Question about Maytag Dishwashers
Touch Pad & Control Panel Replacement (part #8269461) - Whirlpool Dishwasher Repair
  • 3422 Answers
SOURCE: I have a Maytag QuietSeries
HI,
Just visit this link HERE and your problem will be solved.
Goodluck,
Please don't forget to rate the solution.
Posted on Apr 04, 2008
  • 132 Answers
SOURCE: maytag dishwasher MDBH940AWW. ''Touch Panel'' is not working.
Hi There,
Try just replacing the Keypad. It is cheap and is usually the cause. Hope this helps and thank you for using FixYa!
Posted on Mar 30, 2009
  • 15 Answers
SOURCE: Panel not working on Electrolux Dishwasher
CONTACT ELECTROLUX. YOU EITHER HAVE A FAULTY TOUCH PAD OR A BAD RIBBON CONNECTION.
Posted on Apr 07, 2009
SOURCE: Touchpad--No Response
See the notes about cycles taking forever. The relay that controls the heating element commonly gets warm enough to melt the solder around the connection, and the internal water heater stops heating. The "2H" indicates how much time the onboard computer thinks it will take to wash the load, based on previous loads, but if the last cycle was longer than 99 minutes, it shows 2 Hours. Repairing the controller board (or replacing it) should solve the problem. This is such a common problem, Bosch should have had a recall, but didn't.
Posted on Aug 05, 2009
BMT60
  • 126 Answers
SOURCE: touch pad/control board not working?
PART NUMER 8193762 IS WHAT YOU WANT TO CHECK. YOU CAN SEE THE PICTURE OF THE PART AT REPAIRCLINIC.COM
Posted on Apr 24, 2010
Lights are blinking when trying to start frigidaire dishwasher
First, confirm that the display is working. If the display is still working, try pressing some of the touch-pad buttons. If some of the buttons respond correctly but others don't, it is likely that the touch-pad is at fault. (Some manufacturers sell the touch-pad separately from the control panel. Other manufacturers require that you purchase the touch-pad and control panel together. If you cannot replace the touch-pad individually, replace the touch-pad and control panel.) Frigidaire Dishwasher Lights Flashing or Blinking
Oct 28, 2017 | Frigidaire Dishwashers
Whirlpoool model du920pfgb3--touch pad is not responding and no lights or nothing are on??
Control panel. Try to push cancel button to see if it resets.if not google it and they will walk you through it.
Mar 28, 2013 | Whirlpool Gold 24 in. Built-In Dishwasher...
I have a whirlpool DU1145 dishwasher that seems to be stuck on the same cycle. It shows it as sensing and washing at the same time and never shuts off. HELP! WHat could becausing this??
Sounds like your Touch Pad on the Control Panel is defective.
You can try and remove the 120 Volt AC power from the Dishwasher by turning it off at your Main Electrical Power Panel with the Circuit Breaker (15 or 20 amp) labeled: Dishwasher .
Leave the Dishwasher turned "Off" for 10 minutes. This will allow the control circuits on the Dishwasher to reset. Turn on the Dishwasher and press Cancel and attempt to Drain the Dishwasher. If this works...then try to enter a Rinse Only cycle and if that works... then attempt to enter a Wash Cycle.
If you still have your original problems then you probably have a defective:
(1) Touch Pad Assembly (or possibly a defective)
(2) Electronic Control Module (ECM)
Mar 24, 2011 | Whirlpool Dishwashers
My whirlpool adp 5962 does pre rinse start button flashes I press it it goes to end then stops please help
This is a very common issue. The touch pad assembly would need to be replaced to fix the issue. This is a easy repair to make, the parts can be had from the link below as well. The screws around the touch pad need to be removed to complete this repair.
Appliance & Refrigerator Repair
Mar 23, 2011 | Whirlpool 24 in. ADP5962 Free-standing...
I have a Kenmore elite 13102 dishwasher touchpad that has begun to crack around the start button. Does this necessitate changing out the whole electronic control pad or is there a part that is the...
You will need to replace the touch pad assembly. You can purchase the part from the link below.
Kenmore elite Dishwasher Parts Link
You can read an article that explains how to make this repair yourself at the link below.
Mar 22, 2011 | Dishwashers
Start button wont respond
If all the other buttons work except the start button, you have a faulty touch pad that will need to be replaced. Below is a link to a video you will want to download so you can see how to replace the touch pad.
http://www.appliancerepairlesson.com/shop/dishwasher-videos/control-repair-whirlpoolkitchenaidkenmoremaytagjenn-air-amana-dishwashers/
Good Luck
Mar 01, 2011 | Whirlpool 24 in. DU1100XTP Built-in...
The start butoon flashes on off the whole time and beeps when door shut so that the machine never starts
Good Luck
Mar 01, 2011 | Whirlpool GU2400XTP Built-in Dishwasher
I have a Maytag Dishwasher model MDB8600AWS that the touch pad does not work. Is there a simple way to troubleshoot this touch pad before I buy the complete control panel.
My MDB8751AWB had the same problem.
I bought the replacement part for $265.
It worked for 2 weeks, then stopped working.
Frustrated, probably going to buy different manufacturer.
Whirlpool does not warranty the part if you do it yourself.
Jan 04, 2011 | Maytag 24 in. MDB8600AWS Jetclean II...
Touch pad not responding
We regularly repair such control units for customers nationwide by mail for $39.95 postpaid in about a week or so with a one-year guarantee.
At our Web site, we have a video available showing how to remove a typical over the range control panel assembly in under 5 minutes.
Feel free to contact me directly (and please remind me of your full model number from the tag on the unit) for more information & help.
William E. Miller, AS-EET
prototech@usa.net
http://www.microwavedisplay.com
Microwave Oven Control Panel Repair Nationwide
Nov 23, 2009 | Whirlpool GH6177XPS Microwave Oven
Replacing touchpad or control panel in our RBD305PDQ8 oven
F2-E1 - Touch Pad (Keypad) Cable Unplugged -
Check the connection between the touch pad (keypad) and control board (clock) to make sure it is secure.
Select the 'cancel' function and wait 60 seconds.
If error code reappears then replace the touch pad, or touch pad and control board (clock) if all one assembly.
It appears your timer/clock has failed in this instance.
For replacement parts - head on over to PartSelect.com or RepairClinic.com and enter in your full model number for a full parts listing.
I recommend both sites because ...
FixYa has no affiliation with either site - I have been using and recommending them for years - trouble free.
PartSelect has a great schematic database for locating the part on your unit and great "testimonials" for each part that often times includes HOW-TO information.
RepairClinic has pictures of each part they sell and also a great how-to and troubleshooting for basic repairs.
If your unit has never been serviced - there should still be an original service manual enclosed in plastic taped to the inside of the shell.
In the service manual are Error codes, maintenance procedures, and troubleshooting steps you can follow.
Anything too complicated or beyond your scope should be handled by a professional.
If you think you want to tackle the repair - and have gotten stuck on a step - reply to your question and I will be glad to help you out.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.&&&&&&&&&&&&&&&
Jan 25, 2009 | Whirlpool RBD305PD Electric Double Oven
Dishwashers Logo
53 people viewed this question
Top Maytag Dishwashers Experts
Charles T Nevin
Charles T Nevin
Mike
Are you a Maytag Dishwasher Expert? Answer questions, earn points and help others
