Question about Microwave Ovens
Missing threaded part the upper mounting bolts screw into, where can I buy one.
    Champion:
  • 203 Answers
Try e spares on the internet they do most parts
Posted on Feb 17, 2014
3 Suggested Answers
woobie dog
  • 1273 Answers
SOURCE: mounting bolts firgidaire FMV156DC
Where I live there is a bolt shop....really. If you can, find such a shop, and take your other bolt with you and 'match 'em up'.
Another possibility is that Lowe's carries speciality bolts. They're in cabinets/drawers in the hardware section, not hanging on the wall. H/Depot probably has a similar arrangement.
Yet another possibility (and I think it's your best shot) is that, if you can match just the threads, you can buy a piece of all-thread (it's just a piece of steel rod, with the threads running the full length of the rod). Thread your nut onto the all-thread just past where you are going to make your cut, and cut with a hack saw. (You run the nut down on the rod so that, after you make your cut, you unscrew the nut over your fresh cut to straighten out the threads deformed by cutting). Total cost for all-thread and nuts......around $5. Use your existing bolt as a pattern for the new bolt, and leave evough extra to accomidate the nut that you'll add in place of the head of the old bolt. Anyone working in any hardware department anywhere on the planet worth their salt can help you.
Best regards, --W/D--
Posted on Jul 20, 2009
ccbeaudin
  • 6 Answers
SOURCE: LG LMV1680ST no upper mounting
Look for back mounting bolts location, find your wall studs location and mount from the back
Posted on Apr 24, 2012
I removed the bolts for my Danby OTR microwave. Dmw162w-otr. The microwave does not move. Are there any other bolts or is there anything I am missing before I can remove the microwave?
In a normal installation, there is a plate that mounts to the wall and bolts come down through the cabinet. Once the bolts are removed from the cabinet above mic, the mic should hindge forward. It takes two people to handle. How ever, in some cases an installation guy will add screws into the side of the unit. So look for some screws to the right and left of mic. Good luck!
Jan 29, 2016 | Danby Microwave Ovens
The screw in the right filter area that is (approx. 12-13 inches has come loose. I have tried to put in back in place......no luck.Would it be advisable to take oven off the wall? OR, does anyone know...
Those screws screw into the support plate mounted onto the wall behind the unit. would guess it is not lining up for some reason or the hole is stripped out. Would have to remove the unit from the wall to inspect the mounting plate and make sure the hole are not stripped out. Lookt at the end of the bolt. do the threads look clean and not pulled or stripped???
Sep 29, 2017 | Sharp R-1870 Convection/Microwave Oven
Apr 23, 2012 | LG LMV1680ST Microwave Oven
Hello, I need a microwave mounting bolt that is at least 6 inches long. Can you help?
You should be able to buy bolts that long, depending on the diameter, but for mounting a microwave I would suggest you go for 5/16' (8 mm). If you cannot get bolts, use threaded rod and cut it to the length you need, using washers and nuts on both ends to create your long bolts. Most better hardware stores will stock the threaded rods but long bolts may be stocked by fastener merchants only. Good luck and please rate this answer.
May 19, 2011 | Microwave Ovens
Trying to remove an old GE Spacemaker microwave JVM140-001 and can't figure out how to detach it. I do not have a manual or installation instructions.
On some of these old GE Spacemaker models, there are two long horizontal bolts at the top (R&L corners), accessed behind the upper grill. Remove the grill (four tiny screws), take out the two bolts (flat screw heads) that attach to the rear plate, and your microwave will come right down and out, providing you've removed the three mounting bolts on the top.
Dec 11, 2010 | General Electric Microwave Oven
Mounting bolts firgidaire FMV156DC
Jul 20, 2009 | Frigidaire FMV156DC Microwave Oven
What size are t top mounting screws on the GE JVM1350 spacesave
You may be looking for the philips flat head 1/4 x 28 tpi (threads per inch) threaded bolt that is about 4" long. The tip of the bolt does not have threads, which aids in locating the threaded hole in the top of the microwave:
General Electric's part number for their OTR microwave cabinet mounting screw is WB01X10180 (or AP3205964 or 942461 as listed on some repair parts sites).
A set of three is GE's p/n WB01X10125 (or AP3185225 or 910236 as listed on some repair parts sites).
This flathead screw is used on most Advantium Speedcook microwave ovens such as the SCA2001BSS03 or SCA2000FWW03 or SCA2001KSS03.
Here's a picture of three screws:
Apr 05, 2009 | GE Microwave Ovens
Mounting problems
You may be looking for this Flathead 1/4 x 28 threaded bolt that is about 4" long. The tip of the bolt does not have threads, which aids in locating the threaded hole in the top of the microwave:
GE # WB01X10180 (or AP3205964 or 942461 as listed on some repair parts sites
or a set of three
GE # WB01X10125 (or AP3185225 or 910236 as listed on some repair parts sites)
Feb 03, 2009 | Microwave Ovens
Spacemaker XL1400
I found a solution for my microwave. Went to Ace and picked up some lag bolts, yellow in color (believe they said it was yellow zinc). Most common seems to be 1/4"-20, but these lag bolts had the smaller thread of 1/4"-28.
I had to go a little shorter in length because the threads don't run the entire length of the bolt. The only downside is that the top of the bolt sticks out inside the cabinet (but only about 3/16"). Well worth it so I didn't have to buy an installation kit that was in the $40-$50 range.
Dec 05, 2008 | GE JVM1650 1000 Watts Microwave Oven
How can I install this oven GH9115XE?
You may be looking for this flat head 1/4 x 28 threaded bolt that is about 4" long. The tip of the bolt does not have threads, which aids in locating the threaded holes in the top of the microwave:
GE # WB01X10180 (or AP3205964 or 942461 as listed on some repair parts sites)
or a set of three
Jan 21, 2008 | Whirlpool GH9115XE 850 Watts Convection /...
Microwave Ovens Logo
Top Microwave Ovens Experts
William Miller
William Miller
Are you a Microwave Oven Expert? Answer questions, earn points and help others
