Question about Garden
Sears snowblower 536887990
Won,t move in 6,5,4,forward speed
    Welcome Back:
    Visited the website for 2 consecutive days.
  • 28 Answers
Take the belly pan off, squeeze the drive lever and see if the friction wheel is contacting the disc. If it is, make sure there's no grease or oil on it. Seems to me if you're not getting any movement the friction disc may not be making no contact. I would also trace the cable and linkage to troubleshoot. Let me know what you find out.
Posted on Feb 22, 2014
Troy built storm 2890 snowblower slow in reverse
There is an inspection pan on bottom of snow blower remove the 2 or 4 bolts and drop pan
inside you will see an aluminum wheel (drive wheel) also a rubber faced wheel whitch runs on the aluminum wheel at a right angle (like a needle runs on a record on a record player.
Clean plate and rubber wheel using brake clean to degrease surface .
Also there is an adjustment to move the rubber wheel farther to the left for more reverse speed but in doing that you might lose top speed forward.
Mar 02, 2015 | Garden
How do I fix my snowblower when the wheels won,t move ahead or back
Sounds like gear on axle shaft broke shear bolt or key. Take bottom plate off base of snowblower.It is ok to tip snowblown up on front end so wheels are in air. After plate is off turn wheels and see if drive gear is moving with axle. If not key way or bolt has broken off, replace and will be back in motion.
Feb 18, 2015 | Craftsman Snow Blower / Snowblower Bottom...
Snowblower wont engage forward or reverse
Howdie ther is Clutch under the bottom of it that needs to be replaced take the cover off and you will see it
Jan 30, 2014 | Craftsman Snow Blower / Snowblower Bottom...
I have a 1999 Tecumsah Lawnboy 824E 8.0hp, model 28232, snowblower. Last snow the forward and reverse stopped working. The snowblower runs but the wheels locked up. I was able to get the forward and...
Here is a link that may help,ihttp://www.partstree.com/parts/?lc=lawn_boy&mn=28232. Adjust and lube the cables for drive engagement, and the other cables and Hiem joints. This usually will rectify the problem.
Apr 16, 2013 | Tecumseh Lawn Boy Push Mowers Insight...
My Craftsman 5.0 horsepower 5 speed forward, 2 speed reverse snowblower has a problem with the auger. After using it this morning working fine now the auger isn't turning. It's about 8 years old and has...
If the blower (impeller) turns and the auger doesn't there is a 90% chance you broke the shear bolts that protect the auger gear box.
Look at your auger and you will find the bolts shown at the arrows in this picture are missing. Some snowthrowers will have two bolts and others like the new Craftsman will have four.
You can get new ones at your local mower repair shop, your local Sears mall store, or online at sears.com.
Use shear pins or shear bolts not regular bolts. The shear bolts are designed to break off so you don't tear out the front gear box.
Feel free to ask any other questions. Don't forget to rate this answer!
Jan 12, 2011 | Craftsman Garden
Sears 10inch gas snowblower wont move but runs
You may have a bad clutch assembly. Check it and then see if the belt is tight enough.
Jan 10, 2009 | Craftsman 4 Cycle Blower/Vac
Garden Logo
47 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
john h
