Question about Jandy LT250N-L Laars LT Heater - Natural Gas-Low Nox, 250K BTU
How do you change the manifold pressure from 3 to 9 in on the Jandy LT 250
Want to use with propane gas.
    Renaissance:
    An user who is expert in 3 categories / brands.
  • Jandy Master
  • 1,448 Answers
You need a professional
Posted on Dec 01, 2014
4 Suggested Answers
SOURCE: My Jandy LT 400k heater shuts off when the fan
heater comes on for about 2 minutes then service light comes on and so does the ags light
Posted on Jan 27, 2010
  • 33 Answers
SOURCE: I have a Jandy LT low NOx heater, about 3 years
Problem with the thermocoupler its not producing a minivolt of 250 plus that is needed to open the main gas valve
http://www.laarsman.co.uk
Miles
Posted on Jun 05, 2010
adamh294
  • 310 Answers
SOURCE: bought a used jandy lite
Before you undertake this project, you should know that you will not just need the orfices. You will also need a different gas valve.
gas valve part number is : r0096900 for propane ($300.00+)
orfice part number: L0032900 (set of 2) ($3.00)
As you can see, this gas valve is not cheap. The lite2 is a very reliable heater, but chances are that if its been out of service, yo will also have to replace the thermocouple which will be another $75-$100.
Its very unlikely that anyone at your local pool supply store will have the gas valve in stock. They will definately not have the orfice in stock. Your best bet if you still want to proceed is to purchase these parts off the internet. Just google Jandy pool parts. then goto a few sites, search for the part numbers i gave you, and check for the best price.
Posted on Aug 10, 2011
Jandy LX400P-L Heater
ur blower may not be producing enough air flow to constantly keep the air switch closed
May 07, 2013 | Jandy Pool & Spa
Jandy LXi gas heater error message "ignition control failed
if ignitor is glowing try changing position of the shutter 1/2 to 3/4 open should lite
Dec 22, 2012 | Jandy Laars LX Pool Heater / 250,000 BTU /...
The pilot light is lit but the heater will not fire into heating mode when the thermostat dial is turned up. I was told to bypass the pressure switch to check and see if that was the problem. The heater...
Contact Jandy and find a local service center to come out and repair the heater under warranty.
Try: http://www.zodiacpoolsystems.com/Support.aspx
If you want to search for service providers, enter your zip code on the right and then click the find servicers button.
John
Aug 29, 2011 | Jandy Legacy 250 Propane Gas Pool Heater...
On the jandy 400 lt its displaying the AGS code... what does that mean?
Per your owner's manual:
AGS
(automatic gas shut-down)
1. Oscillating pump pressure.
1. Clean filter or identify and repair cause of pump oscillation.
2. Low gas supply pressure.
2. Identify and repair incorrect supply pipe size or pipe line blockage.
Refer to qualified service personnel.
3. No flame at burners.
3. No flame at burners. 3. Identify and correct loose wiring connections, or problems with igniter, flame sensor, gas valve, or ignition control.
For more info the manual is here:
http://www.jandy-downloads.com/pdfs/LXandLT_H02140B.pdf
John
May 03, 2011 | Jandy Laars Lt 400,000 Btu Heater
Jandy pool heater wont stay on the blower kicks on the ignitor glows it lights and then 4 seconds later goes out and i get ignition fault code. please help me out
most likely problem is incorrect gas pressure or a clog in the gas line. If this is a propane heater (you did not specify) then the owners manual is wrong on the gas pressure, you should call the manufacture to get the correct settings for propane.
Either way you need an experienced gas person to come set the gas properly.
Also I had serious problems until I had the gas company install a regulator right next to the heater (so the entire under ground gas line was high pressure). I use to have a regulator next to my house so low pressure fed all the way from my house to the heater (200ft) and this caused serious problems like this.
I also had a regulator break on me one year. It basically stopped putting out the right pressure.
Lastly the flame sensor could simply be bad. If you are still having this problem I can explain how to remove and test the flame sensor. It is easy to test and easy to replace.
Apr 04, 2010 | Jandy Laars Lt 400,000 Btu Heater
I'm trying to convert a Jandy 250 BTU propaine pool heater to natural gas and I need the parts
go to the pool store or supply house or call the manufacture if anyone there speaks good english. and tell them what you got and that you need the propane orfices and the propane gas valve and regulator for your pool heater. you'll need to change the orfices, gas valve and regulator.
Aug 06, 2009 | Jandy Heating & Cooling
Tappan Range Model TGF351ESJ Nat. Gas to Propane
Yes you can convert the range
2. Provide an adequate gas supply.
This unit is pre-set to operate on 4" natural gas manifold
pressure. Aconvertible pressure regulator is connected to the
manifold and MUST be connected inseries with the gas supply
line. If the LP/Propane conversion kit has been used, follow
instructions provided with the kit for converting the pressure
regulator to LP/Propane use. The LP kit can be found on the
back side of the range (some models).
I yours does not have the kit on back go to sears to get one.
Good Luck
Please rate FixYa!
Dec 19, 2008 | Jenn-Air JGR8855BDS Gas Kitchen Range
Dean deep fryer
need to change from natural to propain sr42 g
Oct 08, 2007 | Frymaster Dean SR42G Deep Fryer
Jandy LT250N-L Laars LT Heater - Natural Gas-Low Nox, 250K BTU Logo
53 people viewed this question
Top Jandy Pool & Spa Experts
David Spradling
David Spradling
Pj Kiley
Pj Kiley
Level 1 Expert
Bill Jordan
Are you a Jandy Pool and Spa Expert? Answer questions, earn points and help others
