Question about Blaupunkt Car Audio & Video
Blaupunkt Toronto 420
I need easy to understand DIY instructions to install the new Blaupunkt into my 2002 Mercedes SLK 230. I bought a wiring harness and antennae adaptor but am unable to determine which wires go where.
    Top Expert:
  • Blaupunkt Master
  • 34,781 Answers
Maybe Blaupunkt can provide instructions.
Posted on Feb 14, 2014
  • 83 Answers
SOURCE: Durabrand Db1200 installation
As per our chat session I said I would be back while I search out your product...so here is your information; http://dbproducts.net/i/product/manual/DB1200_OM.pdf
Posted on Aug 24, 2007
thesoundman
  • 41 Answers
SOURCE: WIRING COLOR CODE
Yellow - +12V Constant Power Red - +12V Switched (accessory) Power Blue - Power Antenna Blue/White - Amp Turn-on White - Left Front Positive Speaker Wire (LF+) White/Black - (LF-) Gray - Right Front Positive Speaker Wire (RF+) Gray/Black - (RF-) Green - Right Rear Positive Speaker Wire (RR+) Green/Black - (RR-) Purple - Left Rear Positive Speaker Wire (LR+) Purple/Black - (LR-)
Posted on Sep 21, 2007
SOURCE: What wiring harness and deck install kit?
My husband and I just installed a Pioneer DEH-2000 MP today in my 2004 Sentra, which we bought at Electronic Express. They didn't have the wiring harness or the install kit we needed, but Best Buy did. Just go there or some other electronics/car audio place and tell them what vehicle you are installing your stereo into. Make sure you do have all the same color wires and numbers of them on your harness(s) as you do for your stereo - they should of course match, and the plugs of the harnesses will match those of your truck. Don't freak out if you don't use all the plugs in your truck though - one may be left because it was proprietary to your stock radio. A couple of good install kit brands are Scosche and Metra - both use factory colors and molding that will match the color and lines of your dash to make it look as integrated as possible.
Hope that helps!
Posted on May 27, 2008
jackiaria
  • 350 Answers
SOURCE: Need a new wiring harness for my Dual XDMR7710
Look in your local phone book yellow pages under stereos for a local (not big name) stereo installation store (there will be one) and go there.....you will thank me!
jack
Posted on Feb 22, 2009
  • 105 Answers
SOURCE: need to install my stereo in my car with out the harness for the stereo
It would be best just to buy a new wire harness for the stereo & the aftermarket harness for the vehicle. If you give me the year, make & model of the vehicle & the model # of the cd player I can get you a price on the two pieces you need.
Posted on May 18, 2009
I need orings for top of pump on slk230
SLK 230 320 Hydraulic Top Cylinder Rebuild Kit O-ring Seals - Page ...
www.benzworld.org > ... > R170 SLK Class
May 6, 2010 - 10 posts - ‎6 authors
If the screw that is on top of the pump is lost what are my options? ... Ebay search: Mercedes SLK 230 320 Convertible Top Hydraulic Cylinder. ... just surprised that the last two orings are almost useless.other than, its worth it.
Oct 30, 2015 | Cars & Trucks
How easy is it to change a broken hood release pull handle on mercedes 230 slk (1999)
you should only have to remove a couple of bolts or screws to remove the old release handle and install the new one
Mar 23, 2015 | 1999 Mercedes-Benz SLK
1998 slk 230 can the boots central locking alignment interfere with the operation of the roof closing
your windows move first , check fuses and clean your window may be sticking due to dirt.
Jan 20, 2015 | 1998-2004 MERCEDES SLK230 SLK 230 CARBON...
Get a headlight washer on a 1999 mercedes benz slk 230 to retract all the way
possibly the motor or gears are either worn or dirty or if they are air driven the small pipes going to the may have falen off or leaking may need to remove the washer to do this and check
Jan 16, 2015 | 1999 Mercedes-Benz SLK
Location vin number
There is a couple of places it could be under the bonnet is one the other is on the door piller
Jul 11, 2014 | 1998-2004 MERCEDES SLK230 SLK 230 CARBON...
Mercedes slk 230 hardtop does not open
I owned an SL 500 with the same issue. The auxiliary battery went out ( during warranty )
Mar 11, 2014 | 1998-2004 MERCEDES SLK230 SLK 230 CARBON...
98 mercedes SLK 230 ASR dash light on although seems ok?
Check one of the fuses in the bonnet. There is most likely an electrical contact problem. You will need a fuse wire replacement
Oct 14, 2009 | 1998 Mercedes-Benz SLK
'03 SLK 230 top wont close - stuck half way open
first thing I would try, disconnect the battery to the car for a minute, then reconnect it. that may correct your problem.
Aug 30, 2009 | 2003 Mercedes-Benz SLK-Class
Err code 714
Hi the fault code on your car means P0714 Transmission Fluid Temperature Sensor Circuit Intermittent. Hope this helps.
Aug 12, 2008 | 2002 Mercedes-Benz SLK-Class
Car Audio & Video Logo
138 people viewed this question
Top Blaupunkt Car Audio & Video Experts
xxxxxx xxx
Colin Stickland
Colin Stickland
Are you a Blaupunkt Car Audio and Video Expert? Answer questions, earn points and help others
