Question about Panasonic TC-P50X1 50 in. Plasma HDTV
Part of screen is black
Screen works fine except one section towards the center is blank
What is the reason for my E701i-A3 failure? All boards were replaced, worked for a minute, and then had the same "fade to black" failure as the first time.
Your back light controller board or the ballasts for them may be bad if they weren't incorporated into the power supply board.
Dec 05, 2016 | Televison & Video
Black Screen in Defector mission of COD7 (Black Ops)? In Call of Duty black ops, in Defector mission, after pushing the door, car explodes and screen goes to black but sound remain properly. I have the ps3...
I just had this problem. The screen was blank, except for the direction and compass in the right hand corner, but the sound is still there. Seems to be a bug. I simply shot up a few people, went to the door, waited about 4 seconds without pushing the door, then just before the car came towards us, hit the square but to help push. Then it seemed ok. If you push from the start you may find the screen goes blank.
Dec 28, 2010 | Activision Call of Duty Black Ops
My nokia 3600 slide screen kept blank.all of it works fine except the screen
If everything is fine except your screen, bring it to a technician and have them check first the flex wire.
If your flex is fine then the last thing will be your LCD. have it replace
Nov 04, 2009 | Nokia 3600 slide Cellular Phone
Blank Screen
I had this problem on my 42" Philips. Just got it yesterday and worked fine on the tv stand. As soon as I mounted the TV to the wall via wall mount system, I had the exact same issue you did. Figured it out today.
The wall mount was putting pressure against the center of the back of the tv (tv set had a slightly rounded back plate, and the mount was a flat plate). As soon as I put spacers (part of the wall mount hardware set) between the wall mount braket and the tv so there was no contact except at the mounting holes, the tv worked fine.
My theory is the pressure pushed the tv back plate against some board components which caused them to overheat (no air flow); or put pressure on internal connectors. I dont know.
Hope this helps, may not apply to your situation.
Sep 18, 2009 | Sony KDF-E60A20 60 in. LCD HDTV
Won't turn on or off screen is blank
I had this problem for about 3 hours except that it was a totally blank screen. Unscrew the back of it and take the battery out for about 10 seconds. Put the battery back and it should reset totally. Don't worry about the songs, they'll be fine.
Mar 10, 2009 | SanDisk Sansa View 8GB MP3 Player - Black
LCD Display Blank
I have a sony cybershot DSC-S650, the LCD was very dark and could not see anything except if I pointed it at a bright object, everything else worked ok. I could take pictures but could barely see them in playback as well.
I took it to Sony authorised repair outlet and was told the CCD was damaged, they charged me USD $55 to repair it (in Quito, Ecuador)
Jul 31, 2008 | HP Photosmart R607 Digital Camera
Shrinking screen.
hi there, you do have a vertical section problem and at the power supply section problem. do some test, check for some cold solder at the power supply section, test some electrolytic capacitor at the vertical section. ty
Jan 01, 2008 | Televison & Video
Screen only showing single line of video in center.
hi there, is the single line horizontally or vertically? if horizontal line, you do have a vertical section problem, check some parts at vertical section, the vertical ic, the power source of vertical section ie diode & resistors. ty
Dec 26, 2007 | Zenith Z32X31D 32" TV
Black blank screen
If you cannot find a solution to your problem you may want to email fixityourself@gmail.com. He has good advice and good used parts at a fair price.
Oct 20, 2007 | Sony Cyber-Shot DSC-S40 Digital Camera
Weird problem not convergence
Mine is doing the exact same thing! have you found a fix yet?
Apr 23, 2007 | JVC AV-48WP74 48" Rear Projection...
Panasonic TC-P50X1 50 in. Plasma HDTV Logo
20 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Demonic-2011
Demonic-2011
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
