Question about Yamaha 115HP 130HP "U" Series Outboard Motor Shop/Service/Repair Manual
Yamaha outboard repair manuals - Yamaha 115HP 130HP "U" Series Outboard Motor Shop/Service/Repair Manual
A sucking noise by the carbuerators on a 2000 100hp yamaha outboard
Are any vacuum lines missing or broken cracked etc? Are all unused vacuum ports capped?
Jun 24, 2016 | Seloc Yamaha Mercury Mariner Outboards...
2002 yamaha 150 outboard wont shut off with key
Broken wire in loom,white wire,bad connection in loom plug,if it switches off with kill switch,then it points to ign switch
Mar 15, 2014 | Clymer Marine Maintenance and Repair...
Yamaha 40 outboard stuck at full throttle won't idle
Sounds like accelerator butterflies are stuck,you probably need a good mechanic to sort this one out.try operate accelerator linkage on carburettors by hand but do not force, take off black air cleaner and spray penetrating oil onto butterfly shafts
Jan 27, 2014 | Clymer Marine Maintenance and Repair...
Yamaha 250vx cards outboard lost rpm wont go above 4200 rpm
clean and balance carbs , compressions all above 100psi ? sparks on all cyls ?
Sep 29, 2013 | Clymer Marine Maintenance and Repair...
50 hp yamaha outboard mid 1990's
2 stroke ?? choking up do you mean ? what oil make and mixture ratio ?
May 11, 2013 | Yamaha 40N/50N 40 and 50 HP Outboard Motor...
Yamaha 115HP 130HP "U" Series Outboard Motor Shop/Service/Repair Manual Logo
69 people viewed this question
Top Yamaha Photography Experts
Tony
Are you a Yamaha Photography Expert? Answer questions, earn points and help others
