Question about SanDisk 4GB microSDHC Memory Card
Buenas noches,compre una microSDHC de 4GB y acepta copiar los 4gb pero al leer solo reconoce 1 gb de lo almacenado,digame por favor que puedo hacer
    Sergeant:
  • 369 Answers
Please can you translate to english .
Posted on Jul 12, 2014
4 Suggested Answers
Ranjit Mohan
  • 30 Answers
SOURCE: HELP w/ Sandisk 4GB MicroSDHC Memory Card with SD Adapter
1.May b U hav a problm wit ur Computer Driver so try to reinstall it..
2.Take a backup of ur MC & Format it Restore it.
Posted on Jun 03, 2009
  • 4 Answers
SOURCE: I just bought a SanDisk 4GB microSDHC card at
What is your operating system? What is your card file system? If your operating system support FAT file system then check your memory card reader. If all is ok then try it with your data cable of your phone.
Posted on Jun 08, 2009
bschilz
  • 2049 Answers
SOURCE: my sandisk 4gb microSDHC card has write protection
SOLUTION 1 - Unlock the memory card.
There is a Lock switch on the left side of the SD card. Make sure the Lock switch is slid up (unlock position). You will not be able to modify or delete the contents on the memory card if it is locked.
SOLUTION 2 - Toggle the lock switch.
If the lock switch is not on lock:
1. Slide the switch up and down. Repeat this 3 times.
2. Let it stay on the Lock position for 30 seconds.
3. Slide the switch up to unlock the card.
4. Try to transfer files into the device.
Posted on Aug 09, 2009
Envie un mensaje ZONG AL 7557 SOLICITANDO Powers Tokens, 1 transaccion estuvo bien efectuadas, luego una quedo fuera de Linea, fue cobrada, mas no exitosa. Despues me llego un mensaje a mi telefono celular...
buenas noche no kiero ser grosero pero e enviado dos mensaje y me cobraron 11.60 y kiero k me los debuelban por k la conpra k ise no se realiso y si no me los dan yo los denuncio
Aug 25, 2011 | zong.com
No funciona solo aparece ecipse y es todo
A mí me pasa lo mismo y lamentablemente nadie aporta una solución, el mío (Eclipse 180 8GB)se ha quedado trabado en la pantalla azul de inicio con el logo "Eclipse" y no sé que hacer. Un tipo en las respuestas en idioma inglés dice que llamó al número de atención al cliente y le dijeron que dejara que la batería descargara por completo y luego presionara por unos 30 segundos el botón "Play" (me imagino que es el botón del centro, supuestamente es la manera de resetear el player) antes de conectar el USB al PC. No sé si funciona. Mi problema empezó por una canción que no tocaba bien y reinicié el aparato, y puse de nuevo la misma canción y luego se puso el logo azul en la pantalla y éste no se quitaba a menos de mover el switch a OFF, lo pase nuevamente a ON para que descargara por completo, pero ya no lo reconoce la PC y pide drivers, se queda congelado en el logo, ni carga, ni nada.
He visto que muchas personas tienen el mismo problema y todavía no aparece ninguna solución, tú post es el primero que leo en español. Dicen que será un problema de firmware, pero no venía con un CD de drivers o una herramienta para estos casos, la empresa Mach Speed parece que todavía no tiene una página de soporte implementada para este modelo "Eclipse", también no sé como destaparlo, pues la tapa es una sola pieza. Si sabes como solucionar tu problema, házmelo saber por este medio. Talvez es de esperar, porque el firmware que tiene mi player era de septiembre del año pasado y lo compré en noviembre, el precio es bajo, pero no es posible que nos tomen el pelo de esta manera.
Feb 10, 2011 | Mach Speed Eclipse 180SL 4GB MP4 ...
He formateao mi portatil sin hacer antes copia de seguridad de los drivers, ahora me falta controladora de bus sm, controladora ethernet y pci device, no me puedo conectar a internet porque no reconoce la...
Ir a la >>>> drivers at softpedia dot com >>> y descargar los controladores para
Acer Aspire 5610 LAN Driver 9.25.0.0
Estos son los controladores que necesita para obtener en Internet, pero hay que ponerlos en una USB o un CD para instalar. Una vez en la Internet, puede obtener el resto de su l?nea de controladores. Descargar un programa llamado Speccy, de Piriform dot com. Se le dir? exactamente lo que usted tiene equipo para obtener los controladores para. Buena suerte a mi amigo.
Dec 09, 2010 | Acer Aspire 5610 Notebook
Tengo problemas con un Multifuncional HP Laserjet M1522, por alguna razon empezo marcar ERROR 5 Y NO PUDO INICIALIZARSE el SCANNER , Funciona como impresora pero no como copiadora o Scaner, , parpadea la...
59c05df4-3e41-4402-8674-16fa865682b6.jpg1e27574a-853d-43f0-83e9-639f0eb8015f.jpg6f9cb0d0-efc0-4725-b485-113c15667e78.jpg639e37f6-dbca-4b87-baf4-9919d68a26d4.jpgf319f64c-35bb-4a4d-b11b-3637a94260fd.jpgdf4c7415-80c2-478b-9083-7ef214ae9172.jpg027f0e9b-f662-4bc9-916c-d62c423d9e73.jpga1eea8bc-2311-4ede-b6b1-2b036b38dc64.jpg7ada6481-ced7-4dab-b710-09760d6b9498.jpg04f42b95-4eec-4796-8556-1ef7ab6cddbe.jpgHola amigos, tambien tengo este problema con una impresora, reinstale el firmware y no funciono, lo que note es que el motor estaba quemado, lo desarme y lo rebobine, compre el alambre me parece que fue calibre 33, aprox 25 mts, 260 vueltas con una resistencia de 10ohms por bobina. bueno despues de esto lo monte y funciono un poco mejor. pero al parecer es la tajeta logica pregunte a un proveedor de hp y su valor es de aprox 3000 pesos mx, lo que hice es hacerle un agujero al escaner.
Detalles.
viendo de frente el escaner del lado izquierdo le hice un agujero de 3mm. y le puse un cincho largo(pueden usar algun desarmador, el cincho se lo puse doble para que no se doblara, el cincho debe entrar con facilidad pero no muy olgado para que no se doble, al introducirlo no es necesario sacarlo ya que el carro lo sacar, es por eso que no debe quedar apretado). esto me permite mover el carro del escaner a lo posicion "0". posicion de partida y hubicacion de la banda indicadora(Empujarlo unos 3 cm aprox, despues solo se calibra).
La finalidad de esto es de manera manual regresar el carro, se apaga y se vuelve a encender y listo. funciona nuevamente.
Este error me aparece despues de haber utilizado el ADF, el cual el carro se mueve al lado izquierdo para poder escanear automaticamente los documentos. posteriormente no puede regresar.
Aqui pues es donde le podemos ayudar a regresar a su posicion original.
Espero que les ayude en algo.
Aug 29, 2010 | HP LaserJet M1522nf Multifunction Printer...
MI PROYECTOR EMPIEZA A ENCENDER Y SE APAGA.
buenas noches. tengo un problema con mi proyector.. hace unos minutos encendio y se veia la imagen pero luego lo desconectaron y cuando volvi a encender solo prende la luz de power pero no sale la imagen quen podra ser???
Aug 29, 2009 | Dell 2200MP Multimedia Projector
Hola tengo una camara webcam creative live, cambien de computador y no me lo acepta que puedo hacer gracias por tu ayuda
hola melivaob...
aquí tienes un enlace a la página de drivers para webcams de Creative, no creo que el modelo que tienes aparece en la lista principal, pero abajo de todo hay otro link que te lleva a otra página donde puedes elegir entre muchos... pero muchisimos!
a la derecha de la página principal hay un elace encima de los imagenes de los cams que pone 'aprende a identificar su producto'... si la segunda página te parece difícil... vuelve a la primera y siga el enlace para poder saber exacatmente lo que buscas.
lo haria por ti, pero no tengo bastante información para hacer la búsqueda.
espero que eso te ha ayudado, y avisame si tienes alguna otra pregunta...
bru*
Feb 02, 2009 | Creative Labs WebCam Live!
Luis
el problema es que no tengo los driver de sonido de salida de audio
qure usted que me los podria proporcionar de gratis
Oct 03, 2008 | Computers & Internet
Ayuda para desbloquear
buenas tardes tengo un tv modelo HTV-2115 y tiene un candado rojo en la esquina inferior izquierda el canal no lo deja de mostrar y donde deberia tener la hora aparecen las rayitas no me deja usar el control sino para apagarlo y de los botones laterales solo lo puedo apagar como puedo desbloquearlo sino me da acceso al menu ni con el control ni con el menu lateral. darme respuesta al messnger viittoria1997@hotmail.com Gracias es de Venezuela
May 24, 2008 | Televison & Video
SanDisk 4GB microSDHC Memory Card Logo
195 people viewed this question
Top SanDisk Computers & Internet Experts
Sandy Moore
Sandy Moore
Cleverer2
Are you a SanDisk Computer and Internet Expert? Answer questions, earn points and help others
