Question about HP W2338h 23 in. LCD TV
How fix main menu show hp w2338h - HP W2338h 23 in. LCD TV
2 Suggested Answers
reyjoshua07
  • 1157 Answers
SOURCE: i have HP w2338h moniter
Hi hsaiyed,
appear. You can do different function you want for your monitor to do such as turning the menu off. Observe if the button is working properly, if it is stuck the "menu" on screen won't go away.The buttons are either on the right hand side facing you or under the panel.Buttons go bad due to improper use. If it is bad you have to replace the control panel.
Hope this helps.
Thank you for using FixYa.
Posted on Jul 21, 2011
Power button lockout is on how do I turn it off
to remove the OSD Lockout message, release the Menu button (if something was pressing against it), and press and hold the Menu button again for about 10 seconds - until the message goes away.
== see if this helps==
Feb 02, 2012 | HP W2338H Monitor
Hp w2338h has no power
Possible that the main power supply has failed . It can be due to failure of the Switch mode driver in the SMPS unit.
please remove the panel and check only if you are equipped to probe and change the shorted components.
click this link:
http://www.fixya.com/support/r5826301-working_switch_mode_power_supplies
tutorial on SMPS :
http://en.wikipedia.org/wiki/Switched-mode_power_supply
Nov 02, 2011 | HP W2338H Monitor
I have HP w2338h moniter .Its screen show menue screen again and again .
Hi hsaiyed,
Hope this helps.
Jul 21, 2011 | HP Computers & Internet
My fairly new HP W2338H monitor turns on but then goes black after one or two seconds. Do you have any advice for what the problem is or what the cost would be to fix the problem?
Fairly new? How new? If it's under warranty, you should have it replaced or fixed by HP or the store you bought it at.
You can attempt the following... unplug it... press and hold the power button for 30 seconds, repeat. Plug it back in and turn it on. This may reset it so it will stay on.
The cost of repair might be more than the cost of a replacement.
Apr 22, 2011 | HP W2338H Monitor
W2338h goes black after 2 seconds. Can I fix it myself?
If this is due to the capacitors failing, I'd advise not, unless you are competent in identifying and testing these. My advice is to take it to a reapair shop
Feb 12, 2011 | HP W2338H Monitor
My hp w2338h monitor randomly goes to sleep only when I play games. I have turned set hybernation to never in power options, updated all drivers and this still happens I have also plugged in another...
ok , we've answer that question here , vast endless times.
all old monitors before magic year 2010 even go to sleep
all by them selves to save the pathetic, CCFL tubes insid it.
so learn to use the monitors OSD screen.
push the menu button there(real button)
see that? now turn off sleep.
i will now read the manual to you.
3 seconds latter (manualsdir.com)
page 33
turn off the time and all sleep function INSIDE the monitor
amazing no? RTM still works in the year 2018...
https://www.manualslib.com/download/71500/Hp-W2338h.html
Feb 09, 2018 | HP W2338H Monitor
I have HP Monitor w2338h and I get an error message: OSD lockour
Please just hold the menu button for 10 bseconde and the OSD lock out will disappear.
If this does not work then unplug the power cord for few hours and your problem will be fixed.
Please rate me if this solution works for you
Thanks......Have a great time
Aug 13, 2010 | HP Computers & Internet
I have the HP w2338h monitor. when i listen to
Hi there , Go to your PC settings , and Try turn Screen saver off , aswell as Sleep off... it is in your PC settings.
Good luck
May 22, 2010 | HP W2338H Monitor
HP W2338h 23 in. LCD TV Logo
19 people viewed this question
Top HP Televison & Video Experts
Tony
Computer Links
vbalag
Level 1 Expert
Are you a HP Televison and Video Expert? Answer questions, earn points and help others
