Question about McTavish Water Sport
Can a paddleboard be repaired?
Fatal crack in the middle
Rca l32hd31r
In fact, the picture as a whole is displaced to lower side of the screen. It is a main digital board fault. Products powered by electricity should be serviced or repaired only by experienced professional technicians. Any attempt to service or repair the product by anyone else could result in serious injury or death. If you are not familiar with electronics, do not attempt to repair. Whether you suffer fatal electrical shock. Instead, contact the nearest service centre. Your TV need a thorough check up.
Jul 04, 2013 | Televison & Video
Do I need to wax the top of the paddleboard?
Most paddle boards are made with traction pads attached to the top of the board, these should never be waxed. Boards that do not have the traction pads should be lightly covered with a base wax.
Jan 17, 2013 | Water Sport
What does the paddle have an angle?
The elbow in a paddle provides a more powerful, effective stroke. When you're paddling, the elbow causes the paddle blade to align straight up and down as it comes alongside the paddleboard.
Taken from: http://www.rei.com/expertadvice/articles/paddleboarding.html
Emerson 37in flat screen Cracked inside out
Get what use you can, there is not a way to "fix" that--the front screen unit is called a display panel and even if it was available the part alone would cost much more than the whole set did when new, time to go shopping for a new set.
Sorry, damage to the screen unit is always fatal.
Dec 13, 2012 | Televison & Video
TCP60S30 panasonic replacement screen
The cost of the PDP or plasma display panel is fatal as it will exceed the cost of a new set (not even counting major labor to replace it and the fact they are sold exchange=crack means no core.
Fatal issue.
Apr 30, 2012 | Panasonic Televison & Video
Cracked screen
cracked screen is fatal=time for a new unit.
Apr 29, 2012 | Zenith DVB312 DVD Player
How much to get the screen repaired if busted
if lcd or plasma and screen cracked/shattered is fatal--cost of display panel is more than the price of another set.
Apr 06, 2012 | Televison & Video
Toshiba 32sl410u have 2 vertical lines on screen
Likely a shop repair but:
Either a bad board (main, or power or even a inverter board)
Worst case if Black line and thick would be the panel (screen unit) which would be fatal but is not likely if lines not black.
Apr 05, 2012 | Toshiba 32SL410U 32 LCD TV
I have 1 "12" kicker L7 and i got into a car accident. the sub works greath but the outer face has a crack in it.. its not big but i wanted to know what could i do to fix the problem
If the cone has a crack in it, that is USUALLY fatal, but you MIGHT try using the BLACK ABS plumbing glue to repair the plastic.
I don't know what you mean by the front face.
IF you mean the frame around the cone, I would grind out a groove (Vee it) over the crack and mix and fill with JB Weld. Paint to match when the material has set up and is smoothed a bit.
Nov 09, 2009 | Kicker Solo-Baric L7 S12L7 Car Subwoofer
Line down center of screen rest of screen black
no not fatal, but sick. this problem you are having sounds like you have a vertical sweep problem.. It could be the vertical output IC, the sweep power supply or a capacitor or two is bad. If you have printed circuit board soldering experience, you can try and fix this yourself, but if you do not, play it safe and call in a pro to assist you in this repair as it should not cost more then 100 bucks to repair. Good Luck
Apr 29, 2007 | Thomson 24WK25U 24" TV
Water Sport Logo
751 people viewed this question
Top McTavish Water Sport Experts
Tom Chichester
Bill Boyd
Are you a McTavish Water Sport Expert? Answer questions, earn points and help others
