Question about GE GTUP240EMWW Washer
Lights blinking, no spin, just stops. - GE GTUP240EMWW Washer
Ge he low h20 with precise fill wont spin out completely model gtwn5050mqws
Sounds like a motor or mode shifter issue. If you can access the motor area, there is an LED light on the motor. It will blink a series of blinks. there is a tech sheet located behind the control panel that will tell what the blinks mean. Hope this helps
Feb 22, 2015 | GE Washing Machines
Haier HLP21n blinking light error code.. Rinse and Spin lights blink...what does it mean?
This washer is a sanyo on the inside. When panasonic bought out sanyo and all its daughter brands, they started making parts not available for repairs. The service manual is here---> https://panasonic.encompass.com/shop/research_new/HAI/sm/HLP21N.pdf
This is also known as a sears proflex among other names.... haier-hlp21n-blinking-light-error-code-eqln1e0r5dvuapuxoxy4lmrd-1-0.jpg
Dec 09, 2014 | Haier HLP21N Washer
Spin light keeps blinking and I am unable to start wash cycle
we also need more information to try to pintpoint the problem
Jun 18, 2014 | managemylife.com
Lg washing machine f1068 ldp while washing stopped on spin and all spin lights are blinking
this could be the pump what you need to do is make sure the machine is off and down on the right hand side bottom of the machine there is a round cap clip it down then you should be looking at the pump turn slowly make sure you have a towel down there could be loads or some water coming out DONT undo it quickly OK very slowly until all water is gone then you can pull it out after turning it to pull it out if its all clear then you could have a motor problem but do the pump first OK let me know if this work OK don't for get to put the pump screw back tight OK
Oct 12, 2012 | LG Washing Machines
Infocus Screenplay 4805 No Display, help?
hi friend,
please try to clean the testing diode of color wheeel.
Jack
Nov 22, 2011 | InFocus ScreenPlay 4805 Multimedia...
What would stop a bush a126q washing machine draining, it just stops in the middle of a wash cycle?
hi i have a BUSH A126Q model W/M .Spin and Drain dosnt work. I clean the FILTER but same problem. Error code is Err 03. The start light & program ready light is blinking when M/C go to spin / Drain.
Its looks pump dont work //////
Please advise me what to do ???????????
Thanks
Mar 19, 2011 | Washing Machines
EZ3612 - spins for couple of times then stops with burning smell and mode light blinking 13 times
Per the service manual, if the mode light blinks 13 times, there's a bad dryer sensor or thermostat. I'm not sure if that related to your problem but it's a start.
Doug
Feb 24, 2008 | Equator EZ 3612 CEE Front Load...
Spin speed
If that light is blinking, it's because the spinssense is turned on. If you look at the lighted buttons all the way on the top right of the machine, one of them says spinsense under it. While the machine is running, press and hold that button for 3 seconds. You'll hear a little chime and the light should stop blinking. It's supposed to help vibrations on wood floors.
Oct 16, 2007 | LG WM-2277HW Front Load Washer
GE GTUP240EMWW Washer Logo
91 people viewed this question
Top GE Washing Machines Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a GE Washing Machine Expert? Answer questions, earn points and help others
