Question about Keurig Signature Coffee Brewer w/ My K-Cup & 36 K-Cups -3 brew sizes: 6, 8, 10oz
Water is not coming out
Makes a popping noise when you lift the top
  • 1,511 Answers
Check to see if the fill tube is aligned correctly. That is the needle like projectile that penetrates the Kcup from atop. If is it slightly bent it catches the plastic lid when opeing.
Posted on Feb 22, 2014
Cooker makes popping noise when off
It\'s possible you have a slow leak through one of the rail cocks ( gas taps) lift off the top and spray lightly some soapy water on the end of each of the rail cocks if it bubbles you have found the leak.
Apr 13, 2014 | Rangemaster Classic 110 (Dual Fuel) Dual...
How do you take the back off the machine?
You don't, The front sides and top come off as 1 piece. Under the control panel there are 2 clips that you pop off,ddisconnect the door lid switch plug. lean the cabnet foward,( take notice of how the bottom sits on the base) and lift off the cabnet. When you put it back make sure that the water level hose didnt come off, you have water all over the floor. Good Luck
Sep 24, 2011 | Roper RAS8445KQ Top Load Washer
I am getting a LOUD grinding noise when I turn the T9820 on. I can't find the two plastic caps to remove to pop the top. How do I get the top open so I can check the belt?
disconnect your duct from it temporarily. see if the grinding noise goes away. Some installers are using the foil flex duct on these dryers and it makes a horrible noise. it sounds like marbles rattleing in a coffee can. It is called cavitation. it should be connected with semi ridgid 4 inch ducting, that comes in 3 foot sticks, not the slinky looking stuff that comes in a small box.
to remove the lid, take a dental pick or a sharp knife, pry out the two oval plugs on each side of the lid to expose the t 20 lid screws. loosen each screw 10 turns and push in on the screws. this will disconnect the hidden clamps. do not remove the screws. you will drop the clamps in the bottom of the dryer. you have been warned. if the lid will not lift up after 10 turns, go another turn or two, but check often by lifting the lid. when you have released the clamps enough, lift the lid up and push it back towards the wall three inches. now remove the lid.
Nov 30, 2010 | Miele T9820 Gas Dryer
Making a loud noise when agitating almost sounds like a grinding noise but still washes okay
The noise would be indeed coming from the water pump.
To clean the pump on this top-loader you have to unplug it, pop the top open, and remove the front face of the cabinet to expose the motor and pump.
Slip off the two metal clips hugging the pump to the motor. Place a towel under the motor before detaching the hoses - there's a plastic drip pan between the pump and motor to guide the water away from the motor.
Unclamp the two hoses from the pump by squeezing their spring-clamps with pliers and sliding them further down the hose. Pull the hoses off by lifting the pump off its axle and pulling it out while wiggling the hoses loose. Check if anything jammed in the pump - it must have fallen to the outside of the basket but inside the drum during the last spin cycle, and went down the drain hose. Check the pump for damage and replace if necessary.
For future troubleshooting, remember that a clogged pump causes squealing, diminished spin speed, and slow drainage.
Feb 27, 2010 | Whirlpool Washing Machines
What would make my washing machine leak water and make a funny noise?
this sounds like the main bearings have worn out (they start to rumble first) when they start to brake up they rip apart the water seals that are between them and the back of the washers drum, and then it starts to leak water, to test them to see if there claped out,,,, open the door and try lifting the top of the drum lightly , if it lifts a bit then drops back when you let go its the bearings going, now spin it by hand and you will here a rumbleing noise or grinding noise, when the washer is running on spin it will sound like the end of the world is coming???? im sorry to tell you this part is not cheep to fix, its 2-3 hours work?
Oct 22, 2009 | Kenmore Washing Machines
Water pump is makeing a squeeling noise, I want to dissassemble it to see if something is inside the pump
The noise was indeed coming from the water pump. To clean the pump on this top-loader you have to unplug it, pop the top open, and remove the front face of the cabinet to expose the motor and pump. Slip off the two metal clips hugging the pump to the motor. Place a towel under the motor before detaching the hoses - there's a plastic drip pan between the pump and motor to guide the water away from the motor. Unclamp the two hoses from the pump by squeezing their spring-clamps with pliers and sliding them further down the hose. Pull the hoses off by lifting the pump off its axle and pulling it out while wiggling the hoses loose. I found a small sock jammed in the pump - it must have fallen to the outside of the basket but inside the drum during the last spin cycle, and went down the drain hose. Check the pump for damage and replace if necessary.Always remember that a clogged pump causes squealing, diminished spin speed, and slow drainage.
However Open the washer lid to gain access to the agitator. Depending on your model, lift the fabric softener dispenser off the top of the agitator. Some models only have a cap that lifts off the top.
Remove the barrier cap and the o-ring by pulling them out with your hands. Inspect the o-ring for damage and wear. Replace it if necessary when reinstalling the agitator.
Remove the bolt that attaches the agitator to the clutch in the middle using a socket wrench. Lift the agitator out of the washer. Some models, like Maytag, have a flex vane agitator which requires it to be lifted off bell housing. This is accomplished by inserting two screwdrivers opposite each other between the tub and the agitator. Lift up to remove from the bell housing.
Turn the agitator over to reveal the cogs that are in place. Remove the cogs from the agitator by snapping them out.
Thanks for contacting Fixya.com
Sep 29, 2009 | Maytag Legacy Series Top Load Washer
Washing machine making loud noise when agitating/spinning
The noise was indeed coming from the water pump. To clean the pump on this top-loader you have to unplug it, pop the top open, and remove the front face of the cabinet to expose the motor and pump. Slip off the two metal clips hugging the pump to the motor. Place a towel under the motor before detaching the hoses - there's a plastic drip pan between the pump and motor to guide the water away from the motor. Unclamp the two hoses from the pump by squeezing their spring-clamps with pliers and sliding them further down the hose. Pull the hoses off by lifting the pump off its axle and pulling it out while wiggling the hoses loose. I found a small sock jammed in the pump - it must have fallen to the outside of the basket but inside the drum during the last spin cycle, and went down the drain hose. Check the pump for damage and replace if necessary. For future troubleshooting, remember that a clogged pump causes squealing, diminished spin speed, and slow drainage.
Jun 29, 2009 | Westinghouse Washing Machines
MAGIC CHEF WASHER SPINS WATER OUT MAKING CRAZY NOISE & THE WATER GOES OUT ON THE FLOOR. WHAT'S WRONG? DOES THE PUMP HAVE TO BE REPLACED?
could be.pop the top and take off frount cover.run unit and look where water coming from.could alos inspect pump the pully dose come off on those an then drag metal to metal but normaly no water leak.also could be a bad tub seal you would see leaking from under neath
Dec 31, 2008 | Magic Chef CAV2000AWW Top Load Washer
Whirlpool dryer at least 10 yrs.old
belt broke remove 2 screws under lint screen release clips under edge of top on each corner by pressing in with putty knife..lift top remove screws upper corners each side top ..disconnect door switch connector lift front off install 341241 belt per diagram on bag
Jul 30, 2008 | Dryers
Frigidaire LEQ332DSO Squealing Noise
sounds like rear bearing is dry you will need to remove drum to get to it pop clips in top and raise 2 phillips scews 1 in each side remove front remove belt from drum lift drum up in rear and remove ck to make sure plastic bearing is not worn down to metal bracket if it is it will need to be replaced
Jul 07, 2008 | Frigidaire GLER341A Electric Dryer
Keurig Signature Coffee Brewer w/ My K-Cup & 36 K-Cups -3 brew sizes: 6, 8, 10oz Logo
165 people viewed this question
Top Keurig Coffee Makers & Espresso Machines Experts
Lisa
Lisa
Jason
Are you a Keurig Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
