Question about Dyson DC44 Animal Cordless Vacuum
DC14 Carpet Selector Knob
I need to change out the clutch on my Dyson DC14. All the instructions say to pry it off. I have tried very hard to pry it off to the point that I am afraid I will break it. Any suggestions?
chrispurs1
  • 372 Answers
SOURCE: replacing clutch drive belt dyson dc14
Hi.
There are 2 belts on the Dyson clutch unit which can both be replaced.
Its a lot to discribe so try this site for dyson service manual.
http://dysonmanuals.inc.io/
Chris..
Posted on Dec 13, 2007
SOURCE: My dyson dc14 not sucking only from the hose
Hi- I have the same problem: suction fine, but the brushbar was not spinning. I went 1st to the Dyson site and went thru their troubleshooting guide and I'd done all those things, so I called Dyson (1-866-MY DYSON in the USA) and they walked me thru a very simple solution.
What worked was to "rest" the bare floor/carpet adjustment, and it's very easy! You do this by clicking the carpet to bare floor adjustment back and forth at least 5 times. Make sure when you end it's on carpet. Then tilt it back all the way from the upright position so it's flat on the floor and turn it onto it's left side. The carpet indicator should be below the word carpet. THAT WAS IT! As soon as I turned it on again, the brush bar is spinning great! I wish I could tell you right now how well it picks up, but unfortunately I took out the filter and rinsed it, so I have to wait until tomorrow to **** anything up. However, I'm sure it will work now that the brush bar is moving. Like I said, the suction was fine.
Just as an FYI--If you call, they will have you try other things to rule out other problems 1st. I had already done all the things suggested in their troubleshooting guide on their site and the only additional thing they asked me to try was to turn it on and tilt it back as though you are going to vacuum and make sure the suction from the top tube had stopped, as it normally does, and mine did.
Hope this helps!
Liz
Posted on Oct 28, 2008
SOURCE: dyson dc14 has no suction and burning smell
The guide suggest that you change the belt by putting it around the brush, through the plate, and then try to push it around the spindle, which has a space between it and the casing. I spent an hour trying to do this and couldn't get enough purchase to get the belt around the spindle. Instead I put it around the spindle first, and then through the plate, and then through a screwdriver to hold it in place. I then got the brush and put the band over the brush, rotating it until it went into the groove. I then reassembled. It worked, and I now realise how powerful that brush is. Hope it works.
Posted on Jan 06, 2009
SOURCE: Dyson suddenly hard to push on carpet
I know this sounds silly, but it works. Turn it over and wipe all the black residue off the bottom of it (off the plastic on the bottom that rubs on the carpet as you push and pull it). I thought my husband was out of his mind when he told me that was the solution, but it really works.
Posted on Jul 10, 2009
VacuumRepair
  • 438 Answers
SOURCE: I have a Dyson DC14
This sounds like your roller brush has stopped spinning for some reason. Turn the machine upside down when set to carpeting, and make sure the handle of the vacuum is down, as if you were in the vacuum posistion, and not up like the handle is when you're storing it.
Is your brush roller spinning? If it's not, there are two kinds of agitator brushes on the Dyson DC14, each has it's own troubleshooting.
If your beater brush is perfectly rounded in shape, then you have the newer style Dyson DC14 that doesn't use a clutch mechanism. Either belt has broken, or falled off, and is causing the brush not spin. Here's instructions with a pictorial on how to fix this problem;
Step 1. Unplug the vacuum cleaner.
  • Lay the machine flat on the floor and turn it over so that the base can be viewed.
  • Use a coin to turn the three soleplate fasteners and remove the soleplate as shown.
  • Check the brushbar for blockages and ensure the brushbar is rotating freely by hand.
  • If a blockage is present, carefully use a pair of scissors to cut away any hair and fibres from the brushbar ensuring you do not cut any of the bristles on the brushbar.
If the roller brush still doesn't spin after checking and removing any obstructions, then you need to replace the belt (or clutch if you have the early models). Here's a video that explains how to replace the clutch mechanism on Dyson vacuums;
If this failed to fix your problem, or if you have any other problems or questions, please feel free to just reply using the comment box below, I'm always happy to answer anyones questions or concerns. I hope this helped you. Please do be sure to rate my repair, or leave feedback for me if this helped. This is greatly appreciated by the Fixya community.
Chris Jones
GoVacuum.com
Posted on Jan 06, 2011
How do I fix the carpet brush on my dyson dc14 vacuum?
this is what is is broken it is the clutch Dyson clutch belt assembly for DC07 amp DC14 900252 04 473
most likley needs to be changed it is also a good idea to change the roller brush at this point also
Dyson Dc 07 14 33 Upright Models oem 904174 01
Jun 12, 2016 | Dyson DC14 Animal Bagless Upright Cyclonic...
Dyson DC28 - when using this in "carpet mode", I can hear and feel tons of suction being pulled through the wand, even though the wand is properly stowed as the handle for "carpet mode". And when this...
There's no switch per sey, but there is a clutch activation knob, on the right side of the base, as you're standing behind the unit. There should be a Carpet or Hard floor setting, just two. Twist it to change from one to the other. However, all this is meant to do, as far as I know, is to turn on the brush roll or turn it off, by means of a clutch system. I don't think it has anything to do with the wand assembly.
Oct 21, 2013 | Dyson DC14 All floors Bagless Upright...
How to change the drive belt on a dyson dc14 allergy vacuum
There are 2 belts on a Dyson DC14 if the Dyson has a clutch. If it has a clutch you have a knob on the machine that turns the brushbar on and off. Most of the DC14s have this.
You are far better replacing the whole clutch and its not really too har a job to do.
click this link to watch how its done
http://www.videojug.com/film/how-to-replace-the-clutch-on-a-dyson-dc04-dc07-and-dc14
Oct 25, 2010 | Dyson DC14 All floors Bagless Upright...
Older dyson dc 14 control knob for swithing from carpet to floor
Most likely you need to replace the clutch assembly. This video will show you how to replace it.
May 26, 2010 | Dyson DC14 All floors Bagless Upright...
The brush wheel will not go around?
make sure the carpet/floor selector switch is in the carpet position. if that is good then you probably have a broken belt. Unfortunately a complete clutch assembly will have to be installed. Just the belts cannot be changed
Apr 08, 2010 | Dyson DC14 Animal Bagless Upright Cyclonic...
I cannot seem to replace the beater bar on my Dyson - it seems to spin OK, but when I turn the vacuum back on and turn it to the 'Carpet" position, it makes a noise that is unbelievable. What's up with...
sounds like its the clutch to me if it sounds like a rapid clicking and you have a large knob on the side of the cleaner head it is going to be the clutch this is a hard part to changed without the know how to do it and it is very easy to break the orher parts when gettin to the clutch its not easy to explain how to do it on here if want to replace the clutch see youtube change dyson clutch hope this helps
Oct 29, 2009 | Dyson DC14 All floors Bagless Upright...
Brush on Dyson does not turn ....belt not broken
Hi.
Your machine has 2 belts one goes clutch to brush roller second is motor to clutch.
You need to remove the clutch unit from the machine & replace the motor to clutch belt.
Its A lot to try and explain try this site for help.
http://dysonmanuals.llc.nu/
Jan 06, 2009 | Dyson DC14 Animal Bagless Upright Cyclonic...
Brushes only engage after pushing way past the carpet selection.
I have the EXACT same problem. Did you ever get it fixed? What did you do?
Dec 29, 2008 | Dyson DC14 Animal Bagless Upright Cyclonic...
Dyson DC44 Animal Cordless Vacuum Logo
35 people viewed this question
Top Dyson Vacuums Experts
AskDyson
AskDyson
Samyfam
Samyfam
Are you a Dyson Vacuum Expert? Answer questions, earn points and help others
