Question about LG Televison & Video
How to turn off a LG tv when the power button does not work
LG TV #32In5308 will NOT turn on using the on/off button on the remote or the on button on the rear of the panel. It is getting power, because an HDMI receiver is obtaining power from a USB connector,
Try just pressing a chanel number button, some tv's only turn off with the power button and to power them on you press either the chanel up or down button or one any of the number buttons on the remote
Dec 30, 2014 | LG 32LD350 32 in. LCD TV
No buttons work on LG 47LG5000. Neither remote nor the TV side buttons work but I can access all features by holding down 2 buttons for 15 seconds (eg. MENU and INPUT held together first brings up the...
check to make sure you have power to unit. If you do you may have a internal power problem. Have you gone thru a recent lighting storm? If so see your home insurance co. For coverage to repair or replace unit.
Feb 07, 2014 | LG Televison & Video
Need Time Warner Remote code for LG 42LB5D HDTV
For Time Warner Cable digital remote controls to work with your 42" LG HDTV, do the following:
1. Press "TV" and "OK" simultaneously for 3 seconds, until the button "tv" light on the remote is on.
2. Enter the TV code. In this case, it's "113". With the right code, your component will turn off. Quickly press the power button on your digital cable remote to turn it back on. Press the "TV" button again so that the remote saves that code.
3. You should be done.
Feb 08, 2010 | Directed 434MHZ Remote Control
Power Only
On the LG TV remote, press either the "return" button or the "exit" button, then press power to turn it off and then power to turn it back on again.
Fixed!
(This happens when some other device remotes send a strange signal to the LG TV, putting it in a service mode).
Dec 27, 2009 | LG 22LH20 LCD TV
Brand new LG plasma stuck on test screens
Resetting the TV
If the buttons on the remote AND the buttons on the TV case do not work (channels do not change and you cannot open or navigate the menu), the TV has stopped responding. Reset the TV as follows:
NOTE:
Some TVs have a reset button. If available and accessible, try using the reset buttons before using the steps below. Using the reset buttons can save time.
1. Unplug the TV power cord from the power outlet.
2. Unplug any connected devices (DVD, Set-top boxes, etc...)
3. Press and hold the TV power button for five seconds.
4. Plug the TV power cord back into the power outlet and turn on the TV.
5. Open the on-screen menu to confirm that the TV is responding again.
6. Turn off the TV and reconnect the devices.
7. Turn on the TV.
Hope it may help you;
Regards;
VOTIT
Jan 29, 2009 | Televison & Video
My LG remote control is not working
Make sure you push the TV button on the top of the remote before you push the power on button.
Dec 17, 2008 | Televison & Video
LG LCD and LG DVD remote codes
If both units are LG you don't have to program anything. Below the power button are 6 buttons labeled TV, DVD, etc. As soon as you push the DVD button the remote should work it. Remember to push the TV button again to make it work the TV.
Apr 20, 2008 | LG 42LC2D 42 in. LCD HDTV
Televison & Video Logo
11 people viewed this question
Computer Repairing
Computer Repairing
