Question about Electrical Supplies
What would cause a coleman powermate generator to burn out the outlet plugs(recptical)
  • 15,557 Answers
This is caused by excess heat build up. If the voltage is low then ohms law says that the amperage will rise. The excess amperage causes the heat that is destroying the recepticals.
Posted on Feb 14, 2014
SOURCE: generator fuel-oil mixture
My manual for my Powermate 1000 says 18:1 fuel mixture.
Posted on Sep 13, 2008
  • 13 Answers
SOURCE: Powermate PM0535000-01 Manual
powermate went out of business , but this might help let me know http://www.powermate.com/contact.php
Posted on Sep 27, 2008
SOURCE: Coleman PM0433500 Brushless Generator will not make power
Bad capacitor. They cost 13 bucks. Call 800-445-1805 to buy one.
Posted on Jul 29, 2009
protek480
  • 1714 Answers
SOURCE: My coleman powermate generator will start but will not generate.
The voltage regulator controls the output. You will need to check that first.
Posted on Aug 01, 2009
stunt driver
  • 5 Answers
SOURCE: Coleman powermate 2500 generator :
To what I know about this model - it IS NOT inverter type. Electrical motor works pretty much like car alternator with out reftifier. The ONLY magnet on rotor is a small, 1x2 initiation magnet, that helps to start the induction current. After that, induction current thru rotor is controlled by AVR (automatic voltage regulator) in a way, that output voltage stays at needed level.
The fact that you read 2.0 volts on output - tells you that your initiation magnet is OK. One of few things went wrong, in probability order: winding on rotor, AVR module, winding on stator, brushes woar out.
Take back cover off from electric generator part, use voltmeter to measure continuity on stator (2 or 3 poles, must be within 50 ohnm), continuity of rotor thru brushes ( normally within 100ohm). If broken - have to restore windings. It is DIYable for rotor, but hardly possible for stator. If those are ok - most probably your AVR is dead, you can not test it yourself, so get a new module to try (but try to make arrangements for return, if there it was not the reason).
Just fixed Champion 3500 generator myself, purchased for $50 as broken.
Posted on Jan 13, 2010
The generator hasn't, been used in a while and is not cranking. Gas is getting to the spark plug and the plug is clean. What could be the issue?
Coleman starter not cranking Power Generators Questions ...
www.fixya.com > Forum > Tags > starter not cranking > Power Generators
Coleman power generators starter not cranking related questions and answers. Ask your ... Ad. Question about Powermate Powermate 5000W Generator.
Powermate coleman 5000 gen. with subaru engine ... - faqqq
www.faqqq.com/.../powermate-coleman-5000-gen-with-subaru-engine-col...
Question Product: Coleman Powermate Powermate 5000W Generator Question ... it would crank for a second, then i open the choke, it would die, would not stay ...
Fixing Electrical Problems in Coleman Powermate Generators
www.alpharubicon.com/altenergy/colemanpenwu.htm
*Fixing Electrical Problems in Coleman Powermate Generators* By: Penwu 29 April 2006. All of Coleman's portable Powermate line of generators use brushes ...
Coleman 5000 watt generator cold start - YouTube
? 4:35
https://www.youtube.com/watch?v=pcT989l0rm0
Nov 3, 2011 - Uploaded by stevenpturcheck
well im starting to cycle though my equipment before winter so more cold ... How To Change Oil On Coleman Powermate Generator / Yearly ...
Jan 21, 2016 | Coleman Powermate Powermate 5000W...
How do you convert the (2) 240 volt outlets to one twist lock connector on a coleman powermate maxa 5000 er genset
Make an Umbilical recepticle adapter. Buy the recepticle install the recepticle in a 4" electrical BOX on a plate with two manufactured 3 prong power cords plugging into the 2 outlets and terminating at the new Box twist lock recepticle you made.
Feb 09, 2010 | Coleman Powermate Powermate 5000W...
AVR board is burnt out
AVR burn out is the most popular problem with electricity supplyment....
replace the AVR...if it burnt out shortly after words..then u have a problem with the rpm of the engine...if not..then its just a AVR burnout..
don't hesitate to write to me for further information:
sal_kh_sab@yahoo.com
Sep 27, 2009 | Coleman Powermate Powermate 5000W...
May 31, 2009 | Coleman Powermate Powermate 5000W...
Coleman 5KW gen motor shuts down when A/C switch turned on
Sounds like a problem with the wiring of the outlets after the circuit breaksr. Take apart the outlet box and have a look for burned or broken wires, melted outlets, and/or small critters stuck in the wiring.
I recently had to repair a generator that had its voltage regulator taken out by a frog!
Regards,
Carl
Feb 28, 2009 | Coleman Powermate Premium Plus 6250W...
Powered up Coleman Generator. Generator made grinding noise
I don't know what unit you have, but I would say it was overloaded and shorted out the stator, burned up the voltage regulator, exploded the capacitor, or had a loose connection that caused some wires to burn up. Maybe remove the end plate off the generator end and take so pictures and will go from there.
Jan 14, 2009 | Coleman Powermate Premium Plus 6250W...
TWIST PLUG
go to an electric supply store and let them know it is a 20 amp plug. The big box stores only have a few selections of plugs
I had the same generator and had to modify the plug to make it fit correctly
Jan 08, 2009 | Coleman Powermate Powermate 5000W...
I have a 5000w colman generator w/ 2 standerd 120v outlets, 1twist 120/240v outlet. the grounding prong goes out all i can find are cords that go in ???
Go to an Electric supply store and tell them it is a 20 amp plug. They should be able to get the correct plug.
I had this generator and had to adjust the prong to make it work.
Motor runs but have no power coming out of outlets of mygenerator
1 - Check the circuit breakers on the front of the panel where the outlets are located.
2 - Make sure the black molex plug on the back of the panel where the outlets are located is plugged in securely.
3 - Carefully take the plastic endbell off the generator ( you'll need a 7/16 inch wrench and socket) and look for broken or missing brushes, broken wires, etc.
4 - If you're not up for #3 take it to a good repair shop. :-)
Nov 13, 2008 | Coleman Powermate Premium Plus 6250W...
Electrical Supplies Logo
22 people viewed this question
Top Electrical Supplies Experts
Steve
Gene Haynes
Are you an Electrical Supply Expert? Answer questions, earn points and help others
