Question about Bowflex TC1000 Treadclimber
Am getting a e1 code on my bowflex - Bowflex TC1000 Treadclimber
MY TREAD CLIMBER STARTS THEN STOPS AND FLASHES E1 ACROSS THE SCREEN
This is probably a faulty speed sensor or the speed sensor is not plugged in properly. Its also possibly a faulty motor control board or lower board. The error codes will differ between makes and models but could be e1.
http://www.youtube.com/watch?v=TquYcOzGIw4&feature=related
http://www.youtube.com/watch?v=9G4MZh8JO2Q
http://www.youtube.com/watch?v=M7qJrRbdfBc
http://www.youtube.com/watch?v=MIIxoPtvhy8
hthttp://www.fixya.com/support/r10724803-measure_voltage_in_transforme_fitness http://www.youtube.com/watch?v=bF3OyQ3HwfU&feature=related
Watch this videos and tip.
You must concluded if the inclination motor is faulty or Main Motor Controller Board is faulty.
Oct 18, 2011 | Bowflex TC1000 Treadclimber
E1 error code
hi,
You have to check the speed sensor inside your machine. There will be two wire from the control board to the lover side of you machine. At the end of that wire you can see the speed sensor. Which will be placed near the motor pulley to count the rpm. Clean the sensor and remove and reinstall the white connector in that wire.
ok
Jun 19, 2011 | Bowflex Treadclimber
Our TC 1000 stopped. We get the Error Code E1 when we try to turn it on. There is no sound or any movement. I don't know where to start. Help.
hi
ur treadmills speed sensor have some problem. pullout it clean it and then refix it. also check its white connector , is its connection is proper or not. if the sensor found faulty replace it.
ok
Dec 20, 2010 | Bowflex TC1000 Treadclimber
My bowflex treadclimber goes slow/fast/slow again and stops. It then shows an E1 on the display. What can I do to fix this? I have no directions for trouble shooting. Also, should I be able to speed...
The speed sensor is not connected correctly. There should be a jumper wire that runs from the speed sensor over to a harness by the control board on the other side of the machine. There may be a second jumper wire connected to nothing, only used in the 3000/5000 models. There is also a wire that comes from inside the treadles that isn't used on the 1000. The current assembly manual available from bowflex online seems to explain it better.
Oct 26, 2009 | Bowflex TC1000 Treadclimber
Bowflex tc 1000 treadclimber
TC1000 from Bowflex, works okay for 15 mins then the speed surges ahead and stops dead with error E1
Jun 28, 2009 | Bowflex TC1000 Treadclimber
Error Code E1
I had the same error message E1 at 10 seconds according to the LCD display on an older Treadclimber TC1000. I called Bowflex 1-800-792-6784 and first thing they told me was to check the drive sensor on the back left corner of machine. It is two wires connected by 2 white connectors that snap together. The end of the sensor has a rubber cap that is supposed to be approximately 1/8 inch from the drive pulley. The rubber cap plugs into a small hole within the "firewall" of the drive pulley, but the end of the cap does not actually touch anything. They can email you a picture of it. If it ever gets knocked loose, the machine will register this e1 error, in some cases- hope this helps.getattachment.aspx&hm__qs=file%3d3d2f2ee0-2668-46ea-b32c-db049d56cb37.jpg%26ct%3daw1hz2uvanblzw_3d_3d%26name%3daw1hz2uwmdiuanbn%26inline%3d1%26rfc%3d0%26empty%3dfalse%26imgsrc%3dcid%253aimage002.jpg%254001c99c08.13bd6320&oneredir=1&ip=10.12.128.8&d=d6608&mf=0&a=01_0b590aaade5e800af268d347750ab151eca93264be20cd9ce2166e583b18cfe9
Jan 24, 2009 | Bowflex Treadclimber
Bowflex TC1000 Treadclimber Logo
18 people viewed this question
Top Bowflex Exercise & Fitness Experts
Electro Med Services...
Howard
Howard
Glenn Mayer
Glenn Mayer
Are you a Bowflex Exercise and Fitnes Expert? Answer questions, earn points and help others
