Question about Minolta bizhub 350 Black and White Copier
Touch screen not working
How to repair foto copy minolta touch screen not working . and how can i make trouble reset without touch sreen. please help me,
    Welcome Back:
    Visited the website for 2 consecutive days.
  • 8 Answers
Touch screen is not repairable only change
change your touch screen then use your machine
Posted on Feb 14, 2014
2 Suggested Answers
  • 1294 Answers
SOURCE: reset Minolta cs pro 3050 to Factory
Co920 - 1st cassette problem
Co910 - 2nd cassette problem
Co900 - 3rd cassette
Co950 - 4th cassette
Open and close the front after copier is ON,if the message is apper enter in the service mode,or pull out the cassette failure and work.
Service mode enter:press STOP - 0 - STOP - 1
Check the actuators in the cassette,feed rollers and the sensors.
Posted on Jan 29, 2013
Konica minolta di 3010 C0500
First open the right side cover where the image unit is located. Check the two latches that latch the door ensure they are not broken, especially the rear one. Then get a paper clip and stick the clip in the small hole on the right side of the control panel it will touch a switch. The control panel will go thru some screens when you see the screen with the copiers on it on the left side of the screen in the middle you will see a small "." When the dot appears touch 3 button. Then the machine will continue to the code screen. Press the Utility button you should see a new button "Maintenance Mode" touch it then touch trouble reset. The machine will again go thru screens will see the"." again do nothing. Should go ready to Copy. If the code comes back do not reset, you are messing with the Fuser the Hot part. Continuing to reset without a technician looking at and or replacing it, the fuser can catch on fire and that would ruin a perfectly good day.
Apr 03, 2014 | Konica Minolta DiALTA Di200 Copier
How can i reset konika minolta c0500
Feb 15, 2014 | Konica Minolta DiALTA Di200 Copier
Code problam c0500
Sir/mam,
Jan 22, 2014 | Konica Minolta Minolta Di351 DiAlta...
Konica minolta bizhub 350 touch screen not working
Remove the plastic cover located in the right side of machine near USB and LAN port,touch the reset micro switch,on the screen panel is displayed Touch panel adjustment and adjust the panel,press the Trouble reset and the Exit to return in copy mode.If necessary repeat the adjust.
Jul 21, 2013 | Office Equipment & Supplies
Minolta Di3510 cannot make copies error code Co500
mam/sir,
First check the right side cover where the image unit is located. Check the two latches that latch that door are not broken especially the rear one. Then get a paper clip and stick the clip in the small hole on the right side of the control panel it will touch a switch. The control panel with go thru some screens when you see the screen with copiers on it on the left side of the screen in the middle you will see a small "." when dot appears touch 3 button. Then the machine will continue to the code screen. Press the utility button should see a new button "Maintenance Mode" touch it then touch trouble reset. The machine will again go thru screens will see the"." again do nothing. Should go ready to Copy. If the code comes back do not reset you are messing with the Fuser the Hot part continue reset without a technician looking at and or replacing it can catch on fire that would ruin a perfectly good day
Jul 30, 2012 | Minolta Di3510f Bizhub Copier
Code C0500 for Minolta Dialta model AFR-14 means?
mam/sir First check the right side cover where the image unit is located. Check the two latches that latch that door are not broken especially the rear one. Then get a paper clip and stick the clip in the small hole on the right side of the control panel it will touch a switch. The control panel with go thru some screens when you see the screen with copiers on it on the left side of the screen in the middle you will see a small "." when dot appears touch 3 button. Then the machine will continue to the code screen. Press the utility button should see a new button "Maintenance Mode" touch it then touch trouble reset. The machine will again go thru screens will see the"." again do nothing. Should go ready to Copy. If the code comes back do not reset you are messing with the Fuser the Hot part continue reset without a technician looking at and or replacing it can catch on fire that would ruin a perfectly good day
Jul 18, 2012 | Minolta Office Equipment & Supplies
Machine minolta di2510 comes up with error code c0501
Mam/sir First check the right side cover where the image unit is located. Check the two latches that latch the door. Are they broken especially the rear one. Then get a paper clip and stick the clip in the small hole on the right side of the control panel it will touch a switch. The control panel will go thru some screens when you see the screen with copiers on it on the left side of the screen in the middle you will see a small "." when the dot appears touch the 3 button. Then the machine will continue to the code screen. Press the utility button should see a new button "Maintenance Mode" touch it then touch trouble reset. The machine will again go thru screens will see the"." again do nothing. Should go ready to Copy. If the code comes back do not reset you are messing with the Fuser the Hot part continue reset without a technician looking at and or replacing it can catch on fire that would ruin a perfectly good day
Apr 26, 2012 | Minolta Di2510 All-In-One Laser Printer
C00500 code what to do Minolta Di251 Thank you
Ispyvolvo, First check the right side cover where the image unit is located. Check the two latches that latch that door are not broken especially the rear one. Then get a paper clip and stick the clip in the small hole on the right side of the control panel it will touch a switch. The control panel with go thru some screens when you see the screen with copiers on it on the left side of the screen in the middle you will see a small "." when dot appears touch 3 button. Then the machine will continue to the code screen. Press the utility button should see a new button "Maintenance Mode" touch it then touch trouble reset. The machine will again go thru screens will see the"." again do nothing. Should go ready to Copy. If the code comes back do not reset you are messing with the Fuser the Hot part continue reset without a technician looking at and or replacing it can catch on fire that would ruin a perfectly good day
Aug 09, 2011 | Minolta Di251 All-In-One Printer
I HAVE A MINOLTA Di200f/Di251f/Di351f ERROR CODE CO500
First check the right side cover where the image unit is located. Check the two latches that latch the door are not broken especially the rear one. Then get a paper clip and stick the clip in the small hole on the right side of the control panel it will touch a switch. The control panel will go thru some screens when you see the screen with copiers on it on the left side of the screen in the middle you will see a small "." when dot appears touch 3 button. Then the machine will continue to the code screen. Press the utility button should see a new button "Maintenance Mode" touch it then touch trouble reset. The machine will again go thru screens will see the"." again do nothing. Should go ready to Copy. If the code comes back do not reset you are messing with the Fuser the Hot part continue reset without a technician looking at and or replacing it can catch on fire that would ruin a perfectly good day
Jun 23, 2011 | Minolta - DI200F Printer
Saya mendapatkan kode CO500 pada mesin foto copy saya Di 251 bagaimana cara mengatasinya agar mesin foto copy saya dapat berjalan seperti biasa
First open the right side cover where the image unit is located. Check the two latches that latch the door ensure they are not broken, especially the rear one. Then get a paper clip and stick the clip in the small hole on the right side of the control panel it will touch a switch. The control panel will go thru some screens when you see the screen with the copiers on it on the left side of the screen in the middle you will see a small "." When the dot appears touch 3 button. Then the machine will continue to the code screen. Press the Utility button you should see a new button "Maintenance Mode" touch it then touch trouble reset. The machine will again go thru screens will see the"." again do nothing. Should go ready to Copy. If the code comes back do not reset you are messing with the Fuser the Hot part. Continuing to reset without a technician looking at and or replacing it, the fuser can catch on fire and that would ruin a perfectly good day.
try this site for parts
Precision Roller Printer Toner Cartridges Parts and Supplies Office...
Mar 04, 2011 | Minolta Di251 All-In-One Printer
Minolta bizhub 350 Black and White Copier Logo
230 people viewed this question
Top Minolta Office Equipment & Supplies Experts
Norman  J Weimar Jr
Norman J Weimar Jr
CheckitRight
CheckitRight
David Burkhart
David Burkhart
Are you a Minolta Office Equipment and Supply Expert? Answer questions, earn points and help others
