Question about Halo 5500mAh Portable Power Charger for Cellphones & Electronics - Red -
The three lights don't blink when turned on or when charging
When I want to turn on Halo it doesn't blink the 5 times, nor does it blink when charging
What is the code for 2 or 3 blinks then 5 blinks?
If 25 automatic idle speed.\[AIS].If 35 radiator fan relay.What problem you have overheating or poor idle.
Apr 05, 2013 | 1994 Chrysler Town & Country
My battery wont charge
I use mine almost exclusively plugged in. You can "cook" a battery this way. Think of batteries as having only so many recharge cycles. Like the turn signals on your car will eventually come to the end of it's life, so don't sit through a red light with it blinking for three minutes before you get a green light and make your turn, I turn mine on just before the light turns green. I also take my battery out about every third day and run it only on the AC adapter, giving the battery a rest.
Dec 28, 2011 | Dell Latitude D600 Notebook
Kindle light is orange when I charge but even after of hours of charging continuous efforts to turn on Kindle, it won't turn on.
Try to slide and hold the on switch until after the power light blinks three times (should happen after a little more than 5 seconds). Release the switch after the blinks and the Kindle should start up.
This is only necessary if the Kindle was switched off by the same method before, or if the battery was completely drained. A short nudge of the power switch merely puts it in and out of a power-saving sleep mode, the prolonged hold really cuts / reinstates power.
Jul 16, 2011 | Amazon Kindle Wireless Reading Device
My pcg-fx220 vaio laptop has what looks like battery 1 flashing yellow light. I start it up but it doesn't get past the sony start up screen the little light just keeps blinking. It's plugged in so...
Take out the battery, plug it in turn it on, if the problem is the same unplug it. Turn it over and remove the access panel from the bottom. There you should find your RAM if you have two RAM modules installed remove both and replace them one at a time with the power off. So insert one and power on computer if the same result as before, remove it and insert the other RAM and power it on again. Also look to see if your CPU fan is spinning. If your fan only spins for 5 to 10 seconds and powers off one of three things are bad, either your CPU, GPU, or Motherboard are bad or damaged. It might turn on here or there if this happens it's probably your GPU. Hope this helps you.
Jun 28, 2011 | Computers & Internet
Jabra BT650 won't turn on. green light blinks only while charging.
For a while I was not able to figure out how to turn the Jabra Halo headset on. What you need to do is unfold the headset and then push the hinged portion into itself, which will lock it in place so that it will no longer hinge for the time being.
Oct 14, 2010 | Jabra BT650 Bluetooth Headset Halo
IT TURN OFF ITSELF RIGHT AFTER TURN ON GREEN
If the Lamp red light is blinking then replace lamp, replacement procedure is written in user manual and its easy.
If standby/ power red light is blinking then please count its blinking and post here. It is an error code that has info about problem in specific section of tv.
You will see 3 seconds long pause between blinks so count pause to pause.
May 11, 2010 | Sony Grand WEGA KDF-60XS955 60" Rear...
Air Bag warning light on
Try this too and if it doesnt work the first time u might have done something wrong and try it again. if u can reset it then u will have to have it scanned1. Turn the key from off to on.
2. Watch the airbag light closely. It will stay on for a few secs. and then as soon as it blinks off (the start of the flashing), turn the key off instantly.
3. Count to 5 (1 Mississippi, 2 Mississippi . . . .)
4. Repeat steps 1-3 two more times until you have done the cycle three times.
5. Now turn the key on and watch the light. It will start blinking in a different, slower manner. This is diagnostic mode. You can watch this for a little while, no hurry.
6. Now turn the key off again, Count to 5 like in step 3 again, and turn back on. If the procedure worked, the airbag light will not be flashing.
Sep 17, 2009 | 2004 Kia Sorento
Won't turn on, but the charge icon blinks 3 times
It has enough juice in the battery to light up the lcd lights but not enough to turn it on. Could be the power supply. Consult a reputable service center and have it checked out. Good luck.
Aug 04, 2009 | HP Compaq Presario V2000 Notebook
Air bag light is blinking
my airbag light is blinking . can i reset anything its a04 nissaun armada
May 02, 2009 | 2004 Nissan Armada
Halo 5500mAh Portable Power Charger for Cellphones & Electronics - Red - Logo
118 people viewed this question
Top Halo Electronics - Others Experts
Are you a Halo Electronics - Other Expert? Answer questions, earn points and help others
