaning it.
If you need to replace the cartridge on the hot side do both sides while you at it.
Whenever you work on any faucet before you turn the water on remove the aerator and run the water for a few seconds then replace the aerator.
Posted on Mar 07, 2011
robocop
  • 90 Answers
SOURCE: moen 2 handle bathroom sink
Try going to their web site and selecting consumer support. Usually the bathroom sink faucets, you can unscrew the handle with a Phillips screw-driver and then twist the body of the faucet off. Then there will be a nut to screw off, to remove the inner "guts". It sounds like the rubber seal is worn out on the inner faucet assembly. If so, then all you would have to do, is to replace the rubber seal. I hope that this helps you out. If not, then I would contact the company and see about a replacement faucet, depending on your warranty! If worse comes to worse, then I would call in a professional plumber, to assist in fixing it! Good luck my friend.
Posted on Jul 06, 2011
We have a new Price Pfister 49 Series bathroom faucet set with two handles. Even with the hot water tap open full the water just dribbles out
Mar 07, 2011 | Price Pfister Two Handle Lavatory Faucet -...
After installing a grohe faucet my water is cloudy most of the time. The cold water will eventually clear up after it runs awhile, the hot water, hardly. I never had cloudy water before installing the new...
Dec 12, 2010 | Grohe Plumbing
Just purchased the Price Pfister 42-YP. The hot water has limited water - just a trickle. What can i do to adjust?
Hi, David pressuming the water flow was good before you put in this new tap, then other than a problem with the tap! have you checked if you have an isolater valve on the pipe work under the unit, if so check that it is fully opened?
Thanks Paul.
Aug 31, 2010 | Price Pfister 42-YP0E Ashfield Single...
Moen bathroom wash basin faucet leak, how to repair , we have a new house, 45 days old, bathroom faucet leaks, how do you replace the washer or whatever it takes to stop leak, there are no apparent ways to...
No warrantee on new home?
No instructions left for ALL fixtures,water heater,heating system etc that where installed???
Go to a plumbing supply store,and see if they can help. Not Home Depot
Mar 24, 2010 | Moen 7437 Chateau Single Hole Kitchen...
We recently installed a new bathroom faucet and it
check the strainer where the water comes out of your faucet it may be clogged or if the faucet has a cartridge in it it may be clogged and you will have to dis assemble the faucet to clean it usually the strainer is the problem and it should unscrew by hand
Mar 11, 2010 | Plumbing
Very low pressure when turn on the hot water faucet in sink
Shut off the water supply and open your faucets, and apply air pressure (min. 30psi) to dislodge any blockage in the pipes.
Oct 23, 2009 | Plumbing
Nov 18, 2008 | Plumbing
Plumbing Logo
150 people viewed this question
Top Price Pfister Plumbing Experts
bwbconstruct
Level 1 Expert
john h
TED
Level 1 Expert
Are you a Price Pfister Plumbing Expert? Answer questions, earn points and help others
