Question about Samsung DV317AEG Electric Dryer
SamsungDV50F9A7E(G) has rectangular error code not in manual. Dryer does not turn off just the bell indicates cycle completed then retangle of dashes comes on and dryer stays on.
3 Suggested Answers
SOURCE: have a retangle showing as the dryer ends it dry
I have the same problem with my dryer. I noticed this rectangle that showed up on time dry and there wasn't any code that matched this in the manual. I called samsung and they told me to flip the breaker and see if that helps. I have not tried another load, but I hope that fixed it.
Posted on Dec 21, 2009
SOURCE: My Samsung Dryer (DV218AEB/XAA) Error code HE
invalid heating temp when running. call for service.
Posted on Sep 18, 2010
Error code Ad
Hello Rachael, thank you for your inquiry!
Typically error code AD indicates that the Auto Dry option has been selected. Typically when using no heat in any Auto Dry cycle will result in long drying times and/or wet loads at the end of cycle. I would suggest selecting another option or resetting your dryer. You may either unplug it or flip the household breaker off for approximately ten minutes. Turn your dryer on then select a normal cycle. Your appliance should resume normal operations. If this problem persists, your dryer may possibly have a faulty heating element, blower assembly or a communication problem with the control panel. This is not a normal DIY job. You may want to connect with a local servicer to determine the exact diagnosis. I hope this helps explain the error code you are receiving.
Nov 28, 2013 | Frigidaire GLEQ2152ES Electric Dryer
My washer test runs great I hear every thing working correctly but when I do laundry it doesn't spin. How can I fix this issue. I am getting an error code f7 e1
I know how frustrating it can be when appliances do not function properly.
This particular washer has a test that we can run to see any errors. This can be confusing on this model.
I am including a document below that will describe how to view the old error codes. Use the section that starts with Activating the service diagnostic modes. You can start with the cycle selector knob at any position.
  1. Be sure the washer is in standby mode (plugged in with all indicators off).
  2. Perform the following sequence of movement using the cycle selector knob. NOTE: After reset, sequence "a" through "e" must be completed within 6 seconds. When it tells you to rotate the cycle selector knob, it means 1 click, not a full turn. Once you have completed the cycle knob turns reset and "a" through "e", turn the cycle selector 1 click clockwise from the position it is already in. This is the fault code display mode. Then press the start button. Each time you turn the cycle selector knob 1 click clockwise after pressing start will show you an error code. Note: this washer stores 4 codes if any. The error codes on this washer are displayed in this format: F5 E3, F7 E1, etc. There is an error code chart in the image below.
If there are no error codes stored, I recommend that you start from the beginning (step 1 above) and then run the Automatic test mode. If this unit detects a problem, it will display the error at the end of this test.
I hope this is helpful. Post back your results.
Click here for image
Nov 12, 2012 | Whirlpool Cabrio 7.0 Cu. Ft. Super...
Error code F44 on sears kenmore elite oasis electric dryer.Doesn't seem to be cycling completely.
The F44 error code on this type of dryer indicates a blower motor control board failure. Since it happens only occasionally, then you could have a loose wiring connection or a partial obstruction in the blower housing. Complete details of the troubleshooting for this error code are included in this link of a previous answer: What does the fault code F44 indicate on my Kenmore Elite Oasis dryer?
I recommend that you unplug the dryer and check the wire harness connections if you are confident that you can safely access the internal dryer components. If you find a loose connection, then tightening it or plugging the harness securely into the connection will likely correct this problem.
May 08, 2010 | Kenmore Elite HE4 Electric Dryer
Whirlpool Dryer works on 1 cycle
Activate the diagnostic test mode to determine the functionality of the console buttons and the console electronics as a whole.
Diagnostic Mode Activation Procedure
  1. Make sure the machine is plugged and in standby mode. That is, no indicator light is on.
  2. Press the following keypad sequence within five seconds: More Time>Less Time>More Time>Less Time. All of the indicator lights should light up and "88" is displayed.
  3. Turn the cycle selector knob one complete rotation. When the knob points to a cycle, the corresponding indicator light should turn off and the machine should beep. Only a beep is heard when the knob points at the large spaces between the Automatic and Manual cycle groups.
  4. A beep should be heard when a button is pressed and the indicator light corresponding to it should turn off.
Any failure on the above tests indicates a faulty console board. Please let me know the result of the test for further troubleshooting and repair guide.
Jan 22, 2010 | Dryers
Have a retangle showing as the dryer ends it dry cycle. Dryer will dry but the rectangle shows up about 1 minute before dryer ends it's cycle.
Dec 03, 2009 | Samsung Dryers
My LG dryer shuts itself off during the normal cycle and a dotted
OK, here's what it sounds like to me: The line going around the display should only be seen if you selected "Wrinkel Care" function for that cycle (and with the freshen up cycle, I beleive). With that option in use, after the dryer shuts off, if you do not open the door or turn off power to the dryer the dryer will display the moving rectangular segments and every 6 minutes the dryer will turn itself on and tumble for 10 seconds with no heat (to keep clothes fluffed up and prevent wrinkles from setting in) and will continue this cycle for up to three hours. The "Freshen Up" is the steam cycle used to remove wrinkles from 1 to 5 garments, like things that were all wrinkled up in your suitcase. Try drying with a normal or permanent press cycle, or a timed cycle. If you have additional questions or concerns, let me know.
Dec 06, 2008 | LG WM2077CW Laundry XL Front Load...
Won't turn off
ck to see if a wrinkle guard button is present or some such control if option is turned on most dryers will come on shut off like that for up to 12 hrs before completely shutting off this helps reduce wrinkles in clothes not removed from dryer when dry cycle completes ..if you can find owners manual consult if for a better explantion
Oct 25, 2008 | Whirlpool GEW9250 Electric Dryer
Kenmore Elite quiet pak 9 dryer
Error message E1 indicates the temperature thermistor has failed.
Jun 22, 2008 | Kenmore Elite HE4 Electric Dryer
Samsung DV317AEG Electric Dryer Logo
24 people viewed this question
Top Samsung Dryers Experts
Tim Whalen
Dan Webster
Dan Webster
Are you a Samsung Dryer Expert? Answer questions, earn points and help others
