Question about All-Pro SPC-85 Utility Heater
Heater light but shut down after 2 minutes - All-Pro SPC-85 Utility Heater
Heater will shut down within minutes of igniting and say heater cool down mode
what does water temp show if over 104 replace temp sensor make sure filters are clean if you have a heater bypass make sure it is at least half way closed or possible manual bypass spring broken or if gas pressure too low heater is sooted up and overheating
Jan 03, 2016 | Jandy Lite 2 Natural Gas Pilot Light...
New lasko heater keeps shutting down
fatly over heat switch or tilt switch some r very picky
Dec 10, 2013 | Lasko Heating & Cooling
My confort zone infered heater comes on for a few minutes then shuts down
Does it shut off heater with lights and fan on or power off? Did you bypass the temp sensor or thermostat? If temp sensor that mounts above filter, see http://www.fixya.com/support/t15119324-comfort_zone_cz2011_heater_shuts_off .
Feb 14, 2013 | Comfort Zone CZ1500WC Infra-Red...
Heater turns on and heats 2-3 degress then the service heater light comes on.After about 1 minute the heater fires back up and the light goes out and it repeats this cycle until it up to set temp.
Your "bypass valve" may be wide open, which causes the heater to overheat and shut down till it cools off. Just after the filter there is a pipe, then a valve, then another pipe.Close the valve at least 1/2 way (if not more). This will force water through the heater and keep it from overheating.
Oct 28, 2010 | Sta Rite Pool & Spa
After about 10 minutes the entire heater shuts down pilot light and flame.
IF YOU WOULD LIKE TO KNOW, MY PLAN WILL COST YOU FIVE SMALL INSTALLMENTS OF $20.50.
Thank you
Dec 12, 2009 | Vanguard International Blue Flame - Large...
I have a lasko tower ceramic heater that keeps shutting down.
mine does the same thing every year. I just clean out the dust from the vents on the back of the heater so the heater can breath otherwise it could get too hot and the safety fetcher kick in and makes the heater stop working.
Oct 19, 2009 | Tower Lasko 30 Inch Ceramic Oscillating...
Will light and run for about ten minutes then shut down
the home heating fuel will gel thus the heater will shut down
Jan 16, 2009 | Reddy Heater-170,000 BTU Kerosene Deluxe
All-Pro SPC-85 Utility Heater Logo
63 people viewed this question
Top All-Pro Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
T bone 1963
Are you an All-Pro Heating and Cooling Expert? Answer questions, earn points and help others
