Question about Fender ® Frontman 15R Electric Guitar Amplifer
The amplifier is dead - Fender ® Frontman 15R Electric Guitar Amplifer
    New Friend:
  • 4 Answers
Check the fuse or power converter.
Posted on Mar 10, 2014
Please help me obtain a TC Electronics BG250 schematic
Try Googling (TC)(BG250)(manual) without parens.
Jan 08, 2016 | TC Electronic Music
Treble nob only works all the way up
nomally that means the pot is either dead or has come unsoldered form the board.
May 14, 2015 | Marshall Amplification Marshall MG Guitar...
Flextone 3 one speaker not working
Then you either have a blown amp or speaker. Turn the amp off and move the wires from the speaker on the working side to the other speaker. If the other speaker works, you have a dead amp channel. if it does not, move the wires from the speaker on the non-working side to the other speaker. If that works, you have a dead speaker. Dead amp channel means take it to the shop. Dead speaker means buy a new one from Line 6 and install.
Mar 08, 2014 | Line 6 Flextone III Plus Guitar Amplifier
I have a line 6 spider jam ...was playing guitar and then the sound went dead... loops work lights work but no sound
It probably the output Ic named TDA7293 and maybe because of the fan malfunction, let me know a bit further to help you more.
Oct 22, 2013 | Line 6 Spider Iii 75 Guitar Combo...
My ampeg BA115HP is dead. I suppose it is the fuse. Where is the fuse located?
it's the black thing sticking out of the circuit panel on the back of the amp
May 22, 2011 | Ampeg BA115HP 1x15' Bass Combo Amplifier
What are some of the common reasons that my Samson S-amp headphone amplifier isn't working?
Most common reason probably would be incorrect or failed power adapter. It appears the unit requires a 18 VAC (not DC) adapter. Dead batteries if that is the power source would be the other cause to suspect.
Feb 28, 2011 | Samson Samp Headphone Amplifier
Basically, I turned it on, played it, turned if off, went back to play it and I got a humming noise then it went dead!!??
I suspect either the power supply rectifier developed a short which would likely blow a fuse till repaired OR the power amplifier chio went bad. Most of the smaller amps use some version of the TDA2050 audio amp chip. It looks like a power tab transistor (TO220 stylle case) with 7 leads.
If it went, it did so for a reason... time for unit to be serviced.
May 26, 2010 | Marshall Mg15dfx 15-Watt Combo Guitar...
Hi have been given a Marshall MBB15 amp to find out why it doesnt produce sound through the input jack, have checked inside, looks like the resistors connected directly to the input jack are dead. Could...
Dead resistors? The evidence would be if the resistors are cracked OR if their is evidence of smoke/fire around them.
In either case, there would LIKELY be damage at least one or two layers deep beyond those resistors if in fact they are fried. If they are cracked physically, teh circuit board also may be cracked due to physical bending. Tripping over an inpout cable can do this.
Causes of this would be shorting the input to power line voltage or the output of a high powered amplifier.
I question that the resistors are "dead".
THE USUAL cause of failures of these small amplifiers is frying of the output power chip which is often in the TDA family of 5/7 terminal amplifier chips in modified TO220 packages.
Another less common problem is failure of the rectifier and filter capacitor combination.
Nov 03, 2009 | Marshall 15 Watt Guitar Amp
Fender ® Frontman 15R Electric Guitar Amplifer Logo
41 people viewed this question
Top Fender Music Experts
Michial Gueffroy
dave nyman
Level 1 Expert
Are you a Fender Music Expert? Answer questions, earn points and help others
