Question about Onkyo TX-DS676 Receiver
Independent dual cassette hook up
Independent dual cassette connections.
How do I hook up a rsb11w dual tape deck to a technics sa450 receiver
Hi! This is normally relatively easy. You just connect the tuner output to the line input of the deck. Normally this is done with the amplifier where the tuner go to the tuner and the tape deck to its connections just line out to the cassette input and the cassette line out to the tape input of the amplifier
Oct 04, 2014 | Audio Players & Recorders
Shows err- 3 on power up.
I think it is refering to an external control device such as a wired remote. You might try unhooking external connections and then re-hooking them and then booting it back up. Good Luck
Sep 02, 2014 | Tascam 302 PRO DUAL CASSETTE DECK Single...
I asked 3 times now!!! How do I hook up together a Pioneer tuner, power amplifier, and dual cassette deck, together then hook it up to a speaker!!!
Are we a little impatient?
It's pretty straightforward. Use one cable to connect the tape deck to the amp. Use another cable to connect the tuner to the amp. Use speaker wire to connect the amp to the speaker.
Jul 26, 2014 | Audio Players & Recorders
Kenwood KX-79 CW dual cassette hook up?
Just connect the deck via tape 1 the out of the deck going to the in of the amp. While the out of the amp goes to the in of the deck.
The tape deck itself will automatically choose the player that plays the cassette. One will play the other will be on pause (if you press both play buttons) till the tape stops then the other will play. For recording from tape to tape one deck will be the copy and the other the copier. There should be a dubbing button which you press to record tape to tape. Some models have a high speed dub also. For recording from the amp unless both decks have record buttons you will only be able to record with one deck. Make certain the dub button is not set.
Dec 25, 2013 | Kenwood Audio Players & Recorders
I need to know how I can hook up my Teac EQA 5 equalizer to my Sansui AUD 9 power amp.. I lost the manual to the E/Q
It is very easy, you don't need a manual for this. The EQ line in and Line out get hooked into the record out and Tape in of one of the tape loops on the Sansui amp. Record outs go to EQ in and the EQ out goes to tape play.
Oct 10, 2013 | Sony TC WE435 Stereo Dual Cassette Deck...
Tape reel on either deck stops and tape gets jammed. This is on a Tascam dual cassette deck model 322.
Try replacing the belt, because when the belt is a bit old it looses its elasticity and it can't drive the whole thing properly.Tape A and Tape B works independently.
Jul 25, 2010 | Tascam 322 Advanced Dual Well Single...
How to hook up equalizer to the amplifier
always remember source, amp, then speakers. ex: cd to eq to amp to speakers and it goes: out from cd player into eq, out from eq into amp, out from amp into speakers . hope this makes it easier for you.
Jun 23, 2009 | Sony TC WE435 Stereo Dual Cassette Deck...
Gemini Sound Products EQ-3000 equalizer
please connect as the following-----1-mp3 out-----to cd in in your receiver.
2-receiver rec out (tape put)----to equalizer in.
3-equalizer out----to tape in in receiver.
Sep 17, 2008 | Gemini Sound Products EQ-300 Home...
Onkyo TX-DS676 Receiver Logo
14 people viewed this question
Top Onkyo Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you an Onkyo Audio Player and Recorder Expert? Answer questions, earn points and help others
