Question about HP TouchSmart IQ770 PC Desktop
How do i enable touchscreen
I just bought a used hp touchsmart pc. the touch screen was disabled but i do not know where to turn it on from. i assumed it was off of the control panel but i cannot find a webpage helping with this model.
  • HP Master
  • 16,397 Answers
The only other place that it would be is in the BIOS.
Posted on Feb 14, 2014
philw1964200
  • 130 Answers
SOURCE: my screen does not respond on my Hp touchsmart pc IQ 506
Is it still under warranty? It should be. If not then HP will help either way. This is a new development for HP to start with. Go to HP/support.com there are questions there to match up with the problem you are having if not then you can send them you actual problem you are having. They will most likely either pick up your PC at no cost or do a remote access to resolve your issue. Have any problem in doing this let me know and I will help you.
Phil
Posted on Jan 08, 2009
SOURCE: HP TOUCHSMART IQ770 BLACK SCREEN
Have you checked on the hibernation settings?
Posted on Jan 21, 2009
Hardtack
  • 46 Answers
SOURCE: My HP touchsmart desktop  powers
First of all try shutting down the computer completely, and unplugging it from the wall for about 5 minutes. Sometimes this is enough to reset the internal usb devices. This computer gets very hot, and can drop devices when overheating. If that doesn't work then try plugging in a wired usb mouse, then do a rollback using system restore to the last known working state. Also think about any recently installed programs and how they may have affected your computers sanity. Does the touchscreen still make sound when pressed? The nextwindow touchscreen should always work, even if not properly calibrated it should always be on, because its controllers are hardware, unlike other touchscreens that use software to calibrate. Check the device manager to see if any HID compliant mouse devices are listed at all. There should be at least two, one for the screen and one for the mouse.
Posted on Feb 10, 2009
  • 121 Answers
SOURCE: My touch screen isnt working at all
it seems that your hardware is all right.you need to contact your retailer to get your screen repairs.
Posted on Jun 18, 2009
VKUR
  • 62 Answers
SOURCE: HP TouchSmart IQ770 PC Desktop replace screen
Hi ,
I have pasted the url so kindly copy paste it in the address bar and you will find the moving pictures .All u need to do is just roll the mouse over the picture and u will find something interesting ....It gives u the steps to replace the screen...
http://h10025.www1.hp.com/ewfrf/wc/document?docname=c01060928&tmp_task=solveCategory&lc=en&dlc=en&cc=us&lang=en&product=3351220
hope this will help u .....all the best...
Posted on Mar 19, 2010
Touch portal
By :"touch portal" I assume you mean either the touch screen. I'm not sure if there is an easy way to do this, but one method which should work is to disable the software used to run the touch screen. One way to do this is to go to device manager, find the touchscreen driver, right mouse button click on it and say "disable." That should turn it off. There are probably other ways, but I don't know of them.
Jul 16, 2014 | Gateway One ZX4300-41 (PWGAW02017) 20 in....
Tip
How do I use my iPod With an HP TouchSmart
<p>The HP TouchSmart PC is a common computer, except it has a touchscreen. This allows you to tap the various icons on the screen for games, applications, and download files, and open your iTunes. Using an iPod with your HP TouchSmart PC is like using your iPod to another computer or MacBook. However, instead of using a mouse to navigate through your iTunes library, you need to tap your finger, or "click" on the items you want to open and upload to your iPod. <br /> <p><br /> <p>1. Turn on the computer end of the USB cable into USB port of your TouchSmart. The end of the computer's USB cable is the smaller of the two sides. <br /> <p><br /> <p>2. Connect the other end of USB cable to the bottom of your iPod. Normally, when you connect your iPod to the TouchSmart PC, iTunes opens automatically. If it does not open, tap the iTunes icon on the screen of your desktop to open the application. <br /> <p><br /> <p>3. Tap "File" at the top toolbar of iTunes. Select "Sync iPod" to upload music, photos and even files from your iTunes library to your iPod. <br /> <p><br /> <p>4. Select the "Eject iPod" icon in "Device: iPod" on the left side of the screen. This will allow you to safely remove the USB cable from your iPod and TouchSmart. <br />
on Aug 09, 2011 | Apple iPod touch
TOUCH SCREEN DOES NOT WORK
There are three (3) possible Answers:
First: Your unit does not have TouchScreen.
If the part number has CF30xTxxxxx then the "T"=TouchScreen.
If your unit has touchscreen then,
Second: The TouchScreen may be disabled in the BIOS.
Check the BIOS and see if TouchScreen is "ENABLED".
If it is DISABLED, then ENABLE it usually by pressing
the spacebar key while it is highlighted and then
SAVE and EXIT the BIOS.
Third: You do not have the Touchscreen Drivers loaded.
Locate these drivers at the Panasonic Website:
http://pc-dl.panasonic.co.jp/dl/
Good Luck!
Regards,
Richard - Montreal Based
Panasonic Toughbook Authorized Dealer since 1989.
Mar 17, 2014 | Panasonic Toughbook CF-30 Notebook
The screen touch does not work
try this if no go please post back thanks.http://h30434.www3.hp.com/t5/TouchSmart-PC/TouchScreen-not-working-in-TouchSmart/m-p/1850987#M16027
Jan 04, 2014 | HP TouchSmart IQ770 PC Desktop
How do i turn the "touchscreen" off on an Asus S200E vivobook touchscreen laptop? please i need help urgent!
Press the Windows logo key + X.
Click the little arrow next to Human Interface Devices to expand the list.
Click the touch screen driver (in my case, NextWindow Voltron Touch Screen).
Right-click, and select Disable from the list.
Click Yes on the dialog box that asks if you are sure you want to disable the touch screen driver.
When you want your touch screen to work again, follow the process above, EXCEPT when right-clicking the touch screen driver, select Enable
Sep 26, 2013 | ASUSTeK COMPUTER Asus VivoBook...
Can't use touch screen on hp smart touch
If it is TouchSmart you have an issue with, go to the control panel and select touchscreen configuration. Make sure your global touchscreen settings are set to enabled. Click save and then close.
If this is not the issue it is possible there are hardware damages to the touch screen. Has it been dropped at all?
Jan 07, 2013 | HP Touchsmart Iq500 Driver Recovery Disc...
I have touchsmart 300 and it is not touch sensitive can anyone help?
Hello
Reboot the PC and see if that takes care of the issue. All-in-One PC's tend to stay on all the time and do not get rebooted regularly and this could be causing the issue.
The touchscreens for HP use a sensor that looks at the front of the screen and scans for contact. If you look at the left, bottom and right of the screen, you will see the screen is recessed about 1/4". This is the glass that the touch sensor uses to "see" your finger inputs. If there is any dirt on this or if it is blocked in any way (tape, paper, etc.) the touch screen will be directly affected.
The link below covers the HP suggested troubleshooting of a touch screen issue for your model All-in-One. It covers the basics like keeping the screen clean, checking the OS to make sure the inputs options are enabled and how to further test this.
http://h10025.www1.hp.com/ewfrf/wc/document?docname=c03046857&tmp_task=solveCategory&cc=us&dlc=en&lc=en&product=4066631
Dec 13, 2011 | HEWLETT-PACKARD Computers & Internet
How can we disable the touch screen. we want to loop a video. but we do not want to activiate the touchscreen or have a mouse when the video is looping.
I have provided a link for you to have a look at. I don't know which version of windows you are using but it should be the same technique. I hope this helps and good luck. Extra note, disregard the model of pc that these instructions are displayed for.
http://acer.custhelp.com/app/answers/detail/a_id/6763/~/how-do-i-enable-or-disable-the-touchscreen-feature-on-my-computer%3F
Andrew
Apr 04, 2011 | MSI AIO AE1900-01SUS 18.5-Inch Touch...
My new touchsmart 300 pc will not work
Contact HP they have a special driver.
Tell them to provide you with the touch screen drivers.
Install it and check if it works.
May be its the graphics driver.
May 29, 2010 | HP Pavilion TX1000Z 12.1" Touch Screen...
HP TouchSmart IQ770 PC Desktop Logo
57 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
