Question about Jack Lalanne Power Juicer 250 Watts
Safety part broken - Jack Lalanne Power Juicer 250 Watts
Why does juicer not start when assembled and plugged in?
It has a 10 year warranty, but check the instructions as there are bound to be safety features on it to stop it working unless properly locked together.
Omega BMJ330 Commercial 350 Watt Stainless Steel Pulp Ejection Juicer...
Review
Omega BMJ330 Review JuicerReviewsDirect com
Manual is here. Doesn't look as if there are any safety interlocks in the drawings. Aha, there is a safety lock! It is good to read to the end :>) Page 23 states;
IF YOUR JUICER ISN'T WORKING
If the latch arm on the right side is not secure and properly in place the juicer's safety switch will not engage. Therefore, the juicer will not work. Assemble the juicer properly.
https://www.omegajuicers.com/media/manuals/EFS_BMJ330_390_Manual_JUNE2014_web.pdf
Aug 22, 2014 | Omega Juicers BMJ330
Where is the safety Switch in the Jack Lalanne juicer express?
The safety switch is on the bottom base where the pulp collection bin goes. If you look on the pulp collection bin there is a small tab that when assembled right deactivates the safety switch. The main arm that holds the top container where you put the produce in is also a safety mechanism that when not in place the machine will not turn on.
Sep 08, 2013 | Jack Lalanne Power Juicer 250 Watts
My jack Lalanne juicer just suddenly stopped working.
Mine stopped working after only a few uses. It turns out that the safety microswitch button wasn't being depressed. The little button on the bottom of the pulp collector had broken off. (Image #1) I put a 1/4 inch piece of a shishkabob skewer in the hole before putting the pulp collector on. (image #2) It works fine now. It's still safe. The motor will not start unless the pulp collector (receptacle) is in place and locked in. Be sure to unplug the machine before doing this. 3717db6c-91bc-41ee-b452-1ed06578f280.jpgjack-lalanne-juicer-just-rgzqoe2q2f3mnxiw25vk3yhi-4-2.jpg
Mar 07, 2011 | Jack Lalanne Power Juicer 250 Watts
It wont turn on. i have changed the fuse but still nothing help
Devices these days are safety-ed up the whazzoo (technical term)
The safety catches and hardware all must be correct for these devices to work.
It is possible that a keeper or stationary lock of somekind is still installed preventing the machine from working.
Check the outlet to insure you have power there.
Insure all of the covers are in place and then insure a catch is provided for the output.
Failing all that, return it.
Sep 27, 2010 | Magimix Le Duo 250 Watts Juicer
Don't know how to set up Jack lalanne power juicer
First, check that the switch is in the on position. Then, check that all parts are assembled properly. The unit has a built-in safety device that will not let the motor turn on if not assembled properly. The Power Juicer also has a built-in Thermal Cut Off Safety Switch. If the machine was running, then shut down due to accidental overheating, then there is a 10 minute cooling time before the machine will restart. This helps to protect the motor from seizing. Click on the link below and select your juicer model to view the instructions and operating manual
http://www.powerjuicer.com/customer-manuals.html
Apr 15, 2010 | Juicers
Santos 28 wont switch on
Problem with internal micro switch,no power suply or locking handle not activating safety switch
Jul 08, 2009 | Matfer SANTOS Juicer
My UNIT-does nOt operate at all.
Hey if you have not gotten this resolved already, here are some things to consider.
I have the same unit. It will not operate is any little thing is left undone. So, I would recheck all of the assembly to make sure all the attachments are properly and securely attached.  The last part to check which seems rather minute, but will prevent the unit from working, is to check that the pulp catcher is securely snapped in. There is a small lip at the bottom that must clik in just right for the unit to kick on the switch is pressed.  Once the metal arm is in place, give it a whirl.... and let see what happens.
Hope this helps..
Let me know.
enov8
Feb 08, 2009 | Jack Lalanne Power Juicer (Stainless...
The pulp collection receptacle has a tiny clear plastic button on the bottom. If this has broken off (it happens often) the machine won't turn on. The button must be present to depress the safety switch at the bottom of the machine. If everything else is properly assembled and the machine won't turn on, this is probably the cause. Check the bottom of the pulp collection receptacle to see if the button has broken off. (picture #2) If so, replace it with a piece of pasta or a tiny piece of wood. Sounds silly, but it works. The safety switch at the bottom of the machine must be depressed before the machine will run.
Nov 04, 2008 | Jack Lalanne Power Juicer 250 Watts
The machine wont work
We had a Breville juicer which we just recently used but after a few hours it stopped working. May I know if whats the problem with it. We tried to open it but we can't figure what cause the machine to stop.
Jul 21, 2008 | Breville JE900 Juicer
Just stopped working
I am sorry I might not be able to explain in English very well, but I hope it will help somebody.
In my case, the pulp container was a problem.
when you take out the container, do you see the little(very very small )hole that if you push with something like toothpic it makes sound like "click, click"? I guess when we put the pulp container back, the container is supposed to push the safety button ( bottom area), but I think the part of the container that push the button was broken, and it didn't start,so I just put something small inside the hole before I put the container back to the juicer, so it covers the missing part.
Their customer service doesn't help at all, I waited 1h to talk to somebody, and he couldn't help me. so please check that part.
Sep 04, 2007 | Jack Lalanne Power Juicer (Stainless...
Jack Lalanne Power Juicer 250 Watts Logo
Top Jack Lalanne Juicers Experts
Greg Cann
Greg Cann
dflynn2204
Level 1 Expert
Are you a Jack Lalanne Juicer Expert? Answer questions, earn points and help others
