Question about Whirlpool GY397LXUS Stainless Steel Electric Range
Hot surface indicator light won't go out only on one burner
4 Suggested Answers
  • 1314 Answers
SOURCE: Burner heating when it shouldn't.
change the switch contacts sticking
Posted on Apr 02, 2008
  • 53 Answers
SOURCE: the indicator light will not turn off after
Usually this means a burner switch is bad. Once in awhile the sensor on the burner goes bad, not often. You need to lift the top and measure each burner, checking voltages and ohms to see if it's the switch or the burner sensor.
Posted on Oct 13, 2009
Testimonial: "thanks."
  • 160 Answers
SOURCE: hot surface indicator light stays on. the knobs
signs of a faulty hotplate sensor especially if the surface is cold
Posted on Mar 21, 2010
Hot surface indicator light stays on despite the burners being off overnight
There is a switch in the burner assembly that senses the burner is hot. It could be the sensor switch is bad. It also could be the surface switch itself that has a welded contact that is causing the hot surface light to stay on. i would look at the thermal switch on the burner itself first.
Mar 22, 2015 | Kitchen Ranges
Are there problems with the kenmore 36-in. radiant cooktops 42749 hot surface indicator lights?
Most likely the problem is in the heat control switch.Cannot be repaired you will have to replace it. To make sure, swap it with one of the other burners that do not have the problem. If the problem goes away, you know its the switch.
Aug 08, 2014 | Kenmore 36 in.42741 / 42742 / 42744 /...
The burners light indicator stays on even when the burners are turned off
Here is a tip that I wrote about the problem of the cooktop light staying on.
Oven Hot Surface Indicator Light stays on heatman101
Apr 23, 2011 | Microwave Ovens
The surface light on my mothers stove stays on and all burners are off and cold any ideas why
Here is a tip that I wrote about why the hot surface indicator light will not go out...
heatman101
Jan 18, 2011 | Maytag Cooktops
Indicator light stays on when eye(s) are turned off
The stove indicator light normal stay on until the burner cools off, and then the indicator light goes off, this is to prevent someone from touching the burner, alerting them that the stove is still hot.
Dec 11, 2009 | Kenmore Kitchen Ranges
GE EVOLUTION Glass top. The hot surface(Glass top)
Individual burners, located directly under the cooktop glass, contain a temp sensor which lights up the hot surface lamp when they sense a hot condition. If the light stays on after all burners are cool, one of the sensors has shorted out. The sensors are an integral part of the burner, so the offending burner must be replaced to solve your constant on hot light.
Jul 01, 2009 | GE Kitchen Ranges
I have a new ge range. When I turn on the left
mvek,
If you could see through the glass, you'd see "temperature sensors" located near the elements. They're very sensitive little guys, and rightly so! Their job is to detect temps and energize the warning light on the cooktop so users won't get burned.
To answer your question... It appears that there is an issue with the front left sensor (and possibly the right as well). The temp warning lamps should NEVER go off immediately. Please call for warranty repair (1-800-GE-CARES). This is an unsafe condition for you and your Family. The warning indicators are there for a reason and should indicate high temp's as long as high temp's are present.
SG
Apr 11, 2009 | GE Kitchen Ranges
GE Spectra JBP30B0B4WH surface unit light stays on
If it's the light that indicated the element is on, replace the switch. If it's the light that indicated the element is hot, replace the element.
Jun 05, 2008 | GE Spectra JBP78 Electric Kitchen Range
Cooktop light stays on when cool
no your not doing anything wrong. the unit has a fault. you should call your nearest warrenty agent
Mar 08, 2008 | Kenmore 95002 / 95004 Electric Kitchen...
Surface unit indicator light is always on
Coffy, if you are talking about the hot surface indicator lights, they are controlled by the limiter on the burner itself. When the burner heats up the limiter closes and sends power to the light (hot surface). When the burner cools the limiter is supposed to open cutting power to the hot surface indicator light. They may be stuck closed. If you are talking about the lights on the back panel, that is controlled by the infinate switch itself. Catriver
Oct 09, 2007 | Kenmore 96012 / 96014 / 96019 Electric...
Whirlpool GY397LXUS Stainless Steel Electric Range Logo
26 people viewed this question
Top Whirlpool Kitchen Ranges Experts
Dan Webster
Dan Webster
Ismael Rodriguez...
Are you a Whirlpool Kitchen Range Expert? Answer questions, earn points and help others
