Diagnostic lights 3&4 are on. Should I continue with the installation of the cd or do repairs on memory modules? help please
I share information HDD back site small jumper available so you attach 1-2 and CD back side available jumper not connect any pin. Mother board auto find it and not any issue ok.
Thanks.
TechSupportMart Computer Support
Lights 3 &4 is a memory code error and should be fixed first since the OS and all programs run in you system memory.Dell recommends removing the modules, reinstall one module, and then restart the computer. If the computer starts normally, reinstall an additional module. Continue until you have identified a faulty module or reinstalled all modules without error. Sometimes reseating them is all that is needed.
This is a link to the XPS 200 owner's Manual.
Product Support Dell US
SOURCE: Dell 670 BIOS not installed
If you are installing a new hard drive, it is possible that you have not connected the cables correctly. Check if these are seated firmly in the corresponding pins.
SOURCE: dell dimension L800CXE
Hello Wademyd,
It seems that the installation CD that you have is not a bootable CD.. must be old one.
Please down load the boot disk for windows from http://www.bootdisk.com or follow the Microsoft article link given below:
http://support.microsoft.com/?kbid=310994
Do not be intimidated by the article, although it looks big but there is very little that you need to do, rest of it is general instructions like where can you order a new CD from etc...
OR
Simple solution is to borrow Bootable Windows XP installation disk and install it using the serial Key that has been given to you.
Please let me know if that helps and please rate the solution if it helped you.. it will not cost you anything but will make a difference for me :)
All the best and kindly let me know in case you need any further assistance.
Regards,
Srinivas
SOURCE: computer will not boot
http://support.dell.com/support/topics/global.aspx/support/dsn/en/tree?journalid=6EB139500365CBA6E040AE0AB5E109D6&treeid=286725
See that link for the beginning of the Dell troubleshooting wizard for diag lights 3 & 4, it is in fact a memory subsystem error. Usually meaning the stick of memory in the first slot is bad. The wizard will walk you through this, but try removing the first stick and using the second stick in the first bay and see if it will boot. Unfortunately no recalls on RAM for this model but the good news is that your memory is cheap and if your not under your service contract you can buy a set on newegg or a similar site for about 50 bucks.
SOURCE: My Dell XPS 420 will not turn on. Power light
Hey! Nice Computer! ( At least while it was working! Specifications show some high-end hardware parts)
Steady amber light on the Power On light, means a bad power supply.
The Dell XPS 420 uses the standard ATX style of power supply found in 90% of computers out there.
(Personal computers. Not the Cray Supercomputers!)
This is Dell Support, and the User Manual - Removing and Replacing Parts - part of the manual,
http://support.dell.com/support/edocs/systems/xps420/en/OM/HTML/parts.htm#wp1466871
From Me:
1) Computer unplugged from power, computer case open. TOUCH the metal frame BEFORE you reach inside.
Your body carries Static electricity.
Static will fry out computer hardware components.
You won't see it, or feel it.
Computer unplugged from power, you are safe.
Touch the metal frame Before reaching inside, your computer is safe.
Should you get up for any reason, walk away, then return, Touch the metal frame again)
You either have a 375 Watt, or a 425 Watt power supply.
I would recommend a power supply with more Wattage, and more Amp's on the 12 Volt power rail.
The Dell XPS 420 comes with an Intel Core2 Duo processor, or an Intel Core2 Extreme processor.
These puppy's can use a lot of power when gamin', or other intense programs are being used.
The Nvidia GeForce 8800 Series of graphics cards offered, use a lot of power when maxed out.
The motherboard with the Intel X38 motherboard chipset, uses a lot of power.
I would recommend a 600 watt power supply for a replacement.
My recommendation would be an OCZ StealthXStream 600W
Why?
1) If the temperature of this PSU is kept under 118 degrees Fahrenheit, the PSU can put out 728.8 Watts reliably. (47.9 degrees Celsuis)
2) It has Four - 12 Volt power rails.
EACH power rail can handle 18 Amps.
That's a total of 72 Amps!
3) It has all the power cables you'll need.
A) 20 + 4-pin ATX motherboard power cable
B) 8-pin 12 Volt power cable (8-pin EPS)
C) 4-pin ATX power cable
D) SATA power cables [ 3 ]
E) Peripheral power cables, (4-pin Molex) [ 6 ]
F) 6-pin PCI power cables. [ 2 ]
http://www.tigerdirect.com/applications/SearchTools/item-details.asp?EdpNo=3092557&CatId=106
Not advertising for the above website, nor the PSU manufacturer. Recommendation supported by personal preference, and experience.
Information about the various PC power cables and connectors,
http://www.playtool.com/pages/psuconnectors/connectors.html
SOURCE: Enquiries on maximum supported hard disk capacity and memory
Dell Optiplex 760 Vista
Max CPU Intel Q9550
Max RAM 8GB RAM
Largest HDD Shipped 1TB (Will likely Support 2TB)
Optiplex GX260
Max Intel Northwood 2.53 GHz - 533
Max RAM 2GB
Largest HDD Shipped was 200GB (Will likely support 500GB)
Dell Dimension XPS D300
Max CPU 333 Pentium II
Max RAM 384MB
Largest HDD Shipped 16GB (Will likely Support up to 80GB)
Dell Dimension XPS M
Max CPU 166S
Max RAM 64 MB
Largest HDD Shipped 4.3 GB (Max HDD likely 20GB)
I did not do the installation because I was not sure if I should do additional repairs before installation......especially when I have diagnostic lights warning me?
should i do the installation first? or should I take the memory modules out first?
one more point, I am reading the instruction manual stating that I should have memory modules 1&3 in white clamps and 2&4 in black clamps. I just looked inside pc.....both modules are in while clamps,,,fyi
