Question about Acer H5360 3D Video Projector 3D
Acer projector blue light blinks and fan blows and no picture
It overheated and shut down yesterday and has not been able to turn on since. When I press the power button the blue light comes on, it beeps like normal and it sounds like it is starting up. Then it beeps two times, the blue light flashes, and the fan starts blowing. It continues to cycle like this and never shows a picture.
    Problem Solver:
  • 23 Answers
As far as I can tell this looks like a lamp problem. Unless some of the fans are not able to cycle up tehn it would shut down before it overheats
Posted on Feb 14, 2014
5 Suggested Answers
jcarlton214
  • 105 Answers
SOURCE: Acer pd120 projector
get a bottle of canned air. blow out unit. take bulb out and clean everywhere every time you change bulb. let it sit for a while so it warms back up prior to plugging back in.the air gets cold
Posted on Jun 07, 2009
  • 23 Answers
SOURCE: When I tried to switch
Ordinarily my first thought would be that the lamp is needing replacement. But if it's brand new, the lamp should be OK. Can you open the lamp compartment to see if it was broken during transit, or perhaps it's not fully seated properly. If it's a broken lamp, then I would contact the dealer you purchased it from, or contact the manufacturer directly to have it replaced. Also, is the noise loud and unusual, or just the normal sound of a projector coming on? If it's very loud, it could be the fan motor. Check that the fan is blowing. If the fan is the problem, the projector will shut down to protect itself from overheating. That, too, should be covered under the waranty.
Posted on Jan 13, 2011
Testimonial: "Thx for help"
SOURCE: My acer pd120d is not
help pls............. my problem blinker lcd projector
Posted on Mar 08, 2011
  • 138 Answers
SOURCE: my acer lcd projector not showing display, its
I suggest call for assistance for that product or replace the bulb of your projector.
Posted on Sep 20, 2011
Projector auto shut down
The blink pattern indicates the LED emitter is overheating.
Sep 08, 2014 | Vivitek QUMI Q2 720p LED Projector QUMI-B
Viewsonic projector shut down and power button blinking
It may be clogged with dust which in turn causes overheating. Use a can of compressed air from computer store or office supply store and blow air through the air vents of the projector.
Jul 30, 2014 | ViewSonic PJ513DB Projector
Infocus IN10 projector, when I turn it on the light blinks green for a while (with no picture) and then it shuts off and blinks red (more than 5 blinks)
if Lamp or projector shuts off after running a short period of time, This is usually a thermal issue caused by excessively
high internal temperature. The high temperature
could cause a component on the controller ECA or
the power supply to fail when it gets hot.
First you need to check the fan operation, Are 3 fans, two for lamp and one for the color wheel. Check the elevation foot, if something is broke maybe something stop the fan.
Remove the lamp module.
Examine the fan assembly through the recess in the bottom case. Plug the projector in and turn it
on. Both fans in the fan assembly should start up and run for 5 - 10 seconds, then shut down
(because there is no lamp installed). This is time enough to make sure the fans work properly.
Make the same for the color wheel fan, you need to remove the top case.
Oct 15, 2013 | InFocus Work Big IN10 DLP Projector
Dell 1209S Projector, tries to turn on, and the fan comes on for 30 seconds and then goes off again. It tries this several times and then the light bulb icon comes off and it doesn't do antything else
Lamp is burned out or makes a popping sound.
When the lamp reaches its end of life, it may burn out and may make a loud popping sound.
If this occurs, the projector does not turn back on. To replace the lamp, see on page 38.
LAMP light is solid amber If the LAMP light is solid amber, replace the lamp.
LAMP light is blinking amber If the LAMP light and the Power light are blinking amber, the lamp driver has failed and the projector will automatically shut down.
If the LAMP light is blinking amber and Power light is solid blue, the color wheel has
Unplug the power cord after 3minutes then turn the display on again. If this problem
persists, contact Dell™.
TEMP light is solid amber The projector has overheated. The display automatically shuts down. Turn the display on again after the projector cools down. If the problem persists, contact Dell™.
TEMP light is blinking amber A projector fan has failed and the projector will automatically shut down. If the problem persists, contact Dell™.
Oct 23, 2011 | Dell 1209S DLP Projector
When I tried to switch on my projector Acer H5360 it makes some noise then it beeps 3 times, blue led light flash 2 times and then red is steady by returns... Its brand new.. Any idea? Pls help
Jan 13, 2011 | Acer H5360 3D Video Projector 3D
Projector shuts down after a couple of minutes with lamp and temp lights flashin, is this a fan poblem and can i replace the fan?
This probably the fan is not cooling down the temperature of the high intensity bulb. Due to overheating the bulb will shutdown. Get a correct specification fan to replace the aging fan.
May 30, 2010 | Acer PH110 Multimedia Projector
Projector turns on for about 30 seconds then shuts down. the fan kicks up high, and led light flashes yellow for about 4 min until the fan shuts off. does not feel hot so overheating does not seem to be...
if the lamp lights and then shuts down, replace the lamp. it's at the end of it's life. to rule out overheating, blow the projector out with canned air. dust retains the heat that the projector is trying to expell. also see if all of the fans are working. if you do get an image for a short time, try to get into the menu to reset the settings to factory default. lastly, if all else fails, you have a ballast issue. unfortunately, infocus no longer sells parts for this model.
Nov 28, 2009 | InFocus LP 630 Multimedia Projector
Jun 07, 2009 | Acer PD120 Multimedia Projector
It's on, then it's off
Is the fan running properly or are any vents blocked?
Sounds like it is overheating.
Feb 15, 2008 | NEC MultiSync MT1050 Multimedia Projector
Acer H5360 3D Video Projector 3D Logo
511 people viewed this question
Top Acer Office Equipment & Supplies Experts
jasbo
jasbo
Electro Med Services...
Are you an Acer Office Equipment and Supply Expert? Answer questions, earn points and help others
