Question about LG BX327 DLP 3D Ready Projector, Digital Keystone Correction, Picture StilExpert Color ControBrilliant Color, HD DivX Player, 3D Ready DReady Type, HDMI ver. 1.4_3D, Long Lamp Life, Up to 4000 hrs in economic mode, BuiIn Stereo Speakers, Auto Sleep BX32
DLP Projector BX327-JD lamp cover broke. Need a new cover
Need new lamp external cover. Part that screw goes into broke off.
    Renaissance:
    An user who is expert in 3 categories / brands.
  • 729 Answers
You can pick up some plastics instead of it
Have a good day! any question ,contact me,Please
We supply original projector parts: lamp, bulb, Lcd panel, Lens, DMD chip, color wheel,
motherboard, powersupply ... with high quality and competitive price.
Jerry Lampdeng Limited
Mobile: 0086-13178867858
Wechat ID: 008613178867858
Whatapp ID: 008613178867858
Skype: lampdeng@hotmail.com
http://www.lampdeng.com
Posted on Mar 02, 2014
2 Suggested Answers
marsrover
  • 682 Answers
SOURCE: LAMP goes off after few minutes
1-check the counter reading of lamp to see if it is in the right age of lamp or not.if it is in right age the problem still in power unit or in ballast.
Posted on Mar 14, 2008
How to reset lg BX327-JD Lamp Timer
If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience.
http://electro-medical.blogspot.com/
Jan 02, 2016 | LG BX327 DLP 3D Ready Projector, Digital...
How to reset lamp hour on lg bx327 projector
Here is a link to the manual in case yo don't have it:
http://www.projectorcentral.com/pdf/projector_manual_6082.pdf
However it doesn't include counter reset instructions that I could find!
I didn't find specific 327 instructions, but here are 3 different procedures for other units:
Turn the power off but keep pluged in. Press the buttons on the control panel in the sequence as below.
Press "Up Arrow", Press "Down Arrow", Press "Left Arrow", Press "Right Arrow", Press "Menu", Press "Enter".
Lamp time will be initialized
Posted on Mar 01, 2008
  • If you do not have a remote here is how to reset the filter time. Use the "Menu" bottun to get the "easy menu" to display. Push the down arrow until you get to "Filter Time," then push and hold the RIGHT arrow to reset the filter time. DO NOT try to reset using the "Reset" option on the easy menu, it will not work.
    Posted on Oct 02, 2008
  • SOURCE:Lamp timer on Sharp XV-Z2000 will not reset
    • I unplug my cord, waited for 5 minutes, then reconnect cord holding the power button at same time, released, then proceded with input, left arrow, enter, right arrow and depress power button again holding for 15 seconds, then released. projector warmed up showing the "0000H" on the bottom left of screen...that's how mine worked today.
  • If/when you get it to work, please post back via comment to original question.
Jan 08, 2015 | LG BX327 3D Projector
Optoma PCB MAINBOARD MODULE FOR 8EG
My HD20 also broke after about 1000 hours. Their estimate is $703.00 to replace main board and lamp module. Image shuts off automatically after 3 mins of starting. Lamp fail led goes solid red.
Nov 10, 2011 | Optoma HD20 DLP Projector
Message says airfow blocked, turns on for about a minute then shuts off
1. Remove the air intake filters on your DLP projector. As explained by InFocus, a manufacturer of LCD and DLP projectors, each DLP model will house the air filters in a different location. However, for most DLP projector products, the filters are accessible by unclipping a simple plastic latch.
2. Wipe the air filters with a small cloth dipped in rubbing alcohol.
3. Blow compressed air into the unit's vents. This will force some internal dust out of the DLP projector, but you may still need to open up the unit for additional dust removal.
4. Unsnap the main cover from your DLP projector. Because DLP projectors need periodic lamp replacement, the main cover is rarely secured with screws or bolts. However, if the DLP projector's cover does not snap off, then you'll want to inspect the unit for possible screws or an alternate release latch.
5. Reach in and remove visible dust globs with a paper towel. Be careful to avoid touching the lens, as fingerprint smudges can diminish DLP projector image quality. If you accidentally smudge the lens while picking out dust blobs, wipe the lens with a dry, lint-free microfiber cloth.
6. Spray compressed air into your DLP projector to remove any lingering dust particles.
7. Close up the projector and reattach the filters.
Sep 26, 2011 | Mitsubishi WD-65C9 65" DLP HDTV
I have an rca hdlp6iw51 and i found a color wheel on ebay but i dont know how to change it does anyone have any advice
Follow this steps:
1. Take the back panel off of your set, using your Phillips head screwdriver, to remove any screws. 2. Remove the projector lamp. You can reach the color wheel without doing it, but you are less likely to damage the projector lamp if you take it out. Loosen the screws at the base: depending on your DLP's brand, the screws may come out, or may just loosen. If they come out, set them in a safe place before removing the lamp. If not, just pull the entire lamp out, once the screws will not loosen further. 3. Take out the panel that is connected to the cable outlets, using the screwdriver to take out any screws. Pull the panel until the cables, attached from the inside, run out of slack.
4. Remove the screws at the bottom of the panel, in the center, and any screws connecting this panel to the outer case of your DLP. The number and location of these screws will vary depending on your DLP's brand.
  • 3 Remove the projector lamp. You can reach the color wheel without doing it, but you are less likely to damage the projector lamp if you take it out. Loosen the screws at the base: depending on your DLP's brand, the screws may come out, or may just loosen. If they come out, set them in a safe place before removing the lamp. If not, just pull the entire lamp out, once the screws will not loosen further.
  • 4 Take out the panel that is connected to the cable outlets, using the screwdriver to take out any screws. Pull the panel until the cables, attached from the inside, run out of slack.
  • 5 Remove the screws at the bottom of the panel, in the center, and any screws connecting this panel to the outer case of your DLP. The number and location of these screws will vary depending on your DLP's brand.
  • 6 Pull out the entire center unit, pulling gradually. Then, unplug the power cable from the main set (this is generally blue and brown). Remove the sensor switch and any cables joining the center unit to either side of the set.
  • 7 Take out the plug from the cover of the color wheel. In most brands, it will have a black and blue wire connected to a green circuit board. Then, remove any cables coming out of the wheel. Depending on the brand, the screws may be small enough to require the jeweler's screwdriver.
  • 8 Remove the screws holding the color wheel cover in place. Remove the cover, then take out the screws holding the wheel in place. If tape is holding the wheel, just pull on the wheel until it comes free.
  • 9 Put the new wheel into the slot. You do not want to touch the wheel, or you will blemish it and leave impressions that will be visible when the light shines through it. Re-insert the screws. Then, replace the cover, making sure that the wire jacks are in the same places.
  • 10 Reassemble the DLP television, then plug the set into the wall, and turn on the power.
  • Read more: How to Change a DLP Color Wheel ' eHow.com http://www.ehow.com/how_7697815_change-dlp-color-wheel.html#ixzz1VdDl2OQb
    Aug 21, 2011 | RCA HD61LPW42 61" Rear Projection HDTV
    Need to remove bad lamp from the HC100 projector
    1. Reverse the projector gently.
    2. Loosen the screw (a) using a Phillips screwdriver (+), and remove the lamp cover (b).
    3. Loosen the screws (c) using a Phillips screwdriver (+).
    4. Pull up the handle.
    5. Pull out the lamp box by the handle while holding the projector.
    Pull the lamp box out of the projector slowly. If it is pulled out quickly, the lamp may break scattering
    glass fragments.
    Do not spill liquid on the removed lamp box or do not place it near any flammable object or where children
    can reach to prevent injury or fire.
    6. Load a new lamp box securely into the projector in the right orientation.
    7. Put the handle back to the original position.
    Make sure that the handle is locked.
    8. Tighten up the screws (c) using a Phillips screwdriver (+).
    9. Tighten up the screw (a) using a Phillips screwdriver (+) to secure the lamp cover.
    Jul 20, 2011 | Mitsubishi HC100 DLP Projector
    Bulb "End of Life" message
    hi,
    for replacing the lamp do yhe following.
    1.Remove the lamp cover by pushing two grooves lightly with the flathead
    screwdriver. You can see the lamp cover on the top of the projector. ( left side of the lens)
    2.Loosen the two screws securing the lamp housing until the screwdriver
    goes into a freewheeling condition. The two screws are not
    removable
    3.Remove the lamp housing by pulling out the handle
    4.Insert a new lamp housing until the lamp housing is plugged into the
    Socket
    5.Secure it in place with the two screws.Be sure to tighten the screws.
    6.Reattach the lamp cover
    7.Snap the lamp cover into place.
    Replacing a new lamp automatically clears the lamp usage hours ok
    Jan 27, 2011 | NEC MT1060 Multimedia Projector
    How do you install a new bulb in the Optoma HD70 projector. Got a new bulb but no instructions
    unscrew the screw on the lamp door, unscrew the lamp screws, pull the lamp out, replace with new lamp (making sure it's securely plugged in), screw it in, replace the door, plug the projector in, turn it on, enjoy!
    Nov 07, 2009 | Optoma HD70 DLP Projector
    LG BX327 DLP 3D Ready Projector, Digital Keystone Correction, Picture StilExpert Color ControBrilliant Color, HD DivX Player, 3D Ready DReady Type, HDMI ver. 1.4_3D, Long Lamp Life, Up to 4000 hrs in economic mode, BuiIn Stereo Speakers, Auto Sleep BX32 Logo
    81 people viewed this question
    Top LG Office Equipment & Supplies Experts
    jasbo
    jasbo
    Jaime Hernandez
    Lawrence Oravetz
    Are you a LG Office Equipment and Supply Expert? Answer questions, earn points and help others
