Question about Tetra Bubbling LED Half Moon Aquarium Kit
How to set up the 1 gal bubbling led kit
Instructions Setting up aquarium
NO NETWORK SETTING SHOW IN LCD PANEL IN BROTHER 8370DN AFTER RESET THE PF KIT 1 MESSAGE.
Hi gurjit: try this..
Reconnect the LAN cable to the hub to verify
that the cable and network connections are good. If possible, try connecting the
machine to a different port on your hub using a different cable. If the connections
are good, the lower LED of the back panel of the machine will be green.
sends me the result.
Nov 26, 2014 | Brother MFC-8370DN Laser Multifunction...
Bubbles not coming out of all holes in air strips
Follow the tub back and see if it is plugged where the air should come out.
www.marineland.com/Products/aquarium-parts.asp
Jul 01, 2014 | Marineland Tetra Whisper 60/100 Air Pump...
No bubbles from fluval q1
can't get airpod air pump to blow bubbles
Mar 27, 2013 | Hagen Fluval Q1 Aquarium Air Pump
How to fix fluval led
on this tank the lights are built into the filter pump housing , if they go bad it might be possible to retrofit a new sealed light bar into the same space , but you will need to have previous knowledge of electronics and specify L.E.D. lights as they don't work like regular light bulbs but require a special kind of power or will be damaged if hooked to wrong type of power I suppose its possible to use batterys but id have no idea how long that would work
Jan 29, 2013 | Fluval LED Edge Aquarium 6-Gallon Aquarium...
Aquarium water is cloudy
This can happen and will generally clear with time, if you are concerned do a water change. I find that this treatment is more hassle than its worth, if you have a suitable filter seachem denitrate is a good alternative, or he aquarium pure balls.
Sep 21, 2012 | Tetra 16176 3.38 Oz Easy Balance Water...
I have a 40 gal. freshwater planted aquarium. I would like to know if the Fluval CO2 88 will be large enough for my aquarium. Most plants I use are mosses, crypts, water sprite wendi (sp) & several...
I am no expert with CO2 but i would say that for the amount of plants you have going by the picture vs the amount of fish you shouldnt really need the CO2 at all.
One way to naturally increase CO2 is to run less or no bubbles in the day while the plants are using the CO2 and producing Oxygen and then run bubbles over night to clear out the CO2 the plants produce at night to okeep it safe for the fish.
Sep 04, 2012 | Fish
Need instructions for a spoungebob square pants aquarium kit. i need to know how to fit the filter
What kind of filter is it (does it hang on the back of the aquarium, does it fit inside the aquarium, or is it intended to go under the gravel?)?
Feb 14, 2011 | Penn Spongebob Squarepants Aquarium Kit
Tetra Bubbling LED Half Moon Aquarium Kit Logo
82 people viewed this question
Top Tetra Fish Experts
Jerry Kramer
Jerry Kramer
Steve Dearman
Level 1 Expert
Are you a Tetra Fish Expert? Answer questions, earn points and help others
