Question about NexAira Nexconnect 3g Wireless Broadband Router
I cannot log into the software using the default password, first time user
    New Friend:
  • 35 Answers
First try a different web browser. Sometimes there are security features that block you from logging in. Before you do the next step make sure that you can connect to the router meaning you see the dialog box that says "this is router such and such please enter your username and password" If you still cannot get into it and you absolutely have too, then do a factory reset on the router, you will lose all of the setting though.
Posted on Mar 31, 2014
Which Default Passwords Are Used on S Series Switches?
On the S series switches of all versions:
· When you log in a switch through a console port, no default user name or password is provided. The system asks you to set the user name and password when you log in to the switch for the first time.
· Before you log in to a switch through Telnet, create a Telnet account.
· You can set the Telnet login authentication method in the VTY. If the password authentication mode is configured, set a password in the VTY. If the AAA local authentication mode is configured, set the user name and password in the AAA view. If the remote AAA authentication mode is configured, set the user name and password on the AAA server.
May 27, 2016 | Huawei Computers & Internet
How do a forgotten admin password on a xerox 7655
WorkCentre 7655 7665 7675 Online Support Solution Modify the Printer...
Solution : Modify the Printer's Administrator Password Using CentreWare Internet Services (CWIS) NOTE: This solution assumes the WorkCentre is configured and working properly on the network.
  1. From the computer, open an Internet browser window.
  2. Enter the IP address for the WorkCentre in theAddressfield, and then press [Enter] on the keyboard. The CentreWare Internet Services window will be displayed.
  3. Click on the [Properties] tab.
    NOTE:If the Login screen is displayed, enter the user name in theUser IDfield, and the password in thePasswordfield, and then click on the [Login] button.
    The default username is "admin" (case sensitive), and the default password is "1111". If it has been changed or forgotten, contact Support.
  4. Click on [Security] to expand the list of options.
  5. Select [Authentication Configuration].
  6. Click on the [Modify] button for Device System Administrator Password.
  7. Enter a new password in theNew Passwordfield.
  8. Retype the password in theRetype Passwordfield.
  9. Click on [Save]. This will be the new password to log into the Control Panel and CWIS.
http://www.support.xerox.com/SRVS/CGI-BIN/WEBCGI.EXE?St=143,E=0000000004704152929,K=9646,Sxi=4,Case=obj(3814)
Solution : Modify the Default Admin (Tools Mode) Password on the WorkCentre NOTE:The Admin (Tools Mode) password allows access to configure network and machine settings on the printer.Xerox recommends only changing the default Admin (Tools Mode) password if absolutely necessary. If the password has been changed from the default password (1111) and has been forgotten, a service call is required to reset the password.
To change the default Admin (Tools Mode) password:
  1. Press the [Log In / Out] button on the Control Panel. The Log In window will be displayed. See theRelated Itemsbelow for additional information regarding logging into the WorkCentre.
  2. Select [Security Settings] on the left side of the screen.
  3. Select [Authentication] from theGroupscolumn and then select [User / Administrator Accounts] from theFeaturescolumn. The User Administrator screen will be displayed.
  4. Select the [Account #] field, and then select account number 1 using the keypad on the Control Panel.
  5. Select the [Configure Account] button. The Configure User Accounts screen will be displayed.
  6. Press the [Clear C] button (several times, as required) on the Control Panel to clear the old password.
  7. Enter the new password using the keypad on the Control Panel.
  8. If necessary, place a check mark in the [System Administrator (Admin)] and [Account Administrator] check boxes, and then select [Save Account].
  9. Select [Close].
  10. Press the [Log In / Out] button on the Control Panel.
  11. Select [Logout] on the Touch Screen.
Apr 04, 2014 | Xerox WorkCentre M-24 Color Copier
What to do ,can't log on password required
You can salvage your old user account by logging on as the "Administrator" user. Once you're logged in as the admin, you can reset your old user password. The Administrator user (by default) is similar to a "superuser" and has the highest access level to reset any user password.
If you don't know what your Administrator password is, you can reset that by rebooting into Safe Mode.
The best option here is to reset your account password. You can do this using either 1 of the 2 methods suggested by Microsoft Knowledge Base article #321305. In my opinion, the second method described on this page is most likely the easiest route: Reboot Windows in Safe Mode. Click Start, and then click Run. In the Open box, type the following command, and then click OK: control userpasswords2 Click the user account that you forgot the password for, and then click Reset Password. Type a new password in both the New password and the Confirm new password boxes, and then click OK.
Side note: To access Safe Mode, Click Start -> Shutdown (or Turn Off), and choose 'Restart'. Once the computer restarts, press F8 repeatedly on the keyboard until a Boot Menu appear (this *must* be done before the Windows boot screen appears). Finally, choose to boot Windows in Safe Mode and press Enter on the keyboard.
You can reset a lost or "forgot Windows password" with 4 methods below:
1. Another valid administrator account which can normally log on.
2. A password reset disk or a repair disc, which is created in advance ( before you lost password ).
3. Third-party software to create a bootable password reset CD/DVD or USB, like "Windows Password Breaker".
4. Re-install. Will lose data.
Feb 22, 2011 | Microsoft Windows XP Professional SP2
I kept password for my administrator account..but when iam logging the computer it does not asking password...and directly opening the windows...i wants to keep windows should enter the password on windows...
1) Go to Control Panel on the start menu.
2) Double click on User Accounts.
3) Then under the Pick a Task heading select Change the way users log on or off.
4) Tick the box next to Use the Welcome screen.
5) Then click apply. Password or not when your computer starts up it will take you to the welcome screen where the user can select which account they want to log into.
Jan 31, 2011 | Microsoft Windows XP Professional
Lost my administrator password, how do i remove it? i now have only bio scan access.
are you using windows XP if you are log into safe mode tap f8 upon powering the system till you get windows advance menu select safemode, in safemode log in try logging in as admiistrator leave password field blank if it logs in go to control panel and click user accounts change or manage user accounts select you log in with the lost password change the password or better remove the password then restart system log in using the user name u normaly use if it log directly that is good then ccreat a new password under that account profile ^_^ this should work but for vist and win7 it might be imoissuble to log into an administrator account you must at least know the password if you created one if not then reinstalling vista and win7 is the final option ^_^
Jun 05, 2010 | Alienware PC Systems Alienware M17...
How can i made admin password in WBR 2310?
in your explorer bar
type 10.0.0.1
log on as ADMIN
Password Admin or 1234
add new user when logged on
create your password here
make new user the default user
'write down log on details and password too
open a second explorer bar and log in as new user for testing
if working save your settings and close explorer
open in admin mode then try new user mode
admin probably wont work now new user is the default user so everything should be working now
cheers Misterdj
Apr 18, 2010 | D-Link 802.11g Wireless Router WBR-1310...
Need password to internet
You can't.
What you can do is reset the entire router. There should be a button on the back you can press in with a paper clip, hold it down for a few seconds, lights should flash.
Your router will then be reset to factory defaults. Without any more information I can not tell you how to find the default user/pass to log in.
Apr 08, 2010 | Computers & Internet
Default password is incorrect or reset doesn't work
The default ip is 192.168.1.1
default user-name and password for the 5 models of 3com are as follows.:
1.
3com default ip: 192.168.1.1
username: n/a
password: admin
or
2.
user-name: adminttd
password: adminttd
or
3com default ip 192.168.1.1
user-name: admin
password: n/a
or
user-name: n/a
password: PASSWORD
OR
5
user-name: root
password: !root
ok try
this
Note that at time you will need to set your local ip of your pc from which you are acess the device to the same range...
That is for example 192.168.1.10
Good luck
uttam
Feb 26, 2010 | 3Com 2816-SFP Plus (3c16485-us) 16x1000...
I can not remember my password so i can use my wi fi. So how do i reset my password. i can log on to the router can i change it in the settings?
Reset
Pressing the Reset button for 5 seconds restores the router to its original factory default settings.
Log in to the Router
This section will explain how to log in to your router using the following steps:
1. Launch your web browser.
2. Enter the URL http://192.168.1.1 in the address bar and press Enter.
A login screen like the one below will be displayed after you connect to the user interface.
Note: There are three account types, each requiring a different username and password.
• The user account provides limited access to certain configurations (username / password: user / user).
• The admin account can perform all functions
(username / password: admin / admin).
• The support account is for ISP technicians for maintenance purposes
(username / password: support / support).
Note: Passwords can be changed at any time.
3. Enter your user name and password, and then click OK to display the user interface.
Note: This manual has been prepared using the admin user name
Aug 20, 2009 | D-Link ADSL2/2+ Modem/Wireless Router...
Comtrend ADSL2+ Router CT-5621T
there's quite serious security problem with this routers (not sure if it applies to exactly this type)
if your password if not the default you should try other account:
(username / password)
admin / admin
support / support
user / user
if you are logged in as a "user" you can't change anything but you can access change password page e.g.
http://192.168.1.1/password.html
then open source code of this page and inside javascript code you will find your password in plain text
<!-- hide
pwdAdmin = 'admin';
pwdSupport = 'support';
pwdUser = 'user';
Oct 19, 2008 | Computers & Internet
NexAira Nexconnect 3g Wireless Broadband Router Logo
42 people viewed this question
Top NexAira Computers & Internet Experts
David Payne
David Payne
Are you a NexAira Computer and Internet Expert? Answer questions, earn points and help others
