Question about Boss Bx35 3 Way Electronic Crossover
How to install boss bx 35 3way crossover - Boss Bx35 3 Way Electronic Crossover
Which wire is + and -
The wire with the redline is +. If you open the crossover it is printed on the board.
Oct 29, 2015 | Boss AUDIO Tw 15 Tweeter - TW15 Micro Dome...
I have 2 peavey sp2 bx well I was pushing them really hard and blew the black widows. Now I have got a replacement and hooked it up and still no sound out of them. I do have the horns working but they...
The lamp bulb fusing is just on the horns. Check the Black Widows individually with an ohm meter for continuity. If the speakers themselves test OK, you most likely blew the crossovers. Peavey service (877-732-8391) can rebuild most of therir crossovers in house and they generally are cheaper to fix than replace.
Nov 02, 2014 | Music
Too much bass
What kind of EQ does your head unit have? You should be able to adjust it on your receiver. If not, I would install a simple crossover or even a preamp, that would give you more control over how much power is delivered at certain frequencies.
Aug 17, 2013 | Boss RIP-795 Car Audio Amplifier
It two crossover how to use it
from the audio out of your stereo connect it to the audio in of your crossover, then audio out of your crossover connect it to the audio in of your subwoofer amplifer, and the mid or high audio out of your crossover connect it to the your mid or high freq. amplifier, take note you have two audio out from your crossover don't interchange them to utilize the normal use of your crossover unit
Jun 10, 2010 | Boss Audio Bx25 2 Way Electronic Crossover
Engine noise
The rca is looking for a ground, therefore the easiest way is to go to walmart and for $20 buy a ground loop isolator in the car stereo section. Very simple plug in installation
Sep 16, 2009 | Boss Car Audio & Video
How to install a 7 band boss eq with no high input jacks
If you are using the low input to put high input in you can use a 22k resistor and a 10uf capacitor connected in series to the plus side of the speaker wires. This will bring down the signal level from the speaker to low input level and you will have a nice distorted free music.
Aug 11, 2009 | Boss Car Audio & Video
Boss audio
Either the radio is bad out of the box (Very possible with the BOSS brand) or you car has factory amplifiers that need to be turned on. This is aaauming ther sound system played prior to the installation of the new radio. Most vehicles you can power up the amplifiers simply by connecting the BLUE remote turn on wire in the harness, but can get tricky in some vehicles.
Post the year make, and model of your car, and I can shoot you some odds/info about factory amplifiers.
Aug 07, 2009 | Pioneer DEQ-7600 15-Band Car Equalizer
I dont know how to install tweeters
only if they have a crossover attached if you dont they will blow up!
Jan 21, 2009 | Boss TW-25 Car Tweeter
Help me with my system
More information is required to start solving your problem. (ie. your make and model of "1500W amp", the voicecoil configuration of the kicker and Audiobahn 15's, and why you want to encorprate 2 crossovers in your system)
Seems as If you have a system without a plan.
Head unit?
More info necessary to give you the best use of your components.
Jan 14, 2009 | KEF Audio PSW 2150 Speaker
Boss Bx35 3 Way Electronic Crossover Logo
18 people viewed this question
Top Boss Car Audio & Video Experts
xxxxxx xxx
Are you a Boss Car Audio and Video Expert? Answer questions, earn points and help others
