Videocon tv 21" T.V. cut edges on screen, looks like I have zoom it.
    Top Expert:
  • Televison & ... Master
  • 74,666 Answers
Check and replace its CRT base connector socket. The focus connection to this socket, is bad. If you wish to get some details; check the site linked here. Viewing it in "Mosaic" will make surf easy.
Posted on Feb 14, 2014
3 Suggested Answers
  • 8 Answers
SOURCE: television picture looks too big for screen
Can you change mode to 4:3 or wide?
Posted on Jan 10, 2009
  • 360 Answers
SOURCE: Videocon tv ----on screen showing
Your panel is locked due to child lock. Procedure to unlock it may be given in the operating manual.
sonsunny
Posted on Jun 17, 2011
How do you adjust tv picture to fit entire screen
If you are connecting a computer to your TV and you are seeing the edges cut off it is most likely due to the zoom on your TV. First, make sure that your computer matches the resolution on the TV, then go into the TV menu and find the screen sizing setting and make sure it isn't set to stretch, zoom, etc.
Feb 07, 2016 | Televison & Video
Picture size
I found the user manual online, and the pictures in it are really helpful and make this make a lot more sense, but:
1. Press [SCREEN MODE], to switch the TV aspect ratio.
2. Press [SCREEN MODE] repeatedly until the normal screen displays.
NOTE: • Some programs may not offer all display mode options.
4:3 Programming
[Sidebar] Sidebar displays a 4:3 picture at its standard 4:3 size. Sidebars will be displayed on the right and left edges of the screen.
[Full] Full displays a 4:3 picture at a 16:9 size, with horizontal elongation necessary to fill the screen.
[Cinema] Cinema displays a 4:3 picture at a 16:9 size, with less horizontal elongation necessary to fill the screen because a little bit of the top and bottom edge of the screen will be cut off.
[Wide] Wide displays the center of the picture as original size and the outer sides of the picture will be elongated. The size of the picture will depend on the original signal.
16:9 Programming
[Full] A picture is displayed at 16:9 size as it is.
[Zoom] Zoom displays a 16:9 picture without changing its horizontal and vertical ratio, at its maximum size.
[Cinema] Cinema displays a 16:9 picture with vertical elongation.
[Expand] Expand displays a 16:9 picture with horizontal elongation
Source: LC320EM8 User Manual
http://www.manualslib.com/manual/47021/Emerson-Lc320em8.html?page=21#manual
May 15, 2013 | Emerson LC320EM8 32 in. LCD TV
The picture is outside the edges of the TV
It's probably an issue of the "Aspect" or the "Screen Mode" you're in. I'm no TV repair expert, but if you look in your Main Menu for "Screen Mode" or even your remote might have a button labeled "Asp" or "Aspect" or "Mode"....or even "Wide" (which when pressed repeatedly will cycle through the most common 4 screen modes = Wide, Screen Fit, Zoom, 4:3.) The last one refers to the ratio aspect, but depending on your TV, they could be named differently.
Given your description, it seems you're in "Zoom" mode, since it's cutting off the edges of the picture. Put it on a station like CNN, which has a streaming ticker at the bottom and cycle through the options you have until you find the one you prefer. (Note: you should also be able to set this in your Main Menu somewhere as your preferred view, but some shows and movies might come through as full screen or 'Letterbox' regardless of your preference.
One final observation I've found on several units is that the remote button that's in the bottom right-hand corner (which may not be labeled as such) is the default location for your aspect selections. Push it and see what happens.
Jul 22, 2012 | Philips 47PFL7403D 47 in. LCD TV
My Trinitron's mostly fine, though it's a few years old, but it has a strange display issue. It's almost as though the picture is "zoomed in" about 8%, cutting off about 1 to 1 1/2 inches of...
This problems u are having it is not the causes by the tv,because ur tv it is a analoge CRT tv,don't have this functions zooming in or out or the problems just causes only 8% cutting off edges of the tv pictures only.If the problem it is happening to ur analoge tv it will have no vertical hold at all.The devices u are connected to the tv and using have zoomming in or out buttons or ajustment buttons of the sizes of the picture on the screen.Used the devices remotes controls to readjust ur zooming or pictures sizes adjutment.
May 04, 2011 | Sony FD Trinitron WEGA KV-34XBR800 34" TV
My Sony KDL 46NX 700 is zoomed in so edges are cut. How to fix this? Thanks a lot
Press Zoom button on tv remote repeatedly to change screen aspect ratio/ zoom settings of picture that you wish to see.
Thanks.
Dec 18, 2010 | Sony Bravia KDL-46V4100 46 in. LCD HDTV
The direct tv menu guide is cut off around the edges...how do i fix?
Your TV resolution is not set to the proper screen size for viewing it properly and it probably cuts off your tv shows too and you just don't see it. Press the [FORMAT] or [ASPECT] button on the remote. The option available to remove the horizontal bars is Zoom.
Nov 04, 2010 | Panasonic VIERA TH-65PV500 65 in. Plasma...
I cannot see football stats on bottom of screen. mitsubishi wd-62627 setting is hdmi 1080i standard. help!
either your TV or your cable/sat box(if any) is on zoom(enlarging pix). Look for buttons on both remotes that might say picture size or aspect something like that...Pressing these buttons usually cycle thru 3 or 4 size options. When in zoom center of screen is the focus and outer edges of pic are cut off.
Sep 11, 2010 | Mitsubishi WD62627 62" HDTV
The picture is wider than the screen so the edges are cut off.
The tv is most likely in a zoom mode, go to the menu screen and look for the picture options.
Jul 29, 2010 | Samsung LE40R73BD 40 in. HD-Ready LCD...
Zoomed screen on my TV
with remote control use Zoom boton, or enter to menu and seek for this option.
Oct 23, 2008 | Televison & Video
IMAGE IS ZOOMED ON SCREEN
use the format button, might be called screen size. You are looking at a format that the screen cannot show completely, I can cut the top and bottom off or make it widescreen and lose the edges on my TV
Feb 24, 2008 | Toshiba MD20F51 20 in. TV/DVD Combo
Televison & Video Logo
Top Televison & Video Experts
Electro Med Services...
