Question about Singer 2950 Mechanical Sewing Machine
How to thread machine...I don't have the instruction book
Phaff P3 Power quilter top thread is looping on the backing side of the quilt
1 - Thread the machine absolutely correctly (pages 25-26 of your instruction book)
2 - Balance the tensions (pages 29-30 of your instruction book)
Oct 04, 2014 | Sewing Machines
How do i fill bobbin, thread machine and bobbin?
Did you know all sewing machines are threaded in the same way. The parts just look a little different. If you can thread one machine you can thread them all. Dont you have an instruction book? If not get any instruction book for a simular looking machine. There are many you can dowload for free as a pdf file.
Dec 12, 2010 | Necchi 3610 Sewing Machine
How do I thread the Juki MO-644D?
Email me at sewingnz@gmail.com should be able to help.
Jan 19, 2010 | Juki MO-644D Mechanical Sewing Machine
SIMILAR PROBLEM OF TOP THREAD ACCUMULATING IN BOBBIN AREA
it sounds like a needle threading problem. if you have the instruction book, pull yout needle thread off the machine and re-thread as per the book ie presser foot up and make sure thread goes betwen tension discs and up over takeup lever.
to check needle tension is ok, lower presser foot and pull needle thread through needle, the needle thread should be tight enough to bend the needle a little.
goodluck,
scott.
Jul 28, 2009 | Janome Mini Compact
Trouble shooting a bobbin threading issue for a Singer 5417C
take the shuttle out and see if there is any thread jammed in
Jun 10, 2009 | Singer 5417 Mechanical Sewing Machine
Threading three thread Baby Lock Overlocker EF 405
Ther should be a color coded threading chart on the front inside cover.
Jan 12, 2008 | Sewing Machines
Simplicity Denim Star SW 210
Thread looping / bunching under fabric sewing.
Incorrect or NO top thread tension, Incorrect threading
Re thread top thread and thread machine with presser foot lifted allows thread to locate into the correct thread tension route.
Thread has not been pulled into thread tension unit- re thread, make sure thread is kept taut while threading.
Jan 03, 2008 | Simplicity American Denim SA1100...
Singer 2950 Mechanical Sewing Machine Logo
27 people viewed this question
Top Singer Sewing Machines Experts
Tally Girl
Tally Girl
mystery_soul
Are you a Singer Sewing Machine Expert? Answer questions, earn points and help others
