Question about RCA L26HD35D TV
Powers up - white picture with lines and no sound
On initial power up you get a very faint white noise from speaker, then goes dead. picture flickers with black and white lines of varying widths
    Top Expert:
  • RCA Master
  • 74,185 Answers
Sounds like a min board fault. Contact any service technician. If you wish to get some details; check the site linked here. Viewing it in "Mosaic" will make surf easy.
Posted on Feb 14, 2014
Dell inspiron one 2305 black screeen with one flashing light
Dell Inspiron One 2305 (all-in-one) that will not power on. ... to reboot, I saw a faint white flashing light and heard a faint clicking noise. .... but I still have the black screen and my 2305 model remains essentially "dead".
Apr 18, 2014 | Dell Inspiron One 2305 Desktop Computer...
Tv powers on but no picture or sound
Take a flashlight, dim the lights in the room and shine the light on the panel with the set on. If you see a faint picture, you have a backlight problem. If you indeed do not have a picture or sound, you could be looking at a bad power supply or main board
Sep 08, 2013 | Samsung LN37A550 37 in. HDTV LCD TV
My LTV-32w6 westinghouse powers on & has sound but displays black screen with very faint colored vertical lines. It shows like this for about 1min before it goes into standby mode & the blue power...
Depends on what is causing it...
Vertical bands of faint black are generally caused by filtering capacitors and can be found in the power supply or the 5 volt supply or even the Video processing circuit...it is not an easy task to identify the source of Video hum bars.....we also call them Jailbars.
Another problem seen is faint black lines caused by the TV set being in 4:3 mode all the time....right at the edge of where the picture ends and the black pillars begin, we see a faint black line that never goes away and is normally seen with a full screen....
That is actually image retention, but it's caused by the crystals that create the picture becoming polarized or ionized over a very long period of time....and it's not easy to DE-Polarize them !
But there are some theories out on how to do that....
Certain people suggest running the TV overnight with an ALL-WHITE picture and some suggest an ALL BLACK PICTURE...and some suggest alternating between both !!
Now, a black picture is easy to make, you just deactivate the Video Mute (blue screen) and set it to an unused Video INPUT overnight....
About the only way to make a white screen is to use the USB port for pictures and take a very bright outdoor shot of a piece of white paper that hopefully is out of focus too....That would create an all-white picture that you can plug into your TV set overnight....
Now if you decide to try this, deactivate any displays on your TV set...all you do is press the display button until the Video and/or USB input numbers disappear....
Next day , set it back to normal TV and see if it's gone or if it's REDUCED....try it again if needed, or try the exact opposite if you see NO RESULTS....
Sep 20, 2012 | Westinghouse Televison & Video
At first the screen went dim but you could faintly the picture no sound through the main speakers but wireless headphones still worked then everything went dead the disk would not turn. the red light...
looks like you have a cold solder/loose board on the power supply section of the unit.try resoldering first and post a comment how it goes..let me know ..thank you..
Feb 17, 2011 | XO Vision Televison & Video
I got s panasonic projection HDTV Model#- Pt-47WX53G When turned on there is a solid red light on the power button, no blinks at all, and no picture at all.... I have no sources hooked up to it but it...
I HAVE A VERY GOOD IDEA OF WHAT IS WRONG.
after a few minutes do you see a faint band of noise top to bottom on the screen at the middle or towards the right side of screen?
It will not be easy to see, but if there I know what part is bad.
SD TECH
Sep 18, 2010 | Televison & Video
When tv is turned on picture flickers really
When it goes black can you see a ghost image? It will be a normal tv picture but very faint black and white looking, you may have to get close and look at an angle to even see it. If so that means your backlight system is failing. If you don;t see an image then it is a problem with the power section of the board inside the tv.
Check if it is covered by warrenty and get a quote if it isn't. A 42 inch is new and big enough that it should still be worth repairing but it may cost you anywhere from $100 to $250 depending on the shop to fix.
Apr 12, 2010 | Vizio GV42L 42 in. LCD Television
I have a Sony icf 2010. No sound, but white noise.
AA batteries need replacing or the contacts are corroded and one more, the PC board is connected to the AA negative post by a wire that touches the pad on the PC board. Sometimes it will lose contact because of oxidation or corrosion, to fix this a wire soldered is best but just repositioning the wire will make the cure. Requires removal of the circuit boards.
Jan 20, 2010 | Sony ICF-2010 AM/FM/SW Radio
TV will power up
sounds like a bad power pack, blown capacitors most likely.
it can be replaced or the caps can be soldered into the board to replace the bad ones.
Mar 29, 2009 | Akai LCT2715 27 in. LCD Television
White screen say heat run after a power failure
Was it the house power flickering or the tv poping off and on? If the house power you may have damage in the tv. Try unplugging it for 20 minutes and the plugging it back in. May need to be reset......If this doesn't help, it will need to go to the shop.....
Feb 10, 2008 | Curtis-Mathis CM27101S TV
Green television screen on a princess tlevision
can you clarify that are you seeing white bright lines on screen & is there faint picture with green color?
Sep 16, 2007 | Televison & Video
RCA L26HD35D TV Logo
63 people viewed this question
Top RCA Televison & Video Experts
matt martin
matt martin
Computer Repairing
Computer Repairing
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
