PROGRAMMING CODE FOR REMOTE CONTROL FOR MAGNAVOX
josh1856
  • 105 Answers
SOURCE: programming code for remote control jensen jr321
I am not 100% positive that the JR-321 is supported in the 300 series but.
Jensen JR300 manual - If you cant get it to work using one of these codes it does not support your unit.
http://157.254.235.130/public/IBJ34500SE.pdf
or
http://157.254.235.130/public/J3_4_500_MANUAL_S_E.pdf
Hope that helps!
Posted on Jan 30, 2008
robotek
  • 1512 Answers
SOURCE: Programming a RCA Universal remote to a magnavox tv
Hi tinalynn1071
I couldn't find the book anywhere for you,but did find a guide on programming RCA universal remotes, and a list of standard codes you may wish to try:)
regards
robotek
Posted on Jul 16, 2008
ronaldsuboc
  • 449 Answers
SOURCE: programming remote to phillips magnavox tv
hi!!!!
this might be help
click here
Posted on Oct 31, 2008
chessmaster2
  • 160 Answers
SOURCE: Remote control code for Magnavox 15MF605T/17
oif the codes in setup don't work for the direct tv remote, here is a code list at the end of the post
Great News!! We can program most Philips Universal Remotes with Automatic Code Searh. Here's how it works on most of our remotes.
Programming with Code Search
1. Manually turn on the device (TV, VCR, etc.) to be controlled.
2. Press and hold Code Search button until the red indicator stays on. Release the Code Search button.
3. Press and release the desired mode button (TV, VCR, etc.). The red indicator blink, then stays lit.
4. Press the Channel Up button repeatedly (up to 300 times) until the device could be controlled changes channel. The red indicator blinks, then stays lit. If you accidentally overshoot the code required, press the Channel Down button to backtrack through the library until the device changes channel. Pressing Channel Up changes direction to forward again. Press and release the Mute button to install the code.
The above assumes that you want to store the VCR you want under the VCR but, Cable codes under the CBL, etc
Note: if the device does not have a chat channel at a button, you should Play (VCR only) or Power instead.
Here is a Code List on PDF that shoud be universal for most remotes. It worked for me.
http://www.remotecodelist.com/remot...ps-Magnavox_PM525S.pdf
Hope this helps you out, good luck.
Posted on Dec 02, 2008
SOURCE: Sky TV Remote Control Code For Vistron 40" TV Required
please can you tell me code for vistron 32 hd from ebuyer got part of it working can not get sound to work , thanks
Posted on Jul 22, 2009
I have two RCA remotes. 1st RCU 310 5538P. 2nd RCU 400 2420BB.
Remote Control Support - RCA ' Made for Moments
www.rca.com/support-remotes
RCARemote Control Support. Select your Type of Remote. Remote Code Finder ...RemoteProgramming. Cable/Satellite Receiver Codes. Select Your Provider.
RCA Universal Remote Control- Target Programming ...
www.thompsontv.com/rcarc.html
RCA Universal Remote Control-Programming Codes. ... Universal Remote. The remotemay already be set up to operate your brand of TV, VCR, or Cable Box.
Program an RCA Universal Remote Without a "Code Search ...
www.wikihow.com > ... > TV and Home Audio > Television
wikiHowHow to Program an RCA Universal Remote Without a "Code Search" Button. Do you have an older RCA universal remote that you want to use, but it lacks a ...
Jan 23, 2016 | RCA Televison & Video
How do i set a code on a philips tv/dvd remote if there is no :code search: button?
Look on the remote manufacturers site for instructions on how to do this. It is usually a combination of button pushing sequences to get it into programming mode.
Jul 21, 2014 | Televison & Video
Rca universal remote control crcu4601wm
Programming procedure is too much to type in here, and is not practical. If you wish to get more; check the site linked here. It has set-up code list & set-up procedure to many popular brand remote controls. See it in "Mosaic" view. It will make surf easier.
http://electrohelponline.blogspot.com/
http://electro-medical.blogspot.com/
Mar 05, 2014 | Magnavox Used Original CMWD2206 Remote...
Code for magnavox
Hello
Three digit universl remote codes for Magnavox are:
004/ 008/ 009/ 062/ 068/ 069/ 074/ 075/ 076/ 077/ 089/ 133/ 163/ 165
183/ 184/ 208/ 213
Four digit universal remote codes for Magnavox are:
0062 0004 0009 0456 0183 0226 0288 0008 0068 0075 0141
0054, 0179, 0030, 0020, 0024, 0096, 0186, 0171
Direct Code Entry
  1. Press and hold the SETUP button until the red indicator stays on, then release the SETUP button.
  2. Press and release the desired Mode button (TV, VCR, etc.). The red indicator blinks, then stays lit.
  3. Enter the 4 digit code from the code tables. Note: after a valid code entry, the red indicator turns off. For an invalid code, the red indicator flashes.
  4. With your device on, press CHANNEL UP. If the device responds, no further programming is required. Note: If some buttons do not operate your device, try one of the other codes for your brand
Jul 09, 2011 | Universal Remote Control Remote Control
I NEED TO PROGRAM A MAGNAVOX TV WITH A PHILLIPS UNIVERSAL REMOTE CONTROLL
Find codes and methods here.
http://www.docstoc.com/docs/23925020/Programming-Remote-Control-Brand-Codes-TV-Sets
If those codes dont work try the last three(or four) numbers of your TV's serial number.
On my universal remote is just a matter of holding down the TV button till the light stays on, then punching in the three digit TV code. When the TV turns off it's the right code. But read your manual for your controller.
Oct 08, 2010 | Universal Remote Control Universal IR...
Hi tinalynn1071
regards
robotek
Jul 15, 2008 | RCA RC-U703SP Remote Control
Programming Problem
Try the Philips codes as well...
Jun 09, 2007 | RCA RCR450 Remote Control
Televison & Video Logo
11 people viewed this question
Top Televison & Video Experts
