Question about Husqvarna 1830EXL 30" 414cc Crown Series Two Stage Snow Blower
Drive linkage disconnected
Midpoint connection.
    Problem Solver:
  • 21 Answers
I will have to assume this is a chain if so you can buy what is called a master link to reconnect it. The size of the chain is usually printed or stamped on the side of it. You'll have to get a master link this size. Can probably find one in an auto parts store
Posted on Feb 14, 2014
1988 Dodge Ram 50 Automatic shifts into park reverse and neutral. But physically won't go into drive gears.
Disconnect shift cable from transmission linkage and try to manually put transmission in drive gear ( make sure wheels chocked/park brake on ). If transmission goes into drive gear, suspect a shift cable or shifter assembly problem. If you can't manually shift into drive gear by hand with cable disconnected, suspect internal transmission/shift linkage issue
Mar 10, 2016 | Dodge Cars & Trucks
My 1986 f150 4 wheel drive w/automatic transmission won't shift out of park even with all linkage disconnected
Your transmission is broken inside. There are shifting forks and linkage inside that jammed up - due to the delicate nature of the linkage, it is likely it bent. Remove the side plate the linkage bar hooks to and carefully remove plate to inspect for disconnected or bent linkage. If the plate won't come off, then the transmission will need to be disassembled to fix.
Feb 15, 2015 | Ford F-150 Cars & Trucks
How to repair the deck height linkage setup
Check under the mower that
a. The drive belt is connect to the Hydrostatic dive (back Wheels) and check the the link connecting the peddle to the drive is moving. Also check at the back of the mower that the drive disconnect is not pulled out. Back of the Mower.
Oct 04, 2014 | Husqvarna Garden
How to replace the shift linkage in the pontiac montana van
On that van, like many other GM front-wheel-drive vehicles, the shift cable goes through a bracket on the transmission to the linkage( the little metal arm). Where the cable connects to the linkage, there is a ball stud. It takes quite a bit of force to disconnect the cable from that. If it became disconnected at that ball without any other outside influence, the shift cable may need to be replaced. You can try pushing the plastic end of the shift cable back on to that ball stud ,it should click into place.
If the ball stud became disconnected from the linkage(little metal arm), the linkage would need to be replaced.
There should be a locknut holding the linkage to the transmission stud right above the range selector switch. If it came loose of there, you may need a new linkage, and to replace that nut
Jun 09, 2014 | 2001 Pontiac Montana
Replace throwout barrings location install rattle when in gear.
get a service manual on CD over on ebay for about 5 bucks. jack car way up, drop the drive shaft, disconnect shifter and clutch linkage, unbolt the bell housing from the transmission and remove, unbolt pressure plate and take off flywheel, have flywheel resurfaced and reinstall, install new clutch and pressure plate, replace throwout bearing, put transmission and bell housing back in, connect shifter linkage and clutch cable or hydraulic, put drive shaft back in and you are done.
Jun 29, 2011 | 1996 Ford F150 Regular Cab
How to remove the in door of a 1990 bmw 325i? And also the drivers door will not lock when i turn the key the other doors lock but the drivers door doesnt how should i go about fixing that?
Sounds like you need to replace the power door lock actuator for the driver's door.
E30 Models
  1. Remove the door panel and the water shield.
  2. Disconnect the wiring from the actuator. Remove the screws and pull the actuator off the linkage.
  3. When installing, move the actuator and linkage to the locked position.
  4. Connect the linkage to the actuator and loosely install with the screws.
  5. Compress the actuator drive to take out any play in the linkage and tighten the screws.
  6. Test the locks and install the door panel.
E36 Models
  1. Remove the door panel and water shield.
  2. On the front doors, remove the guide rail nut and pull the guide rail down. Disconnect the wiring and the linkage from the actuator.
  3. On the rear doors, remove the window and the access panel. Disconnect the wiring and the linkage from the actuator.
  4. Remove the 3 bolts holding the latch and actuator to the door structure.
  5. Install in reverse order using threadlocker on the bolts.
Mar 16, 2011 | 2003 BMW 325
Want ****.
Hello
Try this. Disconnect the transmission linkage under the hood at the
colum. Now try moving the shift lever,if it functions normaly,check the
linkage from the colum to the transmission to see if it is bent or bound up. If you still can't shift with the linkage disconnected,the problem is
inside the colum. The easiest fix is to get a used colum.
If you have a cable. Disconnect it at the transmission first. if it still won't
shift, disconnect the cable at the colum. If it shifts, replace the cable.
If not. You're back to replacing the colum. In either case, block the wheels, and make sure the linkage connection at the transmission moves freely. Hope this helps. Good luck.
Feb 02, 2010 | 1995 GMC Sierra C1500
Wiper motor does not work on my 1994 dodge intrepid?
REMOVAL & INSTALLATION
(I made images larger at the end of instructions)
See Figures 1, 2 and 3
0900c1528006ad4a.jpgFig. 1: Unbolt the wiper motor from the housing 0900c1528006ad4b.jpgFig. 2: A little maneuvering may be required to pull the motor out 0900c1528006ad4c.jpgFig. 3: Exploded view of the wiper motor and associated components that make up the wiper system
  1. Disconnect the negative battery cable.
  2. Remove the wiper arm and blade assemblies, then disconnect the in-line hose connections. Do not discard the in-line connectors.
  3. Remove the rear hood seal with the cowl top plastic screen. Disconnect the washer hose in-line connectors.
  4. Disconnect the motor wiring harness at the back side of the housing.
  5. Remove the four wiper housing module mounting screws, then remove the housing.
  6. Remove the nut and disconnect the wiper drive linkage from the motor crank.
  7. Remove the three motor mounting screws. Lift the motor and mounting plate out of the housing.
  8. Disconnect the motor harness grommet from the housing.
To install:
  1. Assemblethe linkage to the motor. Make sure that the crank fits over the D sloton the motor shaft. Tighten the mounting nut to 90-106 inch lbs. (11-14Nm). Be sure the motor is still in the park position before assemblingto the linkage; if it is not, temporarily connect the motor to thewiring and operate the switch to park the motor before assembling thelinkage.
  2. Position the wiper motor and install the retaining nuts until snug.
  3. Attach the linkage drive crank to the motor crank arm.
  4. Plug the wiper motor wiring back together.
  5. Install the wiper motor cover.
  6. Install the wiper arms and plastic cowl removed previously.
  7. Connect the negative battery cable and check the wiper motor for proper operation.
Copyright © 2002 Delmar, All Rights Reserved.
Jan 29, 2009 | 1999 Dodge Intrepid
4-wheel drive won't shift into gear
I take it you have the manual t-case shifter on the floor. If so check all your linkages from the shifter to the t-case, if all appears well, simply disconnect the linkage from the t-case and see if it moves if it does your problem is in the shift mechanism in the t-case. if it still wont move even while disconnected clean and lube the linkage. If this still doesn't do the trick. replace your linkage
Jan 10, 2009 | 2004 Chevrolet Silverado 2500HD
Husqvarna 1830EXL 30" 414cc Crown Series Two Stage Snow Blower Logo
Top Husqvarna Garden Experts
Phil Walker
Phil Walker
Roland W VanLue
Roland W VanLue
Are you a Husqvarna Garden Expert? Answer questions, earn points and help others
